Они просто о нем не знают
Они просто о нем не знают.
В "Британике" он есть.
А это про кого Ильф и Петров сказали, попробуй, догадайся
Цитата: alex_semenov от 18 Окт 2024 [16:31:16]Мы сомневаемся в Циолковском, они - нет. Они просто о нем не знают. Когда был научным сотрудником, читал много англо- и франкоязычной литературы по космонавтике. Ни разу не встретил упоминания.
Everything about fundamental spacecraft design revolves around the Tsiolkovsky rocket equation.Δv = Ve * ln[R]The variables are the velocity change required by the mission (Δv or delta-V), the propulsion system's exhaust velocity (Ve), and the spacecraft's mass ratio (R). Remember the mass ratio is the spacecraft's wet mass (mass fully loaded with propellant) divided by the dry mass (mass with empty propellant tanks).The point is you want as high a delta-V as you can possibly get. The higher the delta-V, the more types of missions the spacecraft will be able to perform. If the delta-V is too low the spacecraft will not be able to perform any useful missions at all.Looking at the equation, the two obvious ways of increasing the delta-V is to increase the exhaust velocity or increase the mass ratio. Or both. Turns out there are two more sneaky ways of dealing with the problem which we will get to in a moment.
To calculate the spacecraft's total DeltaV you can thank Konstantin Tsiolkovsky and the awsome Tsiolkovsky rocket equation. Sir Arthur C. Clarke called the most important equation in the whole of rocketry.
На самом деле, тебе просто завидно
Вы мало читали, мой друг.
