A A A A Автор Тема: камеры SBIG серии STX (STX-16803)  (Прочитано 5295 раз)
Оффлайн rom67Автор темы
    • Сообщения от rom67
« : 18 Дек. 2009 [17:25:04] »
Новые камеры серии STX были анонсированы компанией СБИГ в марте 2009 года.
Обещанные поставки в сентябре 2009 года были прокинуты, но вот на 9 декабря появилась информация, что отгрузка камеры начинается с этого (декабря, 2009 года) месяца.
Подробности по серии http://www.sbig.com/sbwhtmls/stx.htm:
The new STX Series from SBIG will have new imaging CCDs, new tracking CCD, dual interface, greater cooling, faster download rates, new guiding techniques, and more.  The STX features include:
  • Ethernet and USB 2.0 interface on each camera
  • Web browser control ready (no drivers to install)
  • 12VDC Operation (Operates from 9 - 14VDC)
  • Full Frame Image Buffer
  • Multiple A/D Channels
  • Start Next Image While Downloading
  • Continue Guiding While Downloading
  • Internal and External Self-Guiding (Optional Head)
  • Simultaneous Dual CCD Guiding
  • Differential Guiding (patent pending)
  • Continuous Guiding During Autograb
  • Adaptive Optics Ready with Internal or External CCD
  • Minimum Cooling Delta -50 C with Air Only
  • Quick Disconnect Water Cooling Ready
  • Even-illumination Mechanical Shutter
  • Gas Purge Valve on CCD Chamber
  • User Rechargeable Desiccant Plug
  • Variable Speed Fan Control
  • Focus Mechanism for Tracking CCD
  • Opto-isolated Relays for Telescope Control
  • Tracking Relay LED Indicators
  • Power Management LED Indicators
  • I2C Port for AO, Filter Wheel and other accessories
Some Design Features of the STX
USB 2.0 and Ethernet:  Both USB 2.0 and Ethernet will be available on each STX camera.  The user will not have to choose the interface at the time of purchase.  The STX cameras will have the same convenient I2C AUX port that we use on the ST and STL cameras for power and control of accessories such as filter wheels and Adaptive Optics, and will operate from any unregulated 12VDC source.
12VDC Operation:  In similar fashion to the STL cameras, the STX will internally regulate a 12VDC supply so that the camera can be connected directly to any unregulated 12VDC source such as a car battery.  The camera will have 4 power LEDs that will indicate if the supply voltage drops to 11, 10 or 9 volts and when it is "good."  Operation of the camera is possible with a supply voltage of 9.1 to 14 volts DC.
Full Frame Image Buffer: The STX series cameras will have a full frame image buffer for storing image data during download.  The STX will be able to image during download process.  We are exploring the possibility of using this buffer for pre-processing pixel defects based on a defect map provided by the CCD manufacturer, at the user’s direction.
Multiple A/D Channels:  Having multiple A/D channels available makes a number of things possible.  For instance, the STX cameras will be able to download and guide, or guide with two guiders all at the same time.  Guiding can continue uninterrupted using the Remote Head during an autograb sequence, or an automated  LRGB sequence, just as it would if you were using a separate camera or autoguider independent the camera.
Improved Cooling:  Our engineers have modeled an optimum cooling design for this camera using a large custom pin grid array heat sink mated directly to the hot side of the 2 stage TE cooler to achieve maximum heat dissipation with a single large fan.  The STX is designed to achieve a minimum delta of -50 degrees C with air only, and a similar delta with water only.
Water Circulation Ready:  While the design is aimed at sufficient cooling without water assist, it is possible to use water instead of air or in addition to air for optimum cooling.  Using water instead of air will not require the use of a fan.  Chilled water may also be used alone or with the fan for even greater cooling.
Even-illumination Shutter:  Starting with the first ST-7 camera, SBIG has incorporated an even-illumination shutter for taking short exposure flat field frames on all self-guiding cameras.  However, the rotating disk design becomes rather large with ever increasing CCD sizes.  Therefore, a new shutter design will be introduced with the STX series that reduces the overall size and weight of the camera body, while maintaining even illumination on short exposures with large CCDs.
