A A A A Автор Тема: Смотрим на солнечный парус  (Прочитано 21127 раз)
andrey.fedorov
« : 21 Июн 2005 [12:25:18] »
MISSION UPDATE
Private Solar Sail Spacecraft Set to Launch
For 8:00 p.m. EDT Thursday, June 16
A privately-built spacecraft designed to use the power of light to fly through space is poised to launch spaceward atop a converted intercontinental ballistic missile.
A Volna rocket will launch the Cosmos-1 spacecraft from a Russian Navy submarine on June 21 at 3:46 p.m. EDT (1946 GMT). The spacecraft was built for the Planetary Society, a space advocacy group based in Pasadena, California, to demonstrate the ability to deploy and use solar sails to propel spacecraft in low Earth orbit.
While not the first to unfurl a solar sail, Cosmos-1's mission will be the first to demonstrate the controlled use of solar sail in spaceflight, if successful. The spacecraft was built for the Planetary Society by the Russian aerospace company NPO Lavochkin with Moscow's Space Research Institute (IKI) overseeing its flight electonics and mission control software. A U.S.-built camera, from Malin Space Science Systems of San Diego, California, and a Russian camera will provide imaging during the spaceflight.
Cosmos-1 carries eight solar sail petals - each 47 feet (about 14 meters) long - which will be unfurled four at a time by inflating tubes along their sides with nitrogen gas. About one week of checkouts is planned. By rotating certain petals to face or turn away from the Sun, mission scientists hope to be able to control Cosmos-1's flight.
The spacecraft is designed to fly in a 497-mile (800-kilometer) Earth orbit before the sails are unfurled. A suborbital test of Cosmos-1 did launch successfully in 2001, but the spacecraft failed to separate from its booster and deploy its two-bladed sail.
http://www.space.com/missionlaunches/launches/next_launch.html
http://www.planetary.org/solarsail/watch/
Оффлайн zverolovlev
  • Подпись под аватаром
    • Сообщения от zverolovlev
    • Алексей Звероловлев ЖЖ
Re: Смотрим на солнечный парус
« Ответ #1 : 22 Июн 2005 [02:34:51] »
В новостях написано "не вышел на заданную орбиту"
Ё-маё!!! Что за день такой!!!  >:(
Оффлайн Karen
  • Благодарностей: 255
  • Янг, Карен
    • Сообщения от Karen
« Ответ #2 : 22 Июн 2005 [02:54:37] »
Последние новости от Planetary Society в 21:50 U.T., что всё пошел нормально включая три разделения ступеней. На 15 минут после старта получили сигнал от Петропавловска. Сигнал продолжал с течением 3 минута, и потом исчез. Ещё не знают если корабль на орбите, а просто выключен, или если есть серезная проблема. Надо ждать.
Оффлайн GNM
    • Сообщения от GNM
« Ответ #3 : 22 Июн 2005 [04:19:45] »
А я было подумал, что это шутка. Уж больно "космодром" выбран интересный!
Оффлайн Eisbrecher
  • Благодарностей: -1
  • Враг АстроФеста
    • Сообщения от Eisbrecher
« Ответ #4 : 22 Июн 2005 [08:43:11] »
21 июня 2005 года можно назвать" черным днем" для российской космонавтики. Две попытки запуска космических аппаратов и две неудачи. Запущенная поздно вечером с борта атомной подводной лодки ракета-носитель "Волна" с космическим аппаратом Cosnos-1 ("солнечный парус") также не смогла выполнить свою задачу и упала. По предварительной информации, произошло преждевременное отключение двигателя первой ступени. О месте падения ракеты пока не сообщается. К ее поискам приступили рано утром 22 июня
Прискорбно  :'(
angst?
andrey.fedorov
« Ответ #5 : 22 Июн 2005 [09:53:32] »
22.06.05 02:22 ИТАР-ТАСС
РОССИЯ-США-КОСМОС
Экспериментальный спутник "Космос-1" с "солнечным парусом" не выведен на заданную орбиту из-за остановки работы двигателя первой ступени ракеты-носителя "Волна". Об этом корр.ИТАР-ТАСС сообщили в штабе Северного флота. "Самопроизвольная остановка двигателя произошла на 83-й секунде полета. Экипаж атомной подводной лодки "Борисоглебск" отработал в штатном режиме", - отметил собеседник агентства.
По предварительным данным, полет ракеты-носителя "Волна", запущенной во вторник в 23:46 мск из акватории Баренцева моря с атомной подлодки "Борисоглебск", был прекращен из-за самопроизвольной остановки работы двигателя первой ступени. Об этом корр.ИТАР-ТАСС сообщили в "КБ им.Макеева", где была разработана эта конверсионная ракета.
