A A A A Автор Тема: Что выбрать SpaceProbe™ 130 EQ Reflector или SpaceProbe™ 130ST EQ  (Прочитано 1753 раз)
lan
Остановился на двух телескопах, помогите какой выбрать ???
A Classic Scope That Keeps Getting Classier
Without doubt, the SpaceProbe 130 Newtonian strikes a classy pose, from its glossy black aluminum tube right down to its 6x30 finder scope. It's a telescope that's sure to attract serious beginners. But a great telescope is more than how it looks - it's how it looks at the stars, and here the SpaceProbe 130 provides great all-around viewing performance. This scope's 130mm (5.1") primary mirror gathers enough light for deep-sky observing while its 900mm focal length (f/6.9) provides the resolving power need to reveal subtle planetary features. With the two fully coated Explorer II eyepieces provided (25mm and 10mm) you can cruise the Orion Nebula or zoom in on the rings of Saturn. The mount is our sturdy EQ-2 equatorial model, with aluminum tripod and accessory tray. Slow-motion controls allow fine manual pointing of the telescope. Addition of an optional EQ-2M or AstroTrack electronic drive enables the telescope to track objects automatically. One-year limited warranty.
или
Parabolic Optics Give This Compact Scope a Performance Edge!
The SpaceProbe 130ST EQ is a rich-field Newtonian reflector with a tube only 24" long compared to the 33" tube length of the standard 130 EQ. The focal length of the ST's 130mm (5.1") primary mirror is 650mm (f/5), producing a wider field of view and brighter images for a given eyepiece focal length. The diffraction-limited parabolic primary mirror is the same type used on much larger reflectors costing substantially more. On a short-focal-length design like this one, a parabolic mirror is a must for delivering sharp, detailed images.
This scope package includes an EQ-2 equatorial mount with dual setting circles and manual slow-motion controls, adjustable aluminum tripod with accessory tray, two Plössl eyepieces (25mm and 10mm), and a 6x30 achromatic finder scope. One-year limited warranty.
Ernest
Судя по этим красноречивым отрывкам. Первый телескоп имеет сферическое зеркало и соотв. сферическую аберрацию, хотя и не очень большую при таком малом отн. отверстии, да и врядли заметной при увеличениях 90х и тем более 32х. Габариты преувеличены, хотя инструмент все еще остается мобильным. Второй имеет параболическое зеркало с умеренным отн. отверстием, небольшими габаритами и при хорошем исполнении должен давать лучшее качество изображения, но набор окуляров с увеличениями 60х и 24х едва-ли даст возможности "насладиться" этим качеством.
Думаю, первый вариант более приемлим - он дает лучший диапазон увеличений.
