Есть ли кого-то поисковая карта с опорными звездами (постоянные и с известной яркостью)?
Нету ослаблений, подтверждающихся в других полосах.
May 19, 2017 | Tyler Ellis & Tabetha BoyajianWe have detected a dip in progress! Currently the star is approximately 2.5% fainter than it was a few days ago.Currently, we are organizing and cataloging dozens of observations from multiple observers worldwide. Planned responses include photometric observations in multiple bands, spectrometry, and more exotic observations such as polarimetry. We are also continuing the monitoring with the Las Cumbres telescopes at an increased cadence (probably three or four sequences every hour),Stay tuned for more news about this exciting event!
А это тогда что?
Ослабление на несколько сотых? Облако в высоких слоях атмосферы, не видимое невооруженным глазом, пролетело , вот тебе и ослабление яркости на две-три сотые. Правда не реальное, а фиктивное. Появилась случайная ошибка при калибровке пзс-снимков - вот тебе и ошибка фотометрии. По этой звезде имеет данные в VSX: 11.88 V (0.26)Kp, т.е. ослабление несколько десятых зв.величины. Кто может подтвердить ослабления яркости на две сотые в ту ночь?
14-inch Celestron Telescope at Tennessee State University / Fairborn Observatory V-band images taken on UT 2017 May 18 and 19 showed that Boyajian's Star has entered into a new dip. Photometry differential to many comparison stars in the field showed a drop from an offset of Delta-V = 0.65144 +/- 0.00125 mag (UT 2017 May 16 09:16) to Delta-V = 0.67415 +/- 0.00261 (UT 2017 May 19 06:08) - a drop of 0.02 mag. This is the largest and first clear dip seen in over a year of monitoring, and shows no sign of having yet reached a minimum
r'-band observations with the 1-m telescope at the Las Cumbres Observatory (LCO) in Maui show a 2% dip over two days from UT 2017 May 17 to 2017 May 19.
V-band observations by amateur astronomer Bruce Gary using a Meade LX200 GPS 14" with an SBIG ST-10XME CCD confirmed that Boyajian's Star had dimmed from V = 11.906 +/- 0.004 to V = 11.9244 +/- 0.0033 between UT 2017 May 14 and UT 2017 May 19 (an abrupt drop of 1.7%).
Последние сообщения перенесены в Необычные затмения в системе KIC 8462852.
LeMay, я думаю, саму тему надо оставить - как определённые результаты фотометрии этой звезды, а не бред про инопланетян ..
Черные вертикальные линии показывают положение резких падений блеска (больше 2% от яркости звезды).
Черные вертикальные линии это погрешность оценок блеска, т.е. +/- от точки на графике.
Откровенно не вижу ничего уникального в этой звезде.
Черным отметками обозначены измерения проекта ASAS, красными отметками - измерения телескопа Кеплер, синими отметками – измерения проекта ASAS-SN.
Коллеги, а чем она отличается от звезд типа R CrB ?
Цитата: vsf от 29 Авг 2017 [05:27:59]Черным отметками обозначены измерения проекта ASAS, красными отметками - измерения телескопа Кеплер, синими отметками – измерения проекта ASAS-SN.А где же наблюдения обзора SuperWASP?
