Цитата: Denk36 от 13 Авг 2014 [09:17:29]Кстати, на виндовой 13 версии тоже fps упал в 3 раза.Логи?
Почему при поиске скажем Луны или Юпитера первым результатом выходит Гидра (луна) или Призрак Юпитера ?
По началу фразы не нравилось, по подстроке опять не нравится
2014-08-13T21:04:07Unsupported Windows versionCompiled using MinGW GCC 4.8.0Qt runtime version: 5.2.1Qt compilation version: 5.2.1Addressing mode: 32-bitTotal memory: 4095 MB (unreliable)Total virtual memory: 2047 MB (unreliable)Physical memory in use: 37%Processor speed: 3093 MHzProcessor name: Intel(R) Core(TM) i5-3350P CPU @ 3.10GHzProcessor speed: 3093 MHzProcessor name: Intel(R) Core(TM) i5-3350P CPU @ 3.10GHzProcessor speed: 3093 MHzProcessor name: Intel(R) Core(TM) i5-3350P CPU @ 3.10GHzProcessor speed: 3093 MHzProcessor name: Intel(R) Core(TM) i5-3350P CPU @ 3.10GHzC:\Program Files (x86)\Stellarium\stellarium.exe ------------------------------------------------------- [ This is Stellarium 0.13.0 - http://www.stellarium.org ] [ Copyright (C) 2000-2014 Fabien Chereau et al ] ------------------------------------------------------- Writing log file to: "C:\Users\User\AppData\Roaming\Stellarium\log.txt" File search paths: 0 . "C:\Users\User\AppData\Roaming\Stellarium" 1 . "." Config file is: "C:\Users\User\AppData\Roaming\Stellarium\config.ini" OpenGL versions supported: "1.1, 1.2, 1.3, 1.4, 1.5, 2.0, 2.1, 3.0, 3.1, 3.2, 3.3, 4.0, 4.1, 4.2, 4.3" Driver version string: "4.4.0" GL vendor is "NVIDIA Corporation" GL renderer is "GeForce GT 640/PCIe/SSE2" Cache directory is: "C:\Users\User\AppData\Local\stellarium\stellarium\cache" Sky language is "ru_RU" Application language is "ru_RU" Loading Solar System data ... Loading star data ... "Loading ".\stars\default\stars_0_0v0_5.cat": 0_0v0_2; 4963" "Loading ".\stars\default\stars_1_0v0_5.cat": 1_0v0_2; 21598" "Loading ".\stars\default\stars_2_0v0_5.cat": 2_0v0_2; 150090" "Loading ".\stars\default\stars_3_1v0_3.cat": 3_1v0_3; 428466" "Loading "C:\Users\User\AppData\Roaming\Stellarium\stars\default\stars_4_1v0_1.cat": 4_1v0_3; 1702042" "Loading "C:\Users\User\AppData\Roaming\Stellarium\stars\default\stars_5_2v0_1.cat": 5_2v0_1; 7083058" "Loading "C:\Users\User\AppData\Roaming\Stellarium\stars\default\stars_6_2v0_1.cat": 6_2v0_1; 24670782" "Loading "C:\Users\User\AppData\Roaming\Stellarium\stars\default\stars_7_2v0_1.cat": 7_2v0_1; 50733321" Finished loading star catalogue data, max_geodesic_level: 7 navigation/preset_sky_time is a double - treating as jday: 2.45151e+06 Loaded 10051 NGC records Loading NGC name data ... Loaded 416 / 416 NGC name records successfully Loading star names from ".\skycultures\western\star_names.fab" Loaded 237 / 237 common star names Loading star names from ".\stars\default\name.fab" Loaded 4359 / 4359 scientific star names Loading variable stars from ".\stars\default\gcvs_hip_part.dat" Loaded 6886 / 6886 variable stars Loaded 88 / 88 constellation records successfully for culture "western" Loaded 85 / 85 constellation art records successfully for culture "western" Loaded 89 / 89 constellation names Loading constellation boundary data ... Loaded 782 constellation boundary segments Intializing basic GL shaders... Creating GUI ... Loaded plugin "AngleMeasure" Loaded plugin "CompassMarks" Loaded plugin "MeteorShowers" MeteorShowers: loading catalog file: "C:\Users\User\AppData\Roaming\Stellarium\modules\MeteorShowers\showers.json" Loaded plugin "Satellites" Satellites: loading catalog file: "C:\Users\User\AppData\Roaming\Stellarium\modules\Satellites\satellites.json" Unable to find module called "TimeZoneConfiguration" Loaded plugin "TimeZoneConfiguration" Intializing planets GL shaders...
А у меня эта версия все же довольно нестабильна. Вылетает чаще всего при попытке приблизить Луну: "Прекращена работа программы "stellarium.exe"
Цитата: Александр Вольф от 13 Авг 2014 [09:48:55]Цитата: Denk36 от 13 Авг 2014 [09:17:29]Кстати, на виндовой 13 версии тоже fps упал в 3 раза.Логи?Вечером выложу, сейчас на работе.
Вот лог
Цитата: Denk36 от 13 Авг 2014 [23:36:48]Вот логТак, стоп! А в каком состоянии FPS измерялся? Когда в планетарии что-то активно делается или когда просто запустили и он работает себе потихоньку?
Цитата: Александр Вольф от 13 Авг 2014 [23:49:31]Цитата: Denk36 от 13 Авг 2014 [23:36:48]Вот логТак, стоп! А в каком состоянии FPS измерялся? Когда в планетарии что-то активно делается или когда просто запустили и он работает себе потихоньку?Сначала просто открыл стеллариум, fps низкий - 2-3. Потом подвигал мышью небо, приближал-удалял, больше 12fps не поднялся, в какой-то момент вообще замерз, через несколько секунд отвис. На версии 12.4 fps достигал 30-40 спокойно и даже больше.Дрова на видюхе от ноября 2013 года, попробую обновить.
Цитата: Denk36 от 13 Авг 2014 [23:52:50]Цитата: Александр Вольф от 13 Авг 2014 [23:49:31]Цитата: Denk36 от 13 Авг 2014 [23:36:48]Вот логТак, стоп! А в каком состоянии FPS измерялся? Когда в планетарии что-то активно делается или когда просто запустили и он работает себе потихоньку?Сначала просто открыл стеллариум, fps низкий - 2-3. Потом подвигал мышью небо, приближал-удалял, больше 12fps не поднялся, в какой-то момент вообще замерз, через несколько секунд отвис. На версии 12.4 fps достигал 30-40 спокойно и даже больше.Дрова на видюхе от ноября 2013 года, попробую обновить.А сколько комет в наличии имеется?
Все, какие есть. Теперь понятно. Но на 12.4 тоже был закачен весь каталог.
Цитата: Denk36 от 13 Авг 2014 [23:58:37]Все, какие есть. Теперь понятно. Но на 12.4 тоже был закачен весь каталог.В этой версии для всех комет рассчитываются комы и хвосты (оба типа), что существенно нагружает планетарий... к тому же забыли оптимизировать кое-какие участки. В версии 0.13.1 будет исправления этой напасти.
Для начала Вам придется выяснить что такое лунное и что такое солнечное затмение.
Все правильно.
и глюк со шрифтами (шрифт правильный, но внизу - "рваный")... Ставлю назад 0.12.4
А я удалил уже инсталяху предыдущей версии, где теперь взять ее, на оффсайте кроме последней вроде нету.
Ставлю назад 0.12.4
