A A A A Автор Тема: "Джуно" прилетел к Юпитеру  (Прочитано 182879 раз)
Оффлайн Andrey_Samoilov
  • Благодарностей: 22
    • Сообщения от Andrey_Samoilov
Re: "Джуно" прилетел к Юпитеру
« Ответ #360 : 15 Мар 2014 [11:39:56] »
Этот мой пост не про аппарат, но по теме изучения Юпитера и других газовых гигантов.
В немецком научном центре в лабораторных условиях с помощью рентгеновского лазера "FLASH"  смоделировали (ионизировали жидкий водород)  нижние слои атмосферы Юпитера.  Исследования планируется продолжить.
http://www.xfel.eu/news/2014/flash_spies_deep_into_giant_gas_planets/
The study requires a great deal of effort, in part because hydrogen does not normally exist in liquid form on earth. In order to liquefy hydrogen gas, it first must be cooled to minus 253 degrees Celsius. “We use extremely pure hydrogen gas and force it through a copper block that is cooled by liquid helium,” explains DESY researcher Sven Toleikis, a member of the team. “The temperature must be very precisely controlled during this process. If the hydrogen gets too cold, it freezes and blocks the line,” says Toleikis. In such cases, a small heater is used to re-liquefy the hydrogen as needed. At the end of the copper block, a nozzle projects like a finger into the experimental vacuum chamber. From its tip flows a fine jet of liquid hydrogen with a diameter of just one fiftieth of a millimetre (20 micrometres). This experimental setup has been constructed in the course of many years of cooperation between the University of Rostock and DESY.
“This method opens up the road for further studies, e.g. of denser plasmas of heavier elements and mixtures, as they occur in the interior of planets. Hopefully, the results will provide us among others with an experimentally based answer to the question, why the planets discovered outside our solar system do not exist in all imaginable combinations of properties as age, mass, size or elemental composition, but may be allocated to certain groups.”
« Последнее редактирование: 15 Мар 2014 [11:49:52] от Andrey_Samoilov »
"Когда мы овладеем всеми этими шарами Вселенной, и всеми их усладами, и всеми их знаниями, будет ли с нас довольно?", Уолт Уитмен
Оффлайн dan77790
  • Sic!
    • Сообщения от dan77790
« Ответ #361 : 24 Фев 2015 [22:13:29] »
А вот прямо сейчас вокруг Сатурна крутится "Кассини". А вокруг Юпитера ПРЯМО СЕЙЧАС ничего не крутится из автоматических станций? Вроде только в 2016 ЮНОНА долетит... А сейчас там нет нашего присутствия?
Оффлайн Грехов Михаил
  • Благодарностей: 822
    • Сообщения от Грехов Михаил
« Ответ #362 : 24 Фев 2015 [22:31:56] »
Нихт. Совсем нихт уже более 10 лет. Был КА "Галилео", но его история закончилась 21 сентября 2003 года.
Оффлайн LeMay
  • Благодарностей: 1015
    • Сообщения от LeMay
« Ответ #363 : 24 Фев 2015 [22:33:20] »
  Прямо сейчас ничего не крутится и до прибытия Juno в июле 2016 г. крутиться не будет.
Оффлайн LeMay
« Ответ #364 : 07 Июл 2015 [23:46:20] »
  http://www.nasa.gov/jpl/with-one-year-to-jupiter-nasas-juno-team-prepares
  Почти за год до прибытия Juno к Юпитеру (4 июля 2016 г, что и изобразил художник на картинке выше), NASA изменило план выхода на орбиту и работы аппарата на ней. Вместо 11-суточной полярной орбиты будет 14-суточная, вместо минимум 15 месяцев Juno должен проработать 20, сделав 32, а не 30 оборотов вокруг планеты.
  Думаю, опасаются ранней деградации солнечных батарей или иных проблем с радиацией и решили подстраховаться: основные данные о гравитационном и магнитном полях Юпитера будут получены всего за 8 витков по орбите, а не за 15, как ранее планировалось. Каждый следующий цикл из 8 витков будет улучшать уже имеющиеся данные.
Оффлайн LeMay
« Ответ #365 : 14 Янв 2016 [12:09:09] »
  https://www.nasa.gov/feature/jpl/nasas-juno-spacecraft-breaks-solar-power-distance-record
  13 января Juno побила рекорд удаления от Солнца для работающей межпланетной станции на солнечных батареях - 793 млн км. Предыдущий рекорд был поставлен Rosetta в октябре 2012 года в афелии её орбиты - 792 млн км.