Desiccant + Gas Purge Ports:  In order to allow the user the greatest flexibility in the field, and to avoid having to return the camera to the factory in order to purge the CCD chamber with inert gas, we have designed the chamber to accept both a rechargeable desiccant plug similar to our current ST and STL cameras, and a gas purge port for purging the chamber with Argon or other inert gas if desired.  The camera is designed to operate normally without the need of inert gas in the CCD chamber, but the option to use such gas will be up to the user.
Variable Speed Fan Control:  If the user desires air cooling only, the fan speed is controllable through software.  Variable speed control allows the user to "tune" to fan to eliminate any resonance with the user's telescope thus suppressing harmonic vibrations.
Focusing Mechanism of Tracking CCD:  As CCDs get larger, the tracking CCD is moved farther off-center from the optical axis.  This can result in out-of-focus guide stars.  In order to compensate for different telescopes and different tracking CCD locations, the built-in guider will have a small, user accessible, focus adjustment for the tracking CCD.  Once this is set for a particular camera and scope combination, it will not be necessary to change it.
Opto-isolated Relays for Telescope Control:  These isolated relays will not require an external Relay Adapter box or other opto-isolator to work with virtually any telescope mount that accepts autoguider inputs for guiding control.
Tracking Relay LED indicators:  This handy set of 4 LEDs will tell you at a glance if the camera is issuing corrections to the mount in +X, -X, +Y or -Y directions during an imaging session.
Adaptive Optics and Filter Wheels:  Due to the sizes of some of the planned CCDs, a new AO and Filter Wheel will be designed for the STX cameras.  Filters for most of these chips will need to be larger than 1.25".  Some need to be larger than 2" or 50mm round.
Предполагаемые цены и характеристики
Спецификация камеры на чипе KAF-16803
Появился первый публичный тест камеры STX-16803.
Я позволил себе сделать пдф файл и виложил на постоянный доступ тут:
SBIG STX Beta Report
оригинал AstroPhoto Insight
« Последнее редактирование: 18 Дек. 2009 [17:26:35] от rom67 »
Оффлайн Garmisch
  • Благодарностей: 293
    • Сообщения от Garmisch
    • http://500px.com/ybeletsky
Re: камеры SBIG серии STX (STX-16803)
« Ответ #1 : 18 Дек. 2009 [17:28:20] »
оставил одну тему.
« Последнее редактирование: 18 Дек. 2009 [17:35:34] от Garmisch »
Оффлайн tomato
  • Благодарностей: 469
  • Каменный век- дикие вещи!
    • Сообщения от tomato
    • www.chilescope.com
« Ответ #2 : 18 Дек. 2009 [17:35:35] »
Хе-хе, может не зря я не спешил камеру покупать? ;)
www.chilescope.com
W76
100мм АПО бино
Zeiss Telementor 2
Lunt 60mm
Askar 140 APO
« Ответ #3 : 18 Дек. 2009 [17:39:49] »
ну.. если есть 14-15 тыс.$ в резерве на камеру, то наверное - эта камера будет очень приятным подарком :)
Кстати, у этой камеры есть некий механизм регулировки фокус-дефокус гид чипа. Интересно это как сделано: механически или электронно?
Оффлайн tomato
« Ответ #4 : 18 Дек. 2009 [17:40:52] »
Не, ну может не прям вот эту...
www.chilescope.com
W76
100мм АПО бино
Zeiss Telementor 2
Lunt 60mm
Askar 140 APO
« Ответ #5 : 18 Дек. 2009 [18:55:32] »
ну а о других камерах пока что даже речи не идет. Сейчас они пытаются запустить и отладить выпуск 16803 чипа.
Где-то с месяц назад читал, что якобы потом будут чипы 6303, 9000 и 11002
Но когда это будет? Что-то типа вторая половина 2010 года или даже позже.
