A A A A Автор Тема: Новые камеры от QHY  (Прочитано 244212 раз)
Оффлайн mo
  • Благодарностей: 1094
    • Сообщения от mo
Re: Новые камеры от QHY
« Ответ #2200 : 22 Апр. 2020 [18:47:51] »
Это "фича" драйверов
Написать бы китайцу. Тут другое слово в кавычках явно.... если минуты на две толерантность отключить :)
モ - mo
Оффлайн Владимир НиколаевичАвтор темы
  • Благодарностей: 453
« Ответ #2201 : 24 Апр. 2020 [19:25:01] »
Вышла рекламка на камеру QHY247C - новая цена 1700$ в Китае и порядка 1850$ у нас.
https://www.qhyccd.com/index.php?m=content&c=index&a=show&catid=94&id=14&cut=1
The new list price of QHY247C takes effect immediately and will continue until further notice. QHYCCD will price protect
dealers who purchased the QHY247C on or after April 12, 2020. Please change the price on your website and release
notice of this price reduction to your customers.
Low Dark Current: In addition to dual stage TE cooling, QHYCCD implements proprietary technology in hardware to
control the dark current noise in the QHY247C. As a result, the dark current of this camera is a remarkable 0.0012e-/p/s
at -15C.
Sensor AR coating: Halos around bright stars are caused by reflections between surfaces of elements in the optical path.
An uncoated surface usually reflects about 8%-10% of the light striking it while a high quality multiple layer coating
reflects only 1% or less. The IMX193 has superb quality AR coatings on the sensor and this can significantly reduce the
halo effect.
APS-C, 24 Megapixels: The QHY247C has 24 Megapixels, high resolution, 3.91um pixels in a 6024 x 4024 array. When
combined with high quality telescope optics or even with the RASA telescope, the QHY247C can generate the large
images that are ideal for large scale printing.
Оффлайн Infinity
  • Благодарностей: 394
    • DeepSkyHosting: Infinity
    • Сообщения от Infinity
« Ответ #2202 : 24 Апр. 2020 [20:31:25] »
Чб APS-C ожидается?
EQ6 Pro/HEQ5
Онлайн EvgeniyM
  • Благодарностей: 99
    • Сообщения от EvgeniyM
« Ответ #2203 : 24 Апр. 2020 [20:55:30] »
И да, народ страждет моно APS-C сенсор. Это был бы бестселлер.
Оффлайн Олег Чекалин
  • Благодарностей: 1150
    • Сообщения от Олег Чекалин
« Ответ #2204 : 24 Апр. 2020 [21:17:33] »
Qhy вообще-то, обещал 342 моно камеру выпустить. Может и не самый хороший сенсор, но все равно был бы хит. Нужно пинать его в интернетах.
https://www.qhyccd.com/bbs/index.php?topic=6706.0
« Последнее редактирование: 24 Апр. 2020 [21:52:55] от Олег Чекалин »
Оффлайн ROVIAN
  • Благодарностей: 1480
  • RV6LOT Icom IC-775DSP
    • Сообщения от ROVIAN
« Ответ #2205 : 07 Май 2020 [11:35:56] »
https://www.facebook.com/pg/QHYCCD/posts/?ref=notif
QHY600 Photographer Version--Receive orders now.
Compared with the professional version and the previous early-bird version, the photographic has the same capability in astrophotography stuffs, and has shorter camera body--and lower price.
*Take filterwheel / filter suits to get more bentfit
*Support extrashort backfocal (7mm) / Watercooling Custimization
Короткая версия  (не PRO)....... поддерживает водоохлаждение,  короткий бекфокус  :-[
« Последнее редактирование: 07 Май 2020 [13:07:05] от ROVIAN »
Онлайн leviathan
  • Благодарностей: 1647
  • Смотри в оба !
    • Сообщения от leviathan
« Ответ #2206 : 07 Май 2020 [11:41:47] »
И насколько ловер прайс ?
Я видел всё небо !
Оффлайн ROVIAN
« Ответ #2207 : 07 Май 2020 [11:48:28] »
Надо узнавать.... пока не заморачиваюсь, не до такой камеры...пока.
Оффлайн ROVIAN
« Ответ #2208 : 07 Май 2020 [13:08:45] »
Ну теперь понятно, по "спецзаказу"  :-X
"Custmization only so if any interest please contact us directly."
Онлайн EvgeniyM
« Ответ #2209 : 07 Май 2020 [13:44:47] »
Онлайн leviathan
  • Смотри в оба !
