A A A A Автор Тема: За окуляры замолвите слово( FMC 82град)  (Прочитано 5353 раз)
Оффлайн Владимир Николаевич
  • Благодарностей: 453
Re: За окуляры замолвите слово( FMC 82град)
« Ответ #40 : 08 Мар 2010 [08:23:02] »
На данный момент больше всего сведений о данном окуляре Вам даст вот это описание и работа со ссылками
http://store.explorescientific.com/82degreeseries30mmeyepiece.aspx
http://explorescientific.com/eyepieces/index.html
http://www.joctech.com/newweb/html-E/telescopes/eyepieces%201.html
http://www.joctech.com/newweb/html-E/introduce.html
JOC owns the five valued brands of Maxvision, Smart PC, Skywalker, Explore and Observer in China, and two famous brands of Bresser and Explore scientific in oversea market
Ну а что Брессер это есть Meade, а JOC это Jinghua обьяснять надеюсь не нужно ;).
The Explore Scientific 82° Series Eyepieces are optimized to produce high contrast, high resolution, and superior flat field characteristics.
All internal surfaces of the eyepiece barrel are flat black, as well as the edges of the lenses themselves, the fully multi-coated to minimize the scattering of light within the lenses.
The Explore Scientific 82° Series Eyepieces provide a huge field-of-view and long eye relief by using advanced computer design, combinations of low dispersion and high refractive index optical glasses.
Precision machined metal lens barrels that maintain the perfect alignment of the optical train for years of rugged use in the field.
This model is a Explore Scientific 82° Series Eyepieces - 14mm focal length, 1.25" barrel diameter with 15mm of eye relief, in a 7 element - 4 group design that weighs 11.8 oz oz.
About Explore Scientific 82° Series Extreme Wide Field Eyepieces
Using advanced computer design, combinations of low dispersion and high refractive index optical glasses, and durable multilayer deposition coatings, Explore Scientific 82° Series extreme wide field eyepieces are optimized to produce high contrast, high resolution, and superior flat field characteristics.
The visual effect of these eyepieces with their long eye-relief and their 82° apparent field is truly a full-immersion experience. Your eye is relaxed, allowing you to easily use the "averted vision" technique to study faint details across a huge field-of-view. Just check out this animation of how Explore Scientific Eyepieces field of view works and read about how Scott Roberts uses them:
"I now use the 82° Series eyepieces for most of my deep sky work at the telescope. I love the way that objects like M31 in Andromeda, the Orion Nebula, distant galaxies, and beautiful star clusters stretch across the huge field of these eyepieces. I feel more connected with the universe at large and as I study the treasure of stars in my eyepiece I am reminded of the distances and age of the cosmos and the constant discoveries that are being made by professional and amateur astronomers alike.
You can see from the illustration above that an eyepiece with a larger apparent field of view (AFOV) will produce a larger true field of view (TFOV) if we are comparing different eyepiece designs of the same focal length. Large apparent field eyepieces give you what I call "full- immersion" viewing. With eyepieces that have small apparent fields (like Kellner ("K"), Modified Achromatic ("MA"), Orthoscopic ("OR"), or Huygens ("H") designs) if the eypieces are of good optical quality, the resolution, contrast, magnification, and sharpness will be there, but the observer tends to be more "removed" from the experience of observing the object. You feel like you are looking down a dark tunnel to see the object at the end of the eyepiece, and your eye tends to strain a little as you lock your eye straight down the eyepiece. In visual astronomy, the harder you try to look as you strain your eye, the less you see.
But when you use eyepieces of larger apparent field, you have a much wider visual angle to scan your eye across the image inside the eyepiece. By scanning your eye from edge to edge you can more comfortably and naturally look into the eyepiece, and as you relax your eye, you begin to see finer and fainter details. This "immerses" you into visual experience of astronomy. The experience for many who first use extreme wide angle eyepieces like the 82° Series is often quite overwhelming as they start to really connect with the universe. The cost of such eyepieces is generally more, but experienced observers often feel the expense is worth it.
To calculate the true field-of-view with any eyepiece, first calculate the magnification the eyepiece is producing by dividing the telescope's focal length by the eyepiece's focal length. Then divide the apparent field of view of the eyepiece by the magnification. This will give you a number in degrees of the actual section of the sky that you are seeing through the eyepiece, the true field of view." -- Scott Roberts
Each eyepiece is meticulously assembled into precision machined metal lens barrels that maintain the perfect alignment of the optical train for years of rugged use in the field. The 82° Series eyepieces come with a twist-up rubber eye-guard that raise to the desired height for the comfort of the observer, and as experienced astronomers know, eye comfort is critical when trying to observe at the visual limits of the telescope. To keep internal reflections to a minimum, all internal surfaces of the eyepiece barrel are flat black, as well as the edges of the lenses themselves to minimize the scattering of light within the lenses themselves.
In today's modern telescope industry there are many fine companies to choose from manufacturing top quality eyepieces. Explore Scientific invites direct side-by-side comparison with any other eyepiece of similar design, and they back their eyepieces with an exclusive Five Year Limited Warranty. (Limited Warranty is one year, extended to five years when product is registered within 60 days of purchase.) We think that you will find Explore Scientific eyepieces rank among the finest obtainable and represent an outstanding value.