Оффлайн Max_canaryskies
  • Благодарностей: 163
    • Skype - max_anderson
    • www.astroshell.com
« Ответ #6 : 18 Дек. 2009 [19:54:03] »
Ну, тут можно одно сказать - надо брать...  :)
Оффлайн Anton
  • Благодарностей: 78
    • Сообщения от Anton
« Ответ #7 : 19 Дек. 2009 [21:14:59] »
Только сначала нужно взять какой нибудь бетоненфокусер и бетонентелескоп впридачу. ;)
2.2 кг на стандартном плече в ~200мм, воткнутое в дристлявый двухдюймовый крефорд, зрелище достаточно жалкое.
Оффлайн NKV
  • Благодарностей: 105
  • Nikolay Volkov
    • Сообщения от NKV
« Ответ #8 : 19 Дек. 2009 [21:19:22] »
Действительно, что-то господа фукусники... пардон... фокусостроители прищурились.
Оффлайн Олег Чекалин
  • Благодарностей: 1150
    • Сообщения от Олег Чекалин
« Ответ #9 : 19 Дек. 2009 [21:23:27] »
2,2 кг + колесо фильтров. Это действительно далеко не каждый кассегреновский задник выдержит.
« Ответ #10 : 19 Дек. 2009 [21:35:06] »
у всех камер СБИГа есть возможность быть примонтированными к рельсе (ласточкин хвост или спец.рельса) на которой крепится телескоп. Проблем не должно быть.
« Ответ #11 : 19 Дек. 2009 [21:39:34] »
Как ты это себе представляешь? Подвижная камера крепится на неподвижный рельс + крепится к фокусеру телескопа. Ну и что?
Оффлайн Anton
« Ответ #12 : 19 Дек. 2009 [22:01:52] »
Пруфпик или пруфлинк в студию.
Дырка с фоторезьбой на сбигах есть, но не более того.
Оффлайн Anton
« Ответ #13 : 19 Дек. 2009 [22:06:20] »
Пня.... Так оно еще и без колеса фильтров встроенного что ли?
Тогда вообще расслабиться можно.
Нелюбительский кингсайз.
« Ответ #14 : 19 Дек. 2009 [22:28:31] »
Антон, а для чего вот эти отверстия и крепеж у камеры ST, тоже самое у STL?
Оффлайн lazyBSD
    • Сообщения от lazyBSD
« Ответ #15 : 19 Дек. 2009 [22:33:13] »
Это как штативное гнездо в фотоаппаратах.
Оффлайн Дмитрий Иванов
  • Благодарностей: 55
    • Сообщения от Дмитрий Иванов
« Ответ #16 : 19 Дек. 2009 [22:34:00] »
Отверстие для ремня\лямки.
Оффлайн Anton
« Ответ #17 : 19 Дек. 2009 [22:44:03] »
У STL щели такой вообще нет, есть только дырка с фоторезьбой.
У ST в дырке та же фоторезьба а зачем эта щель хз. Под ней сразу печатная плата и бумажка наклеена, что мол больше несколких миллиметров в дырку не совать. Скорее всего для охлаждения.
Так что нету у сбига никаких хитрых рельсов, домкратов и такелажа для поддержки камер.
« Ответ #18 : 19 Дек. 2009 [23:03:02] »
видел у америкоса именно для ST10XME версии вот в эту щель и резьбу накручен уголок, который крепился к рельсе.
Помимо камеры был AO8 и фокусер на кассагрене (не, не кассагрен был... что-то другое, не помню сейчас) стояли.  Камера крепилась боком, отверстием вниз.
После того как ткнул пальцев мне ответили, что так прогибов вообще нет.
Мне идея оченно понравилась.
плата стоит сильно ниже. Ничего не мешает туда засунуть уголок. Только что посмотрел на своей камере.
На вентиляцию эта щель никак не сказывается, вентиляция идет через заднюю плату, так где вентилятор стоит.
« Последнее редактирование: 20 Дек. 2009 [00:23:57] от rom67 »
« Ответ #19 : 19 Дек. 2009 [23:34:50] »
Мало ли в аматерской среде авангардистов. Но в целом это не решение, особенно при дистанционном управлении телескопом.
