With the sanction of the Government, therefore, I planned an instrument, of which the essential part is, that the wholetube, from the lower surface of the object-glass to a plane glass closing thelower end of the tube, is filled with water, the length of the column of waterbeing 35’3 inches. The curvatures of the surfaces of the two lenses constituting the object-glass, adapted, in conjunction with the water, to correctspherical and chromatic aberration, were investigated by myself and verifiedby my friend Mr. Stone (now Astronomer at the Cape Observatory).
The micrometer is constructed on a plan arranged by myself, by which thedouble observation in reversed positions of the instrument can be madewith great ease. The reference to the vertical is given by two spirit-levels,both to be read at every single observation. The work of construction wasintrusted to Mr. James Simms, who carried it out with great ability.Distilled water was supplied by H. W. Chisholm, Esq., Warden ofStandards.
Я не астроном, пытаюсь разобраться в устройстве инструмента Эйри, и его методике наблюдений.
There is only one point in this investigation upon which a doubt can be suggested as possible, namely the evaluation of the micrometer-scale. It was thus conducted:—The micrometer-plate contains 26 wires, and the fixed part of the instrument contains 25 crosses, each interval being nearly 256". With this arrangement every wire-interval is measured with great ease, and the whole series of 25 intervals is accurately obtained in terms of the micrometer. By placing the instrument in a proper position, the same intervals are obtained in time of the star’s transit, which is easily converted into arc. The comparison of these gives the value of micrometer-divisions which has been employed. The following verification, of somewhat inferior accuracy, has been made by measures of the instrument. It appears that the ray of light passes through 0 9 inch of glass, 35*3 inches of water, and 0*8 inch of air, nearly (the measure of the last being slightly uncertain). Remarking that thedividing surfaces are horizontal and plane, it is easily seen that the micrometer-scale ought to be such as is due to an air-telescope whose length ininches = 0.9/1.6 + 35.3/1.336+0.8 = 27.8 inches. And from this, with observation of transit of the star, it was found that the measure of 25 intervals of wiresought to be 0'8693 inch: as measured with a pair of compasses, it was found sometimes 0'871, sometimes 0'875. The agreement is fully as closeas can be expected from the rudeness of the operation, and shows distinctly that there can be no error of principle in the method of evaluing themicrometer-scale
Ответ простой:Движение Земли через Мировой Эфир должно вызвать изменение показателя преломленияводы, заполняющей телескоп, это изменение можно обнаружить измеряя аберрацию света.
А мне вот стало интересно, зачем не-астроному работа полуторавековой давности.
Как устроен зенит-телескоп и какие бывают микрометры и как ими измеряют ,про всё это у акад. С.Н Блажко в Курсе ПрактическойАстрономии.
И тогда Эйри использовал большой гринвичский телескоп, заполнив его внутреннее пространство водой
Конечно, точность 0,01" недостижима, реально, при соблюдении всех условий наблюдения, 0,1"
По-видимому, речь идет об этом телескопе http://articles.adsabs.harvard.edu//full/1856GOAMM..16F...1A/0000868.000.html
поскольку на дно трубы заливалась ртуть, используемая в конструкции телескопа качестве плоского зеркала.
Ну, залили бы стеклом.
Вот кратенько про суть и цели этого эксперимента .Опыт Эйри по измерению звездной аберрации при наблюдении через телескоп, заполненный водойhttp://novmysl.ru/SpecialRelativity/Airy_aberration.html
Чтобы внести порядок в исследования, Эйри задействовал Большой гринвичский телескоп и заполнил его внутреннее пространство водой.
Я уже как будто понял, почему Эйри указывает зенитное расстояние с точностью до 0.01". Это значение не прямо измеренное, а результат вычислений.
Кто-то же пустил эту байку гулять.
занырните поглубже в океян с телескопом