"На 83-й секунде полета произошла самопроизвольная остановка работы двигателя 1-й ступени", - сообщил собеседник агентства. "Боевые ракеты на такой случай снабжены системой аварийного подрыва. Конверсионная "Волна" не имеет такой системы", - уточнил он.
Ракета "Волна" должна была вывести в космос российско-американский экспериментальный космический аппарат "Космос-1" с "солнечным парусом".
Ракета-носитель "Волна" создана Государственным ракетным центром "КБ имени академика Макеева" (г.Миасс, Челябинская область). Она представляет собой конверсионный вариант двухступенчатой жидкостной баллистической ракеты для подводных лодок РСМ-50. Конверсионная ракета отличается от базовой модели наличием дополнительного малогабаритного твердотопливного двигателя, обеспечивающего вывод малых космических аппаратов на околоземные орбиты.
Первая попытка отправить в космическое плавание "солнечный парусник" была предпринята в июле 2001 года, но оказалась неудачной. Космический аппарат не отделился от носителя и разрушился в плотных слоях атмосферы. Четыре года назад для запуска "Волны" также использовался "Борисоглебск".
anovikov
« Ответ #6 : 22 Июн 2005 [10:02:36] »
Что ж так не везет этому парусу!
Вывод: при расчете сценариев ядерной войны количество боеголовок с нашей стороны можно смело срезать раза в полтора. Потому что часть из них просто не долетит. Похоже ракеты начали сыпаться.
Осталось только разместить РСД для поражения стартовых комплексов и первый эшелон ПРО на территории Прибалтики, Украины, Турции, Средней Азии и Аляски и о проблеме России можно будет забыть... На что я искренне надеюсь т.к. распухание экономики на нефтяных деньгах уже достало - пора перекрывать краник...
andrey.fedorov
« Ответ #7 : 22 Июн 2005 [10:08:03] »
Точно. Если не в два :)
Оффлайн Белый мир
  • Пусть всегда будет Солнце !
    • Сообщения от Белый мир
« Ответ #8 : 22 Июн 2005 [13:15:55] »
Солнечный парус чебурахнулся  :) :) Ну может теперь Российское правительство перестанет заниматься прожектами типа "солнечный парус" и "секретные военные спутники" и займётся проблемами чахлой Российской экономики ? Хотя вряд ли. Это правительство, похоже, только на прожекты способно. Не летающие, к тому же. Значит надо ждать отставки прожектантов и прихода к власти хороших людей. Глядишь, тогда безумные НДС с ЕСН отменят .. Но это всё мечты.
Мир прекрасен
Оффлайн dmitryP
  • Благодарностей: 12
    • Сообщения от dmitryP
« Ответ #9 : 22 Июн 2005 [14:27:10] »
...может теперь Российское правительство перестанет заниматься прожектами типа "солнечный парус" и "секретные военные спутники" и займётся проблемами чахлой Российской экономики ?
Если Вы не в курсе, то "парус" делался в основном на штатовские деньги. Так что российская экономика тут только при том, что это еще один источник заработка для контор типа НПО им. Лавочкина. Заметим себе, что такие конторы поддерживать надо, т.к. "Лавочка" много чего для обороны делает.
Я уж не говорю про работу на перспективу. На "керосине" летать умеют хорошо. Но что будет через 10-15-20 лет? Про это тоже надо думать. Вы думаете зря штатники во всю строят всякую "дичь" типа ионных приводов, парусов и т.п.?
andrey.fedorov
« Ответ #10 : 22 Июн 2005 [16:58:23] »
Кстати, завтра вроде "Зенит" должны запустить, а 25го - "Протон". Ой что будет...
Оффлайн Белый мир
« Ответ #11 : 22 Июн 2005 [17:15:39] »
dmitryP:  Если Вы не в курсе, то "парус" делался в основном на штатовские деньги.
Наверно российских капиталовложений там было тоже не мало. иначе бы Американцы
запустили этот космический аппарат со своего космодрома.
dmitryP:  Я уж не говорю про работу на перспективу. На "керосине" летать умеют хорошо.
Если сегодня зайти на рынок бытовой техники, то там не найти ни одной цифровой камеры,
ни одного сотового телефона, ни одной микроволновой печи, видеокамеры или компьютера
российского производства. Это значит, что промышленность в россии не работает. Зато наше
государство активно инвестирует в паруса и секретные никому не нужные военные спутники.
А живёт за счёт торговли природными ресурсами. Если так дело пойдёт дальше, то через 15 лет
природные запасы нефти и газа истощатся и Россия превратится в государство, которое будет
просить помощи у Зимбабве и Бангладеш. Зато будет о чём вспомнить: сколько ядерных могильников
понастроили, сколько парусов и секретных военных спутников запустили, просто жуть. Надо
на следующий спутник собрать всё российское правительство и запустит его. В подарок
марсианам. Пусть эти гуманоиды на марсе демократию строят. Только через 15 лет марсиане
подарок вернут. Такого "добра" везде полно, как грязи.
