A A A A Автор Тема: Астрономический альманах на PC  (Прочитано 7671 раз)
khomutov
Коллеги,
лет 8 пользуюсь интерактивным программным пакетом USNO (usno.exe и т.д.). Очень грамотно сделан (под DOS), точно считает, большой набор функций.
Не знаете, имеется ли сейчас его продолжение (м.б. уже под Windows, с расширенным сервисом, новый каталог и пр.)?
Сергей
Pietro
Re: Астрономический альманах на PC
« Ответ #1 : 02 Ноя 2001 [12:18:50] »
Если Вы про MICA 1990-2005 то похоже что нет, но может что-то и готовится.
khomutov
« Ответ #2 : 02 Ноя 2001 [12:31:41] »
Это вот что (заставка):
U. S. Naval Observatory
Nautical Almanac Office
Interactive Computer Ephemeris
Version 0.50
Сергей
Pietro
« Ответ #3 : 02 Ноя 2001 [14:17:01] »
Это значит, что у Вас ICE 0.5.  Существует обновленная версия ICE 0.51.  ICE больше не поддерживается USNO:
Interactive Computer Ephemeris (ICE)
(Discontinued)
ICE, the Interactive Computer Ephemeris, is a computer almanac program for PCs that was developed at the Naval Observatory in the late 1980s. It was essentially a version of the then-popular Floppy Almanac that provided data for extended periods of time. A "beta" version (ICE version 0.5) was tested by a group of users and very few problems were encountered. However, in 1990, for administrative reasons, it was decided not to continue development of the product. The known problems were fixed and a final version of the software (ICE version 0.51) was produced and made available to those users who had tested version 0.5. At that time, those users were notified that further development, distribution, and support of the product by the Naval Observatory would cease.
Therefore, ICE is not now distributed by the U.S. Naval Observatory. The Naval Observatory does not provide technical support for the product, nor does it warrant it in any way. However, because of its history, the program is in the public domain and is available through commercial and other sources. The Naval Observatory does not have any connection to or control over these sources. Apparently ICE versions 0.5 and 0.51 are both available; version 0.51 is the better of the two, although most users will not encounter any differences. If you have obtained ICE version 0.5 from a commercial or other source, and wish to obtain version 0.51, you should contact your source.
If you need an accurate computer-based almanac from the Naval Observatory, you should consider obtaining MICA, the Multiyear Interactive Computer Almanac. MICA has a much more modern user interface than does ICE, and provides a wider range of tabulations. MICA is available for both PCs and Macintosh systems.
На смену ICE пришла MICA:
Она не бесплатная и продается в Willman-Bell:
http://www.willbell.com/almanacs/almanac_mica.htm
Достоинства: основана на JPL DE200/LE200.  Недостатки: под DOS; всего на 15 лет.
Из того, что MICA дает эфемериды только до 2005, я делаю вывод, что вскоре следует ожидать новой версии.  Но все-таки они астрономы, а не разработчики, и учитывая их любовь к UNIX, FORTRAN и т.п. трудно сказать, будет ли это полноценная программа под WIN.  Поживем увидим.
Еще есть Web-версия WEBMICA:
http://aa.usno.navy.mil/data/docs/WebMICA_2.html
но она крайне ограничена по сроку действия :(
Еще предлагается библиотека NOVAS:
http://
http://aa.usno.navy.mil/software/novas/novas_info.html
это для разработчиков.  Судя по описанию, очень заманчиво, но я ее скачал только вчера и разумеется не успел разобраться.
Вот собственно и всс, чем нас сегодня радует USNO.  Кстати можете зайти и почитать про ICE, MICA и NOVAS сами: http://aa.usno.navy.mil/,
клик на Software Products.  Для расчета эфемерид можно воспользоваться и сторонними разработками, например SkyMAP Pro, Cartes du Ciel etc.
tlgleonid
« Ответ #4 : 02 Ноя 2001 [14:54:31] »
Не зная программі под Дос, рискну предложить Ephemeris Tools. Точного адреса я не помню, но на моем сайте http://tlgleonid.chat.ru есть ссылка на него. Он позволяет расчитать эфемериды планет, спутников планет, комет и других объектов, различных событий (покрытие звезд и планет Луной, и планетами, являния в системе спутников планет, прохождения интересных объектов, большой сирт, красное пятно... ). У меня сохранился еще вариант очень точного варианта (до тысячеых долей секунды).
Прошу простить за ломанный ответ, но эмоции переполняют...
Pietro
« Ответ #5 : 02 Ноя 2001 [15:39:55] »
Ephemeris Tools homepage:
http://
http://virtualskysoft.de/asappsen.htm
Там есть бесплатная и полная версии.  Про полную сказано:
Enhanced accuracy for for Sun, Moon and planets (VSOP87c und ELP2000).
--т.е. в бесплатной версии точность пониженная что ли?  Непонятно.  Полная версия-- коммерческий продукт (31 евро), причем они не принимают кредитные карты.  Вот и думайте что это такое.
P.S. А по поводу чего эмоции?
tlgleonid
« Ответ #6 : 06 Ноя 2001 [10:21:42] »
Я говорил об эмоциях по поводу качества и функций программы, так их много.
У меня есть полная версия (я ее скачал, когда она еще была бесплатной). Там используется теория с более высокой точностью, ведь VSOP имеет несколько разных таблиц с разной степенью точности. Та, что идет в бесплатной версии, считает довольно быстро, но точность эфемерид для луны не выше 1 секунды. ( по времени). Я считал покрытие Луной Сатурна для разных мест и дат и получил в некоторых случаях разницу в 1 секунду по времени.
