Покрытия на март https://disk.yandex.ru/d/b7GTV7naem46Ew?w=1 .
ASTEROIDAL OCCULTATION - REPORT FORM +------------------------------+ +------------------------------+ | EAON | | IOTA/ES | | | | INTERNATIONAL OCCULTATION | | EUROPEAN ASTEROIDAL | | TIMING ASSOCIATION | | OCCULTATION NETWORK | | EUROPEAN SECTION | +------------------------------+ +------------------------------+1 DATE: 2021/03/02 STAR: UCAC4 589-045543 ASTEROID: (362) Havnia2 OBSERVER: Michel Turchenko EAON Abbr: E-mail: mturchenko@yandex.ru Address: 357601, Russian Federation, Stavropol region, Yessentuki, Il'inskaya 223 OBSERVING STATION: Nearest city: Kislovodsk (RU) Station: Longitude (DD MM SS.s): E 42°40'15.97" Latitude (DD MM SS.s): N 43°44'15.84" Altitude (m): 2078 Datum: WGS84 Single station: +----------------------------+4 TIMING OF EVENTS: | | | EVENT REPORTED: POSITIVE | | | +----------------------------+ Event code S: observation Start I: Interruption start D: Disappearance J: Interruption end R: Reappearance B: Blink F: Flash E: observation End O: Other (specify) Abbreviations P.E.: Personal Equation = reaction time (for visual obs) Acc.: Accuracy (overall accuracy of the given time) Comments Event Time (UT) P.E. Acc. Code HH:MM:SS.ss S.ss S.ss S - 20:13:16 - - : D - 20:15:38.699 - +/-0.120 : R - 20:15:48.322 - +/-0.120 : E - 20:17:34 - - : Duration : 9.623 +/-0.24 Mid-event : 20:15:43.511 5 TELESCOPE: Type: Newton Aperture: 150 mm Magnification: prime focus 750 mm Mount: Equatorial Motor drive: Yes6 TIMING & RECORDING: Time source: Reference time signals from GPS-USB Sensor: ZWO ASI385MC Recording: Notebook Lenovo ThinkPad T480 Time insertion (specify): Recording a 1PPS light flash and a GPS-synchronized system time stamp on a video Event insertion (specify):7 OBSERVING CONDITIONS: Atmospheric transparency: GOOD Wind: Weak 6 – 10 km/h Temperature: -6°C Star image stability: GOOD Minor planet visible: Yes8 ADDITIONAL COMMENTS: Video rate is 5 fps. The time stamp on the video corresponds to the end of the exposure of the frame. To get the time of the event, the difference between the system time and the time obtained from GPS was added and half of the frame duration was subtracted, that is, the time of the event was tied to the middle of the frame duration. The difference between the system time and the GPS time was determined with an accuracy of 2-4 ms. with 1PPS light flashes recorded on video. Wherein, the time difference was determined from those frames where the onset of the flash occurred at the beginning of the frame exposure. Such measurements were taken before and after occultation. The difference in system time and GPS time in the moment of occultation was calculated from these measurements. The duration of the coverage was measured between the approximate middle of the fall and rise of the signal fronts from the star.
Так что наблюдать можно на пределе технических возможностей.Да ещё нужно попасть в полосу покрытия шириной 20 метров.
В США наблюдали покрытие 300-метровым Апофисом.
