A A A A Автор Тема: Журнал наблюдений переменных звёзд  (Прочитано 287365 раз)
Оффлайн SERIV
  • Благодарностей: 219
    • Сообщения от SERIV
Re: Журнал наблюдений переменных звёзд
« Ответ #2480 : 17 Фев 2016 [00:22:48] »
Вот что ответил А.Henden по поводу развития метода VISDIG и массовой фотометрии переменных на фотоснимках:
I agree that VSP is not a convenient tool for viewing large areas of the sky.  It has a limit of 15x15 degrees so as to be useful to the visual observer, but not for the fields of view from your Zenitar and Gelios lenses.  There is no method of filtering the types of variable stars other than by limiting magnitude.  It would be a good future project to add additional constraints to the displayed variable stars.
VPHOT will perform automated photometry of all known variables in your field of view, and will produce a properly formatted AAVSO Extended Format file.  However, you may find it difficult to use for your application, as you have to manually analyze each image using VPHOT.  If you take multiple images of a single field (a time series), then you can automatically perform photometry on all of the variables.  However, VPHOT is not "free".  You need to be a member of the AAVSO in order to use it.
I do not know of a commercial software application that will do what you want.  Most observers who are creating a survey will write their own scripts to analyze the data.  I would suggest posting to the Software Forum or to the Photometry Forum with your request and ask for help there.
Ясного неба и успехов!
Оффлайн SERIV
« Ответ #2481 : 18 Фев 2016 [11:41:54] »
Обсмотрел ( метод VISDIG) красные переменные в поле Б.Медведица-Г.Псы_Медведица-Лев 16.02.16 19:32 UT:
Z UMA 7.7
IQ UMA 4.5
BR CVN 7.1
TU CVN 6.05
RY UMA 7.2
GY UMA 7.6
VW UMA 7.85
RX LMI 6.0
TV UMA 7.0
RR UMI 5.3
V UMI 7.85
Еще не глядел как стыкуются мои наблюдения с данными AAVSO.
Оффлайн SERIV
« Ответ #2482 : 21 Фев 2016 [09:51:56] »
Обсмотрел яркие красные перменные в поле М.Медведица-Кассиопея-Цефей-Б.Медведица-Жираф-Дракон (частично) (предел 8.5)
метод VISDIG (глазомерная фотометрия по фотоснимкам способом Аргенландера):
16.02.16 19:34 UT:
HU DRA 7.05
T CEP 7.15
V0380 CEP 7.2
S CEP 8.0
V0438 CEP 6.45
V0436 CEP 8.0
V CAS 8.0
R CAS 8.0
V0393 CAS 7.45
В районе 23:51 +52:12  заметил звездоподобный объект примерно 6 величины, которого нету в каталоге Тихо. Стационарный метеор? Блик ИСЗ?
Оффлайн Иван С. Брюханов
  • Благодарностей: 32
    • Сообщения от Иван С. Брюханов
« Ответ #2483 : 21 Фев 2016 [19:04:42] »
VISDIG, глазомерная фотометрия с фотоснимков ,
Да-да ... Правильно правильно, Ваня ...
Когда наблюдения проводятся фактически в режиме реального времени, то этот метод, особенно с последственными инструментами, имеет свой реальный вес ..
Не зря он был по договорённости предложен при наблюдении на снимках олл-скай камер вспышки Новой Дельфина в августе-сентябре 2013-го и уже прочно введён "в оборот" при наблюдениях Новой Центавра в декабре 2013-го .. Не зря, ибо объёмы быстрой информации с погрешностями 0,1-0,2 m по гразомерным измерениям с экрана монитора давали на 2-х 3-х олл-скай камерах круглосуточно информацию об изменениях этих Новых ..
Также были проведены и наблюдения Новой 2 Стрельца в марте-июле 2015-го на снимках олл-скай камер ...
http://adsabs.harvard.edu/abs/2015CBET.4080....2I
Спасибо Иван ... Продолжай и совершенствуй !
Спасибо Саре Бэк, которой надоело править глазомерную с экраном мониторов фотометрию и она ускорила процесс ( :-) ) ... Спасибо Хендену, Самусю и Бердникову, которые приняли эту внесистемную фотометрию особенно для белых или слабо окрашенных звёзд (по договору звёзды спектрального класса B-A-F-G можно промерять с такой погрешностью и достаточной амплитудой в условных лучах CV - TG весьма продуктивно специально для задач фиксации экстремумов и проверки периодов и циклов).
« Последнее редактирование: 21 Фев 2016 [19:27:46] от Иван С. Брюханов »
Оффлайн SERIV
« Ответ #2484 : 21 Фев 2016 [20:47:24] »
Cтараюсь  развивать этот метод, т.к. он позволяет не спеша, в уютной обстановке обсмотреть практически все переменные звезды на фотоснимках! Ну это нужно усидчивость + желание проводить глазомерную фотометрию. Мне нравится.