Мир прекрасен
Оффлайн deymos34
  • Благодарностей: 8
    • Сообщения от deymos34
    • Личная страничка Рената Якубова
« Ответ #12 : 22 Июн 2005 [18:07:45] »
Деньги американские (негосударственные, кстати, да и небольшие, около 4 лямов $), технологии наши. Чем плохо?
Да работает российская промышленность! Экспорт сырья - это от силы 30 % ВВП. А на космосе уже  сейчас можно неплохо зарабатывать. Кстати, есть и отечественная бытовая техника. Взять тот же Roverbook (правда, сколько в его продукции импортных деталей ;D). Вообще, что касается компьютеров, собираются они практически все в России.
Оффлайн Вячеслав
  • Благодарностей: 10
    • Сообщения от Вячеслав
    • Сказки Енота
« Ответ #13 : 22 Июн 2005 [18:10:21] »
 ;D  ;D  ;D
Никогда не задумывались, КАК и ИЗ ЧЕГО их собирают?
andrey.fedorov
« Ответ #14 : 22 Июн 2005 [19:16:24] »
Смеялсо :) Вы бы еще завод BMW в Калиниграде привели как пример роста нашей промышленности :)
Оффлайн Olweg
  • Благодарностей: 466
    • Сообщения от Olweg
« Ответ #15 : 22 Июн 2005 [19:56:36] »
Ну да, лучше дерьмо, но полностью свое
Оффлайн zverolovlev
« Ответ #16 : 22 Июн 2005 [22:26:20] »
По теме: а известно что-нибудь, вышел ли аппарат на хоть какую-нибудь орбиту?
Оффлайн Белый мир
« Ответ #17 : 22 Июн 2005 [22:34:53] »
Зачем делать дерьмо ? Можно сделать качественную и удобную технику и продавать
её по всему миру. Но не дадут. В стране процветает теневая экономика, факты
нарушения закона встречаются на каждом шагу, граждане России абсолютно
не защищены юридически. Бесплатных юридических консультаций, работающих
на постоянной основе для всех слоёв населения и оказывающих качественные
юридические услуги нет. Не существует. Российский автопром доживает последние
деньки, поизводство отечественных автомобилей сворачивается. Это всё правительство
беспокоит ? Нисколько. Но наше правительство очень обеспокоено, например, тем, как будут
чувствовать себя улитки в космосе. Для исследования этой проблемы в космос отправляют баслосновно
дорогие космические аппараты, потом космических улиток спускают на Землю и ищут на вертолётах.
Это важно. США не позволяет себе столь роскошного финансирования космических исследований.
Там деньги считают. А в России допустили до власти идиотов, которые не знают, куда гроши,
которые каким-то чудом попадают в государственную казну, запулить. На исследование космического
паруса или на возведение ядерного могильника ? В связи с благоприятными ценами на нефть
возросли и поступления в государственную казну. Соотвественно, возрос интерес правительства к самочуствию
улиток в космическом пространстве. Запуски уже чуть не каждый день намечаются. Поставь
на "верх" человека, который хоть немного бы думал о России, исследования космического
пространства в нашей стране был бы свёрнуты на несколько десятилетий как минимум. Милиционеры
получают нищенскую зарплату и побираются по коммерческим палаткам, о каких улитках
и парусах может идти речь ? Американцы не дураки, поставили нам идотов в руководство, подкинули баксов
немного, путь паруса запускают. Чем дураче в России правительство, тем лучше себя чувствует Америка.
Мир прекрасен
v.bobkin
« Ответ #18 : 23 Июн 2005 [01:13:01] »
Кажется, у Железнякова читал, что ни один старт не обходится без благословения священника. А был ли поп на ПЛ?  ;D
ЗЫ Но, если серьезно, то жаль - "порвали парус". Это уже был третий по-счету или все разные проекты?
Оффлайн Karen
  • Янг, Карен
« Ответ #19 : 23 Июн 2005 [03:16:38] »
http://www.spacedaily.com/news/solarsails-05g.html
Согласно Planetary Society, Космос 1 вероятно достиг орбиту, хотя не правильную орбиту. Будет ли он полезным или нет, ещё не знают.
На что касается "ряд" аварий (точно "два"), не хорошое положение, но помню что несколько лет назад были ряд неудач спутниковых стартов на стороне НАСА. Очень напряженным, но не смертельным, если не остановят финансирование. В этом случае, вероятно нет связи между стартой Молнии-М и Космос 1--просто совпадение. Космический полет--пилотируемый или нет, ещё опасное дело. Аварии случаются, и несмотря на наших лучших попыткой, будут случаться в будущем. Важно найти причину, но это не причина "оставаться дома" и ничего больше не сделать в космосе.