Explore Scientific Product Number: EP8214
« Последнее редактирование: 08 Мар 2010 [09:25:26] от Владимир Николаевич »
Оффлайн хиусАвтор темы
    • Сообщения от хиус
« Ответ #41 : 08 Мар 2010 [09:07:59] »
Большое спасибо за информацию.
В действительности всё совершенно иначе, чем на самом деле.(А. Сент-Экзюпери)
http://astrovrn.4adm.ru/ Воронежцы присоединяйтесь. Наш астрофорум.
Оффлайн Vkolos
  • Благодарностей: 20
    • Сообщения от Vkolos
« Ответ #42 : 31 Окт 2010 [23:32:56] »
Приобрел недавно FMC  24mm 82гр. Первые впечатления весьма положительные. Пробовал на SW Dob 254 1200 и SW EQ 66. Очень резкий и контрастный по всему полю. Заметный хроматизм 3-4 градуса по краю поля, дальше абсолютно чисто. Для моих телескопов кома-корректор и флатнер, соответственно, явно не помешали бы.
 Из недостатков:
-вынос  невелик, глаз почти в упор к линзе.  При смещении глаза от оптической оси часть поля резко пропадает.  Нельзя сказать, что это сильно мешает, просто надо привыкнуть.
-лампочки фонарей дают заметные блики, Юпитер тоже имеет зеленоватого двойника. Звезды двойников не имеют.
- много металла, мало резины. На холоде несколько дискомфортно.
SW 254 1200 Retractable на EQ6
Онлайн kup
  • Благодарностей: 519
    • Сообщения от kup
« Ответ #43 : 01 Ноя 2010 [14:14:00] »
Это можно было сказать сразу, судя по малому диаметру глазной линзы. Чтобы глазу были доступны все 82 градуса его надо подвинуть к линзе близко-близко.  Но для владельцев ортоскопиков, кайфующим с  2-3 мм выносом этот окуляр должен показаться райской штучкой, особенно на морозе без резинового наглазника.
Оффлайн Rybak Aleksey
  • Благодарностей: 273
  • I can see for miles and miles and miles and miles
    • Сообщения от Rybak Aleksey
« Ответ #44 : 01 Ноя 2010 [21:24:07] »
Приобрел недавно FMC  24mm 82гр... Из недостатков:
Вы наглазник крутить пробовали? Вынос там регулируемый где-то до 15 мм. Про хроматизм - непонятно. Описанный же Вами эффект "пропадания" изображения (blackout) я не замечал, поскольку, как говорил Эрнест, он в основном проявляется при дневных наблюдениях. На Юпитер в свой экземпляр смотрел прошлой ночью (телескоп - DS 102/714 ED, данный окуляр использовал в качестве обзорного), никакого двойника не заметил.  От фонарей блики есть, но у меня в центре Москвы это, имхо, естественно.
Я наживляю мой крючок трепещущей звездой...
https://astronomy.ru/forum/index.php/topic,21284.0.html
Оффлайн Vkolos
« Ответ #45 : 01 Ноя 2010 [22:11:10] »
Пробовал. Качество по краям поля падает довольно резко. Вынос 5 мм - мой оптимум.
Юпитер бликует однозначно и очень заметно. Но я смотрел на него в 10 дюймов и яркость его соответственно выше. Блик пропадает когда Юп точно по центру поля. Эффект "blackout" наблюдаю и днем и ночью. Причем днем он моргает цветом и сходен с "сусликами" на плазмах первых поколений и DLP-проекторах, если смотреть на них периферийным зрением. Хроматизм по самому краю тоже вижу четко, у Эрнеста это объясняется влиянием полевой диафрагмой. Но, что то далеко она влияет.  Возможно это особенности моего экземпляра или зрения.
Несмотря на эти недостатки, окуляр мне нравиться. Все эти дефекты можно простить за выдающюся резкость и широке поле.
Оффлайн zlyden
  • Благодарностей: 72
  • Сергей Ларионов
    • Сообщения от zlyden
    • разговоры об астрономии
« Ответ #46 : 01 Ноя 2010 [22:17:36] »
Это видимо остатки Explore Sceintific, и не факт что все окуляры одинаково хорошие. Не зря они новый дизайн сделали, таких больше нет.
« Ответ #47 : 01 Ноя 2010 [22:46:46] »
Причем эти старые остатки они распродали задешево. 4,7 и 6,7 мм на ОПТКОРПе я купил за 99 и сто с небольшим долларов. Кстати, ES 6,7 мм недавно сравнивали с аналогичным Мead'ом, так они - как родные братья, только раскраска разная. Даже крышечки одинаково хреново держатся.
« Ответ #48 : 02 Ноя 2010 [18:23:49] »
Шутник! Когда эти окуляры в Россию приехали Эксплорер Саентифик их только выставил в Америке... ;D Да и красных у Эксплорера никогда не было .
Сейчас все покончалось, осталась еще по паре 24-к и 30-к
    https://astronom.ru/vcd-207/catalog.html
« Последнее редактирование: 02 Ноя 2010 [18:30:11] от Владимир Николаевич »
Оффлайн zlyden
  • Сергей Ларионов
« Ответ #49 : 02 Ноя 2010 [18:37:09] »
Да их уже и не будет, а эти окуляры у Эксплорера уже давно, вы ошибаетесь, остатки из этой серии по 99 баксов распродавали, это вы шутник. А цвет ни на что не влияет, о чем говорит снимок ЧЕРНОГО (как у Explore) окуляра в магазине звездочета.