Опять отсмотрел красные переменные (VISDIG):
16/02/2016:
R TRI 6.95
R GEM 7.55
RR UMI 4.9
GY UMA 7.3
VW UMA 7.5
HL UMA 8.2
ST UMA 7.1
RY UMA 7.25
IQ UMA 4.65
BR CVN 7.2
TT UMI 7.05
V UMI 7.8
R CAM 9.2 ("идет в рост")
X CEP >10
T CEP 7.65 (вышла в горб)
V0386 CEP
V CVN 7.6 (СЛАБЕЕТ)
TU CVN 6.0
CR CVN 7.6
Z UMA 7.8 (СЛАБЕЕТ)
Оффлайн mnn72
  • Благодарностей: 76
  • Astromouse
    • Сообщения от mnn72
    • Astromouse
« Ответ #2485 : 21 Фев 2016 [22:12:45] »
Шо это за метод такой?
Обсерватория: Ananjev (L33, IAU); AAVSO; TESS TFOP (TESS Followup Program)
Открыто: 200 переменных, 46 транзиента (12 сверхновых); Подтверждения: 15 астероидов, 6 комет.
Николай Мышевский
Оффлайн Ghost Rider
    • Сообщения от Ghost Rider
« Ответ #2486 : 22 Фев 2016 [00:48:37] »
Наблюдения от 2016/02/13
S UMa <7.3
Z UMa 7.3
NN UMA 7.4
Удачи Всем!
Оффлайн SERIV
« Ответ #2487 : 22 Фев 2016 [09:36:43] »
VISDIG - метод глазомерной фотометрии с цифровых носителей. Расшифровывается : VISUAL + DIGITAL. Введён AAVSO несколько лет назад, когда в БД AAVSO начали поступать первые плотные ряды наблюдений с олл-скай камер по Новым звездам от Брюханова И.С. Первоначально было не понятно как вообще оформлять наблюдения с jpeg-снимков олл-скай камер. Толи это visual, то ли фотографические наблюдения. Вот тогда руководство AAVSO и ввело новый метод наблюдений - VISDIG. Матрица приемника формирует изображение звездного неба. Глаз человека считывает яркость тех или иных объектов. Можно, конечно, на живом небе обсмотреть в бинокль или телескоп любимые объекты. Кому как удобно. Преимущество метода VISDIG возможность "снять" фотометрию по любым объектам и сделать оценки яркости не один раз, т.е. присутствует документальность наблюдений. Наблюдать можно как методом Аргенландера (всегда можно подобрать рядом звезду по яркости схожей с переменной), так и степенными методами Пикеринга, Нейланда-Блажко. Одно из преимуществ метода - наблюдатель не видит цвет переменной и звезд сравнения в отличие от наблюдений на живом небе. Минус визуала заключается в невозможности проверить оценку яркости. Облака наплыли и все. Как говорится "планетарий закрылся".
Оффлайн SERIV
« Ответ #2488 : 22 Фев 2016 [12:20:41] »
Ради любопытства пронаблюдал Миру Кита на олл-скай камере в NM. Весь процесс занял несколько часиков. :) Звезда ярчает! Мои точки лежат выше данных AAVSO (ближе к полосе R), т.е.  матрица камеры в NM наверняка чувствительна к красным лучам. После 12 февраля ничего рассмотреть нельзя из-за сильного лунного света. Тоже самое и после 14 января. Решил "сопровождать" звезду до ~6.5-7 величины. Погляжу что есть  на своих снимках. Большой плюс наблюдений на олл-скай - плотные круглосуточные ряды по той или иной звезде.
« Последнее редактирование: 22 Фев 2016 [12:26:14] от Иван Сергей »
Оффлайн mnn72
  • Astromouse
    • Astromouse
« Ответ #2489 : 22 Фев 2016 [12:53:11] »
VISDIG - метод глазомерной фотометрии с цифровых носителей. Расшифровывается : VISUAL + DIGITAL...
Искал в AAVSO какую-нибудь инструкцию, а все оказывается просто - визуал с фотографии.
Николай Мышевский
Оффлайн Ghost Rider
« Ответ #2490 : 22 Фев 2016 [21:32:29] »
Да! Не всё так просто в жизни астронома.  :)
Удачи Всем!
Оффлайн SERIV
« Ответ #2491 : 23 Фев 2016 [16:48:50] »
Вчера отнаблюдал минимум AW CAM. Сначала хотел наблюдать VW UMi, которая послабее, но расчетный минимум должен произойти на несколько часов позднее чем у AW CAM. Учитывая нестабильную погоду, быстро плывущие облака и иногда редкие просветы широкого неба, решил остановиться на AW CAM. HEQ-5 + объектив Gelios 2/58. Cразу нацепил KO-140, но из-за яркого фона неба не сориентировался. Расчетный минимум почти совпал с практическим. Сложение с усреднением по 3 кадра, ISO 400, exp. 15s. Данные отправил в B.R.N.O. чехам. На графике O-C(t) красная точка - моё наблюдение. Цель наблюдений минимумов затменных - изучение вариаций периодов во времени.
