Также возможен Грегори со сферическим вторичным зеркалом. При этом ГЗ будет гиперболическим. Вторичку можно подобрать из распространенных деталей. Например зеркало от ТАЛ-35 (сувенирный телескоп ньютона) Д=35мм Ф=150мм можно получить супер-планетник с ЦЭ=11,5%
при Д=300мм относительное 1:40. У ГЗ легкая гипербола е2=1.123
D1 Diameter of the Primary Mirror 300.00
F1 Focal Length of the Primary Mirror 1200.00
A1 Focal Ratio of the Primary Mirror 4.00
R1 Radius of Curvature of the Primary Mirror 2400.00
X1 Sagitta of the Primary Mirror 4.6921
E1І Eccentricity at Square of the Primary Mirror 1.123
L1 Linear Field Diameter of the Primary Mirror 0.84
D2a Axial Beam Diameter of the Secondary Mirror 33.75
D2w Clear Aperture Diameter of the Secondary Mirror 34.70
F2 Focal Length of the Secondary Mirror -150.00
R2 Radius of Curvature of the Secondary Mirror -300.00
X2a Sagitta of the Secondary Mirror [D2a] -0.4750
X2w Sagitta of the Secondary Mirror [D2w] -0.5022
E2І Eccentricity at Square of the Secondary Mirror 0.000
D3 Minimum Diameter of Hole in the Primary Mirror 14.22
F Effective Focal Length of the System 12000.00
A Effective Focal Ratio of the System 40.00
L Linear Field Diameter of the System 8.38
Dm Mirror Separation 1365.00
BWD Back Working Distance 285.00
BFL Back Focal Length 1650.01
ODS Object Distance of the Secondary Mirror -165.00
Dfs Diameter of the Front Shield 47.18
Lfs Length of the Front Shield 54.92
Drs Diameter of the Rear Shield 22.62
Lrs Length of the Rear Shield 607.15
Dep Diameter of the Exit Pupil 37.21
Lep Exit Pupil Distance -1488.54
Eab Central Obstruction [D2a/D1] in [%] 11.25
E2w Central Obstruction [D2w/D1] in [%] 11.57
Efs Central Obstruction [Dfs/D1] in [%] 15.73
D1i Diameter of Inoperative Zone of the Primary Mirror 33.75
D2i Diameter of Inoperative Zone of the Secondary Mirror -5.59
q Central Obstruction Ratio -0.14
Я Reciprocal Magnification of the Secondary Mirror -0.13
m Magnification of the Secondary Mirror -10.00
2w Unvignetted Field Angle in Degrees [°] 0.04
