2011-05-28T17:07:36
Unsupported Windows version
Compiled with GCC 4.4.0
Qt runtime version: 4.7.1
Qt compilation version: 4.7.1
Addressing mode: 32-bit
Total memory: 2047 MB (unreliable)
Total virtual memory: 2047 MB (unreliable)
Physical memory in use: 38%
Processor speed: 2006 MHz
Processor name: Intel(R) Core(TM)2 CPU 4400 @ 2.00GHz
C:\Program Files\Stellarium\stellarium.exe
[ This is Stellarium 0.10.6.1 -
http://www.stellarium.org ]
[ Copyright (C) 2000-2010 Fabien Chereau et al ]
Writing log file to: "C:/Users/Àäìèíèñòðàòîð/AppData/Roaming/Stellarium/log.txt"
File search paths:
0 . "C:\Users\Àäìèíèñòðàòîð\AppData\Roaming\Stellarium"
1 . "."
Config file is: "C:\Users\Àäìèíèñòðàòîð\AppData\Roaming\Stellarium/config.ini"
OpenGL supported version: "1.1.0"
Qt GL paint engine is: "OpenGL"
Cache directory is: "C:\Users\Àäìèíèñòðàòîð\AppData\Local\stellarium\stellarium\cache"
Sky language is "ru"
Application language is "ru"
Loading Solar System data ...
Loaded 231 / 231 planet orbits from "C:\Users\Àäìèíèñòðàòîð\AppData\Roaming\Stellarium/data/ssystem.ini"
Loading star data ...
"Loading "./stars/default/stars_0_0v0_1.cat": 0_0v0_1; 5013"
"Loading "./stars/default/stars_1_0v0_1.cat": 1_0v0_1; 21999"
"Loading "./stars/default/stars_2_0v0_1.cat": 2_0v0_1; 151416"
"Loading "./stars/default/stars_3_1v0_0.cat": 3_1v0_0; 434064"
Finished loading star catalogue data, max_geodesic_level: 3
navigation/preset_sky_time is a double - treating as jday: 2.45151e+06
Loaded 10051 NGC records
Loading NGC name data ...
Loaded 222 / 222 NGC name records successfully
Loaded 88 / 88 constellation records successfully for culture "western"
Loaded 85 / 85 constellation art records successfully for culture "western"
Loaded 89 / 89 constellation names
Loading constellation boundary data ...
Loaded 782 constellation boundary segments
Loading star names from "./skycultures/western/star_names.fab"
Loaded 230 / 230 common star names
Loading star names from "./stars/default/name.fab"
Loaded 3215 / 4359 scientific star names
Creating GUI ...
Loaded plugin "AngleMeasure" .
AngleMeasure plugin - press control-A to toggle angle measure mode
Loaded plugin "Oculars" .
Ocular plugin - press Command-O to toggle eyepiece view mode. Press ALT-o for configuration.
Oculars::validateIniFile ocular.ini exists at: "C:\Users\Àäìèíèñòðàòîð\AppData\Roaming\Stellarium/modules/Oculars/ocular.ini" . Checking version...
Oculars::validateIniFile found existing ini file version 2
Loaded plugin "Satellites" .
Satellites::getJsonFileVersion() version from file: "0.6.4"
Satellites::init using satellite.json file: "C:\Users\Àäìèíèñòðàòîð\AppData\Roaming\Stellarium/modules/Satellites/satellites.json"
Loaded plugin "SolarSystemEditor" .
Using the ssystem.ini file that already exists in the user directory...
Loaded plugin "TimeZoneConfiguration" .