Оффлайн SERIV
« Ответ #2492 : 23 Фев 2016 [18:28:16] »
"Пробежал" по красным переменным (VISDIG,TG, объективы 2.8/16, 2/58, Canon 400d):
22.02.16:
OMI CET 4.25
R TRI 7.65
R GEM 7.45
V0428 AUR 6.6
NZ GEM 5.65
V CMI 8.1
T CEP 7.65
T CAS 7.7
Мира Кита видна великолепно визуально в 8-кратный монокуляр оценил её 4.6. Визуальные наблюдения Миры дают примерно на 0.4 вел. слабее яркость по сравнению с фотонаблюдениями.
Оффлайн Ghost Rider
« Ответ #2493 : 25 Фев 2016 [02:15:39] »
S UMa < 7.3
NN UMa 7.3
Z UMa 7.45
RY UMa 7.0
T UMa < 6.7
Данные за 2016,02,24
Луна.
Удачи Всем!
Оффлайн SERIV
« Ответ #2494 : 25 Фев 2016 [22:37:53] »
25.02.16 (VISDIG):
R TRI 6.65
OMI CET 4.3 (классно видна даже невооруженным глазом как объект 4.3-4.4 вел.!)
TV PSC 5.1
R GEM 7.65
NZ GEM 5.75
V0428 AUR 6.6
U ORI 9.05 (на прежних снимках не видна. Мирида  ярчает!)
VW UMA 6.7
T CEP 7.8
Сбросил снимки на комп и решил подняться в башню. Вышел из дому - а небо в тучах и снег валит! А до этого был получасовой просвет с кристально чистым небом (lim ~6.2)! Даже на западе над домом видел клин зодиакального света.  :)
« Последнее редактирование: 25 Фев 2016 [22:49:23] от SERIV »
« Ответ #2495 : 29 Фев 2016 [19:05:54] »
Вчера отнаблюдал минимум AW CAM... Учитывая нестабильную погоду, быстро плывущие облака и иногда редкие просветы широкого неба, решил остановиться на AW CAM. HEQ-5 + объектив Gelios 2/58. Cразу нацепил KO-140, но из-за яркого фона неба не сориентировался. Расчетный минимум почти совпал с практическим. Сложение с усреднением по 3 кадра, ISO 400, exp. 15s. Данные отправил в B.R.N.O. чехам. На графике O-C(t) красная точка - моё наблюдение. Цель наблюдений минимумов затменных - изучение вариаций периодов во времени.
Отлично Ваня !
Вот ещё один способ использовать способ наблюдения VISDIG с методами Аргенландера, Пикеринга, Нейланда-Блажко, Горанского для измерения блеска переменных и получения результатов наблюдений с "моментальной загрузкой" фотометрии в хранилища международных научных организаций...
 :-X  :-\
« Ответ #2496 : 29 Фев 2016 [19:23:51] »
    Недостатки фототеки:
    1. Внесистемная фотометрия
1. Ну, с внесистемностью проще простого: использовать исключительно зелёные пиксели и фильтры, обрезающие ИК...
Ну при внесистемной фотометрии VISDIG особенно звёзд спектральных классов B_A_F_G и для задач получения моментов экстремумов периодических переменных звёзд (особенно при плотнейших рядах снимков олл-скай камер) с погрешностями измерений в ~0,1 m - внесистемностью можно пренебречь, так как все ошибки при ухищрениях извлечения информации с отдельных зелёных пикселей намного меньше 0,1 величины.
А также важнейшую роль играет определения момента экстремума, а не точность измерений и внесистемность...
 :-\  :-X
Оффлайн SERIV
« Ответ #2497 : 01 Мар 2016 [00:55:13] »
27 февраля отнаблюдал затменную (EW) NSVS 1156719 в М.Медведице. Цель- определение моментов главного и вторичного минимумов. Автоматическая фотометрия в VAST c привязкой к полосе "V".
Оффлайн SERIV
« Ответ #2498 : 06 Мар 2016 [18:02:11] »
05.03.16 (VISDIG, lens 2.8/16):
R TRI 6.65   ярчает
T CEP 7.75  вышла в горб
R GEM 7.5   "сидит" в максимуме
U ORI 8.05   ярчает
R LEO >8.15
DV LEO 8.05  малоамплитудная SR без периода
V CVN 7.95  слабеет
Оффлайн SERIV
« Ответ #2499 : 06 Мар 2016 [18:03:28] »
Еще кривые красных переменных (AAVSO):
