ВНИМАНИЕ! На форуме идет голосование в конкурсе - астрофотография месяца - АВГУСТ!
Вообще говоря, это неверно. Вещество кометы в целом должно быть довольно светлым. Но на поверхности оно безнадёжно тёмное по причиние обогащения всякой нелетучей сажей и потемнения камня в результате воздействия радиации. У меня есть множество фактов "в кармане", легко опровергающих эти ваши выводы (спутник Сатурна Феба, 9P/Tempel, 67P/C-G, ...).
Размер яркого пятна, откуда происходит (скорее всего) выброс водяного пара, не превышает 4 км, его альбедо больше 40%.
Цереру поделили на зоны (quads), каждая из которых получила имя бога урожая у разных народов.
One of the interesting talks from that part of the session was by Tim Titus, who tried to use modeling to figure out where the "snowline" on Ceres is -- that is, the latitude at which ice is stable at the surface. Ceres has nights and days, of course, so the surface temperature varies with time, but those variations die out as you go beneath the surface. Titus defined locations where the subsurface never gets above 145 kelvins to be the location of the snowline on Ceres. For a variety of possible surface properties, a smooth surface would have a snowline somewhere between 40 and 60 degrees. If that surface is roughened (by, say, impact craters), then the snowline shifts poleward. So near-surface ice is stable near the poles, and comet-like ice sublimation could happen there, especially with help from seasonal heating or a meteor impact. On the other hand, plume activity at lower latitudes -- like the 20-degree-north position of the bright spot -- is happening in a place where near-surface water ice is not stable. Activity there would need to originate in a source of water ice that gets recharged somehow, such as by cryovolcanism. Of course, as Andy Rivkin pointed out during the question period, a sufficiently big impact could expose much more deeply-buried ice; he asked if Titus had modeled how often impacts would be expected to expose such deep ice. Titus replied that this was beyond the scope of his work.
Довольно светлым? Вообще-то, мы видели область коренных кометных пород на комете Чурюмова-Герасименко в районе перешейка, не присыпанную пылью. И она такая же тёмная, как и вся комета. Про радиацию лучше вообще не упоминать – возраст поверхности этого перешейка едва ли сотня лет, комета ведь испаряется, а радиационное потемнение занимает куда больше времени.
Можете ли вы привести хотя бы один пример кометы, у которой был бы участок поверхности с альбедо больше 40%? Боюсь, что нет.
Ни одного слова про альбедо больше 40% здесь нет.
Цитата: Kweni от 23 Мар 2015 [09:12:08]На кометах области, где происходит испарение, такие же тёмные, как и те, где испарение не происходит.Вообще говоря, это неверно. Вещество кометы в целом должно быть довольно светлым.
Нет, из этого следует, что лёд в ярком пятне на Церере не является грязным, в отличие от льда комет.Использование цифр никак не может быть уводом разговора в сторону. Вся наука основана на численных измерениях.
1. 40% - это довольно таки грязный лёд.
Вещество под поверхностью кометы может иметь альбедо хоть 50%
Оно меньше 4 км - это все, что про него известно.
as Ceres' globe rotates and the 80-kilometer crater's rim rotates into view, that rim should block our ability to see the bright feature on the floor of the crater. However, the bright feature is already visibly bright as the crater begins to rotate into view. Therefore, it must be vertically above the rim of the crater: it must be some kind of plume.
3. Вы утверждали что на кометах нет светлых пятен льдов без всяких цифр - это тоже не верно, они прямо обнаружены.
Я говорил, что на кометах области, где происходит испарение, такие же тёмные, как и те, где испарение не происходит.
Ещё я говорил, что на кометах нет областей с альбедо, равным альбедо яркой области на Церере (т.е. >40%)
Опровержением моих слов, по правилам логики, является обратное утверждение – что на кометах области, из которых идёт испарение, намного светлее других и имеют альбедо не меньшее, чем альбедо яркого пятна Цереры.
Это неверно.
Нет, вы должны сначала обосновать свои слова, чтобы кому-то вдруг понадобилось их опровергать
Нет, это верно. Достаточно посмотреть на фото кометы Чурюмова-Герасименко и сравнить те области, откуда истекают джеты, с прочими областями.
Если бы вы действительно так считали, вы бы вообще не ввязались со мной в дискуссию здесь.
Дискуссии, как таковой, пока что и нет. Я лишь указываю на фактические ошибки в ваших рассуждениях.
