Значится формула такая ( просто проницающая способность телескопа )m = 5.5+2.5LgD+2.5LgND - диаметр объектива в смN - увеличение используемое при визуальных наблюдениях ( в нашем случае видимо 1 )
Посчитал проверил.Действительно в приведенной формуле Боуэна вероятнее всего должны быть САНТИМЕТРЫ
Also, as explained above, there are different factors to be considered for electronic imaging. In particular, the t in your formula would need to be replaced by square root of t because electronic noise increases with time as well as the signal from the star.Thus a formula like this one would be more accurate:LM = M + 2.5 * log10 (d * d * sqrt(t))ieLM = M + 5*log10(d) +1.25*log10(t)For d in metres and t in seconds the value of M would be around 15 to 17 depending on the quality of the CCD camera used. This assumes that star size is atmosphere limited to about 2 arcsec diameter and that camera noise is greater than background sky brightness.When star size is telescope resolution limited the equation would become:LM = M + 10*log10(d) +1.25*log10(t)and the value of M would be greater by about 3 magnitudes, ie a value 18 to 20.For a practical telescope, the limiting magnitude will be between the values given by these 2 formulae. An exact prediction cannot be expected, but these values are consistent with the images shown above.Background sky brightness will likely be between 17 and 24 magnitudes per square arc sec. If star image brightness is less than this value then this condition takes precedence and the above formulae are irrelevant.
In 2007, amateur astrophotographers Johannes Schedler and Ken Crawford combing more than 12 hours of exposures through 16" and 20" telescopes to image a high-redshift quasar. The magnitude of the quasar was measured at 24.8. Its redshift is 6, meaning light left the quasar nearly 13 billion years ago!
Цитата: Ar(h0n от 30 Сен 2009 [21:54:12]Цитата: M.Sergey от 30 Сен 2009 [20:52:54]А как посчитать проницающую способность телескопа при астрофотографии?Такая формула просто не нужна.Для её выведения нужно ...1) постулировать критерий "проработки" звезды по соотношению сигнал/шум (то есть считать проработанными звёзды с С/Ш, например = 3)2) учесть пропускание оптической части инструмента (поглощение в стёклах, коэффициенты отражения зеркал, процент площади свободной от Ц.Э, виньетирование)3) Учесть квантовую эффективность матрицы с данным светофильтром или IR-Cut фильтром (для цифрозеркалок каждый цветовой канал отдельно).4) Длительность экспозиции (если кадров несколько, то их число через формулу роста с/ш в зависимости от методики сложения).5) Шум считывания матрицы также влияет на кривую зависимости сигнал/шум от длительности экспозиции и их количества6) Размер звезды на приёмнике (FWHM), который зависит от турбуленции, качества гидежа, фокусировки и оптических характеристик инструментаВ итоге получим очень большую, и точную формулу, которая не работает. Потому что1) засветка повлияет на результат с силой +/- пара звёздных величин. Причем засветка ещё и может отличаться спектральными характеристиками и меняться в течение ночи (в некоторых городах гасят уличное освещение и подсветку зданий, в остальных к глубокой ночи пропадают с дорог автомобили с фарами и гасятся окна)2) Прозрачность атмосферы и светорассеяние меняются в широких пределах.3) Турбуленция (п.6) меняется от ночи к ночи, и даже от кадра к кадру, а от концентрации сигнала в точку проницание сильно зависит.Так что теоретически рассчитать возможно, но на практике получается слишком много трудноуловимых неизвестных. Поэтому вместо формул, обычно используют экспериментальные данные для конкретного приёмника, оптики и астроклимата.
и еще, можно было бы поискать по форуму про проницающую способность телескопа, было раньше обсуждение, но наиболее конкретно и КМК правильно ответил Игорь Чекалин тут: ...
PS1: Можете попробовать найти статью из Sky&Telescope за 1998г. (page 117 of the May 1998 issue), называется "Limiting Magnitudes for CCDs", автор Bradley E. Schaefer.Коллеги из ньюйоркского клуба мне подкинули ссылку на калькулятор по этой статье: http://www.go.ednet.ns.ca/~larry/astro/ccdlimit.html
Не сразу понял с кем имею дело
напрягитесь, и осильте то, что написано мною выше (включая англоязычный текст с формулами)
Формула моя - вывел 15 мин назад.
Пока будем по умолчанию считать верным ...
Ваша последняя формула просто математический спам. Попробуйте оценить от каких параметров зависит предельная видимая зв.величина (ПЗВ) и увяжите их в формулу, а не пытайтесь подгонять константы к заранее известному результату.Я вам дал первоисточник в котором весьма умный человек пытался увязать все известные ему параметры, влияющие на ПЗВ. На основе этого была написана программа...
Все больше склоняюсь к мнению, что темы Graf-a все же нужно перенести в Клуб Разве что читать будет не очень неудобно, т.к. в данном случае "Комната смеха" подрастет за раз на страниц 20-30
Вот зарплату астрономов-то и экономят огромные телескопы, эффективно исследующие Вселенную!
Все больше склоняюсь к мнению...
Предельную величину ему подавай. А спроси его что он будет с нею делать, с этой m limited, так он и не знает.
