Features:Sturdy case is custom laser-cut and sized for easy use with anyone's hand, bare-handed or glovedCustom Keypad is waterproof and features tactile keys so you can feel when a key has been pressedKeypad is designed with a standard PC numeric key layout with dedicated Search keysFiber-optic backlighting provides even illumination of all the keys and is adjustable for all conditions8 Gb of high-speed flash storage provides almost unlimited storageFast 32 bit CPU allows for quick response and multi-level searchesBuilt-in USB to Serial converter allows connection to the mount using only a USB portOptional GPS integrates seamlessly into the controller's softwareIdentify command tells you the name of the object in the eyepieceLocations can include horizon information allowing the AHC to select objects that are actually, not just theoretically visibleA separate catalog can be loaded with a users favorites, right from the keypad during an observing session.The Favorites catalogs can be saved by location and upto 5 different users can have their own separate set of favorites catalogsSearches thru catalogs can be performed on multiple criteria, and be performed with just the press of one buttonResults from the previous sessions can be remembered so that each new search doesnʼt require the user to scroll through objects he has already seenThe hardware and software design is open-ended, allowing the AHC to keep up with the latest trends in Astronomy and to be compatible with future Takahashi mountsSpecifications:Custom Laser-cut Acrylic case with silicon surroundSize: 7.7” x 4.7” x 1.5” (largest dimensions)Waterproof membrane keypad with tactile keys and variable actuation pressureRed Fiber optic keypad backlighting - Adjustable brightness4 line by 20 character display with adjustable red backlightingUSB input port for connection to the PC. Internal USB to serial converterStd 9 pin serial port for connection to the mountIlluminated one-touch power switch12-24V DC locking power connectorFlash Disk Card slotInternal connector for optional GPSWeight - 18.5 ozWarranty: Full 3-Year Parts and Labor
Дизайн, мягко говоря, спорный.
Т.е. FSQ-106EDX4 будет продаваться по прошлогодней цене в 5000$ ?
FSQ106EDX4 OTA - 6845 евро.
Цитата: Владимир Николаевич от 20 Окт 2020 [22:23:11]FSQ106EDX4 OTA - 6845 евро.