Оффлайн arduan
  • Благодарностей: -20
  • все будет хорошо
    • Сообщения от arduan
« Ответ #366 : 16 Янв 2016 [11:15:07] »
Здесь счетчик   https://www.missionjuno.swri.edu/    остался 171 день с точностью до секунды
« Ответ #367 : 15 Мая 2016 [20:59:54] »
Джуно признали самым быстрым рукотворным объектом.
http://www.ibtimes.co.uk/nasas-juno-spacecraft-becomes-fastest-object-ever-made-during-mission-jupiter-1560157?utm_source=yahoo&utm_medium=referral&utm_campaign=rss&utm_content=/rss/yahoous/news
Рекорд Гелиосов пал.
Оффлайн Trend
  • Благодарностей: 30
    • Сообщения от Trend
« Ответ #368 : 16 Мая 2016 [13:41:11] »
У этой космической миссии самый лучший сайт, который я видел. Подробнейше объяснено устройство аппарата и цели миссии.
Оффлайн Mark
  • Благодарностей: 166
    • Сообщения от Mark
« Ответ #369 : 30 Мая 2016 [21:40:18] »
Автоматическая межпланетная станция Juno вошла в систему Юпитера
http://www.astronews.ru/cgi-bin/mng.cgi?page=news&news=8564
"три фигурки LEGO из алюминия"
Canon EOS 60D;
Celestron NexStar 6 SE
"We are made of star stuff".
Оффлайн [XD]
    • Сообщения от [XD]
« Ответ #370 : 31 Мая 2016 [08:09:49] »
Отлично, хоть что то интересное, в этом году
Пока без телескопа
Оффлайн Crewe
    • Сообщения от Crewe
« Ответ #371 : 31 Мая 2016 [12:48:11] »
Фотографий подлета к Юпитеру не будет, правильно я понимаю? Жаль, вроде камера неплохая стоит.
Говорить путано умеет всякий, говорить ясно немногие. (с) Галилео Галилей
Оффлайн ЖораIV
    • Сообщения от ЖораIV
« Ответ #372 : 31 Мая 2016 [20:20:51] »
Гибель аппарата запланирована на февраль 2018 года, когда его направят в атмосферу Юпитера, где он и сгорит.
Интересно, какой глубины достигнет аппарат перед тем, как сгорит.
Телескоп Celestron NexStar 127 SLT
Оффлайн Mark
    • Сообщения от Mark
« Ответ #373 : 31 Мая 2016 [20:31:01] »
Наверное не будет. Хотя, посмотрим. :)
Canon EOS 60D;
Оффлайн Moonchild
  • Благодарностей: 83
  • Акуна матата!!!
    • Сообщения от Moonchild
« Ответ #374 : 31 Мая 2016 [20:36:10] »
никакой, сгорит в верхних слоя атмосферы, как и "Галилео", т.к. на скорости порядка 40-50 км/с без теплозащиты других вариантом быть не может
Оффлайн Бизоныч
  • Благодарностей: 26
    • Сообщения от Бизоныч
« Ответ #375 : 01 Июн 2016 [09:53:05] »
Камера там как раз не фонтан. Максимальное разрешение ожидается 15 км на пиксель. да и не нужно там сверх разрешение, миссия не орбитер системы Юпитера, а орбитер самой планеты. Для наблюдения старика Джупа вполне хватит, да и с траффиком на Землю там проблемы. Вот статьтя.
https://ru.wikipedia.org/wiki/JunoCam
Китайский noname рефрактор 50/360  на теодолитном штативе, SW 150/750 на AZ4.
Оффлайн LV46
  • Благодарностей: 411
    • Сообщения от LV46
« Ответ #376 : 02 Июн 2016 [13:45:51] »
Откуда такие цифры? Сейчас скорость Джуны - 542м/с и увеличивать уже не будут.
....a 35-minute burn of its main engine, which will impart a mean change in velocity of 1,212 mph (542 meters per second) on the spacecraft....
Оффлайн Moonchild
  • Акуна матата!!!
« Ответ #377 : 02 Июн 2016 [14:02:24] »
скорость относительно чего???
а увеличивать ее и не надо, это сделает Юпитер своим притяжением. любое тело, попавшее в зону влияния Юпитера и свободно падающее, будет  притянуто и достигнет вблизи самого Юпитера такой скорости. почитайте про миссию "Галилео", посмотрите фильм ВВС "Планеты", так как раз один из разработчиков про это рассказывает. да и можно еще копнуть небесную механику и посчитать какая скорость зонда будет относительно планеты в перицентре орбиты и в апоцентре...
Оффлайн Moonchild
  • Акуна матата!!!
« Ответ #378 : 02 Июн 2016 [14:03:20] »
...гигантская масса Юпитера делает свое дело :)
Оффлайн Infinity
  • Благодарностей: 393
    • DeepSkyHosting: Infinity
    • Сообщения от Infinity
« Ответ #379 : 02 Июн 2016 [14:06:18] »
Хммм, а он будет производить съёмку во время своего приближения перед сгоранием?
EQ6 Pro/HEQ5