« Ответ #2210 : 07 Май 2020 [14:29:52] »
Уже лучше, ближе к ASI6200. :)
Я видел всё небо !
Онлайн EvgeniyM
« Ответ #2211 : 07 Май 2020 [15:16:19] »
Еще ближе:
https://www.teleskop-express.de/shop/product_info.php/language/de/info/p11945_Atik-Color-CosMOS-Kamera-gekuehlt-61-2MP-Kamera-Cip-D--43-2mm.html
Atik закрыл страницу Cosmos, поскольку производство было приостановлено из-за вирусного кризиса.
Оффлайн Сергей1981
  • Благодарностей: 123
    • Сообщения от Сергей1981
« Ответ #2212 : 07 Май 2020 [17:16:00] »
Всем здоровья. Планируется ли выпуск камер типа 290 с большим размером матрицы?
OrionUK 300/1200
Quattro 200P
EQ6pro
ASIair,EAF,EFW.
GPU 1.0x/SW0.85x
ZWO ASI585MC,ZWO ASI585MМ,ZWO ASI462MM.
Touptec 678ММ,Touptec 662MM.
Онлайн Дмитрий Маколкин
  • Благодарностей: 1522
  • всяко разно
    • Skype - dmitrymakolkin
    • DeepSkyHosting: dvmak
    • Панорамы Луны
« Ответ #2213 : 07 Май 2020 [18:12:50] »
У Сони таких сенсоров нет :(
Панорамы Луны в моей галерее:
Оффлайн AnatolyP
  • Благодарностей: 41
    • Сообщения от AnatolyP
« Ответ #2214 : 07 Май 2020 [20:00:46] »
Еще бы у QHY600 драйвера были рабочие, сейчас глючная [----]. Свою никак не могу заставить стабильно работать, может повиснуть в любой момент, без присмотра и на час не оставить:(
Онлайн leviathan
  • Смотри в оба !
« Ответ #2215 : 07 Май 2020 [20:29:22] »
Если бы это написал я, то объявили бы врагом народа и шпионом ZWO. ;D
Я видел всё небо !
Оффлайн AnatolyP
« Ответ #2216 : 08 Май 2020 [01:03:45] »
У меня из ZWO только 290 моно и 224 цветная, не глючили ни разу. А из QHYCCD есть еще  163M и 128С, обе работают нормально (хотя 128С использовал только несколько раз всего). Правда в драйвере для QHY163M тоже есть косяк, ну или он в данных на камеру на их сайте: на сайте указано, что максимальное время экспозиции составляет 30 мин, а аском драйвер не дает снимать больше 20 мин. А самая глюкавая была связка QHY8M и колесо фильтров - такое впечатление было, что пятилетний ребенок драйвера писал. После того как от нее избавился, долго ничего от QHY не покупал.
Для QHY600M на сайте до сих пор драйвера выложены только как тестовая версия, сами наверняка знают какое они г... пока.
Оффлайн Грехов Михаил
  • Благодарностей: 822
    • Сообщения от Грехов Михаил
« Ответ #2217 : 08 Май 2020 [01:14:40] »
Не по новой, а по старой камере вопрос - QHY-5 (1-ая версия, шайба). Почему то изображение, снимаемое с камеры перевернуто шиворот навыворот по горизонтали (право на самом деле лево). В программе QGVideo предусмотрена функция "Horizontal Flip" для устранения этого. А есть ли такое, чтобы это исправлялось еще ранее - при процессе снятия информации по USB? И далее уже шла в любую программу в "правильном" виде?
Онлайн leviathan
  • Смотри в оба !
« Ответ #2218 : 08 Май 2020 [01:39:44] »
А какой версией драйвера пользуетесь ? И снимаете в какой программе и ОС ?
Я видел всё небо !
Оффлайн AnatolyP
« Ответ #2219 : 08 Май 2020 [02:24:12] »
Версии драйверов устанавливал все новые, когда они выходили, сейчас стоят последние, которые на сайте выложены. Но ничего пока не меняется. Ось  - Win 10 Pro. Пробовал в MaximDL - камера вылетала почти всегда в первые несколько минут работы, поэтому перешел на N.I.N.A. Тут ситуация получше, может проработать несколько часов, а может сразу зависнуть, хотя ни процессор ни память особо не нагружаются. Причем виснет так, что приходится перезагружать винду. В общем сыро пока все. Хочу на совсем чистую систему все установить, но пока руки не дошли, работы много, на мою работу карантин не распространяется.
