Или: CANON - г...., а SBIG - рулит (тем более и с редьюсером - поле нормальное). ИМХО.
For the best quality imaging, select Readout Mode to RAW Monochrome and set Binning to 1x1. In this mode, the images are initially monochrome but have color information encoded in them by way of a Bayer matrix. Although color is not immediately visible, this mode provides higher bit depth (12 bits instead of , and dark frame subtraction will be superior on RAW images. The typical sequence is to acquire images, subtract dark frame, convert color, and then stack. Note that this mode is not suitable for use with the focusing tools.If you set Readout Mode to RAW Color and Binning to 1x1, then the images appear immediately in color. This is not optimal for dark frame subtraction, though, so the RAW Monochrome mode is preferred unless you set the camera to subtract dark frames internally. Some camera models have the capability of taking two frames for every exposure; one with the shutter closed and one with the shutter open; the images are automatically subtracted prior to download. If you activate this mode, then the images take twice as long to collect, but they are already dark subtracted. This feature is best used with Developed Color, since it eliminates the color conversion step.Focusing can be performed in any mode except for RAW Monochrome, Binning 1x1. In that mode, the Bayer matrix is present, and this will interfere with measurements. Focus in any other mode or with Binning 2x2. Please note that Binning only improves the download speed for JPEG download modes.ISOThis setting can adjusted on the Expose tab. The desired ISO setting can be configured from 100 through 3200 (the range actually available depends on the camera model selected). The ISO setting is really the camera's A/D converter gain; a low setting provides good quality but is less sensitive. A high setting provides the highest sensitivity but may limit the dynamic range. You may need to use trial-and-error to determine the best setting for your specific conditions; however, a good starting point for low-light images is 800.
Цитата: hard Noi 2 от 08 Апр 2010 [09:24:06]Или: CANON - г...., а SBIG - рулит (тем более и с редьюсером - поле нормальное). ИМХО.ну да, при том что один из чипов охлаждается зы. можете исходники кинуть - думаю можно сделать результат одинаковым практически
Краткий перевод - снимать только в бининге 1. При переключении в бининг 2 аппарат переводится в режим JPEG. По крайней мере мой 300Da - не знаю, как более современные модели, поддерживающие RAW+JPEG.
Интересно, на Кэнонах все работают через Максим или кто-то работает через родное ПО? Уж больно результат выглядит по разному
Слово JPEG при записи кадра не заметил. По умолчанию TIFF не важно в каком бининге. В avtosave ставилось RAW-Color. Это и есть JPEG? Но кадры записывались не в 8 битах, а в 16 (по крайней мере так в фотошопе отражается). Чего -то не понимаю? Объясните. А то, если есть кнопочка 2х2 - почему бы и не нажать?
... даже кропнутый Кенон лучше ...
Цитата: Opossum от 08 Апр 2010 [23:14:25]... даже кропнутый Кенон лучше ...Угу, тоже так подумал. Рано ещё кэноны на помойку нести.
Я честно говоря не понял,... что-то пытаетесь сравнивать?
Народ, покритикуйте фотографии (одниночные) начинающего астрофотографаОсновоной инструмент - RC400, SW 240 камера SXV-M25? выдержка 300 секГИД - ED80, камера QHY6
Народ, покритикуйте фотографии (одиночные) начинающего астрофотографаОсновной инструмент - RC400, SW 240 камера SXV-M25 выдержка 300 секГИД - ED80, камера QHY6 M104 от 09.04.10NGC 4565 от 09.04.10М101 от 09.04.10 (200 сек)Желаю критики ОДИНОЧНЫХ КАДРОВ, что там не так... (до сложения я еще пока не дорос...)
А чего критиковать в одиночных кадрах? Качество гидирования, фокусировки, кадрирование?Это вроде нормально получилось на NGC4565. А на остальных звёзды тянутые. Сейчас основная задача - освоить гидирование. Одиночные кадры - это сырьё, но не результат. Выбрасывать их не надо. Их надо копить!
Ок, а фокусировка как??
А тянутые из за чего бывают, в данном случае сильно тянутые??? Криво монтировка ведет??
Выдержка достаточная??
есть ли будущее у этих одиночек, или в мусорный ящик??
