Boosting Color Saturation A color saturation boost can be carried out by different ways in PixInsight; for example with a midtones transformation, or by applying curves in different color spaces. Our recommendation is to modify color saturation working in the HSVL or CIE L*c*h* color spaces, since they perform a much more accurate isolation of the chrominance. In this example we have increased color saturation by modifying the c* component of the CIE L*c*h* color space. In this color space, an aggressive increase in saturation can be achieved without causing any deviations in color hue. However, independently of the color space used, the higher the increasing in color saturation, the higher the resulting noise in the chrominance. We have chosen the LRGBCombination process in PixInsight, not only because it is an excellent tool for LRGB image combination, but because it allows a significant boost in color saturation by means of a midtones transfer function applied to the CIE c* component, while at the same time it can reduce chrominance noise efficiently (in the CIE L*a*b* space).
Finally, we have applied a color saturation enhancement with LRGBCombination. To do this, we have deactivated the R, G and B channels (as they play no role in this process), have checked the "L" box, and have selected the luminance of our RGB image (identified as Luminance_RGB on Figure 19). Then we have defined the midtones transfer function in the saturation component, and at the same time we have adjusted chrominance noise reduction parameters.
Есть такая обучалка по Плеядам http://pixinsight.com/examples/M45-sonnenstein/en.html...Кто разбирался с этой обучалкой и понял как они конкретно усиливают цвета?
PCLDIR=$HOME/PCLPCLBINDIR32=$PCLDIR/binPCLBINDIR64=$PCLDIR/binPCLBINDIR=$PCLBINDIR64PCLLIBDIR32=$PCLDIR/lib/linux/x86PCLLIBDIR64=$PCLDIR/lib/linux/x86_64PCLLIBDIR=$PCLLIBDIR64PCLINCDIR=$PCLDIR/includePCLSRCDIR=$PCLDIR/srcexport PCLDIR PCLBINDIR32 PCLBINDIR64 PCLBINDIR PCLLIBDIR32 PCLLIBDIR64 PCLLIBDIR PCLINCDIR PCLSRCDIR
Коля, про CosmeticCorrection, еще раз опиши, пожалуйста, алгоритм автодетекта.Ты анализируешь весь бэеграунд целиком? Не окном?
Каким-то образом username oказался пустым , видимо из аккаунта PayPal подхватило кириллицу. Here are your personal account data:-------------------------------------------------------------------------Username : Password : zzzzzzzzzzzz-------------------------------------------------------------------------Нафиг его было на русском делать, я и заполнил на русском, осёл Написал в support, чтобы персональные данные поменяли.
Обновил PCL: Comet Alignment module
Как же классно работает и как же такого модуля не хватало! Спасибо, Николай!(Гаррадд 25 сентября 2011г.)
И под маком это все тоже будет работать?
