A A A A Автор Тема: Phoenix Mars Lander  (Прочитано 191287 раз)
Оффлайн Karen
  • Благодарностей: 255
  • Янг, Карен
    • Сообщения от Karen
Re: Phoenix Mars Lander
« Ответ #420 : 29 Мая 2008 [06:21:23] »
На www.spaceweather.com есть ссылка на звуки посадки Phoenix. Смотрите на "Listen to Phoenix descend" и нажмите на ссылку в абзаце, и на следующей странице, на "listen now". Мне надо было "save" и после этого открыть в Windows media player.
« Последнее редактирование: 29 Мая 2008 [06:39:10] от Karen »
Оффлайн nelson
    • Сообщения от nelson
« Ответ #421 : 29 Мая 2008 [09:06:55] »
Кстати Феникс первая марсианская станция связь с которой осуществляется не с Землей напрямую,а только через спутниковые ретрансляторы на орбите Марса!
подробнее:
How will the Phoenix spacecraft communicate with engineers on the Earth?
...Phoenix will communicate directly with Earth using the X-band portion of the radio spectrum (8 to 12 gigahertz) throughout the cruise phase of the mission and for its initial communication after separating from the third stage of the launch vehicle...
...The mission will use ultra high frequency (UHF) links (300 megahertz to 1,000 megahertz), relayed through Mars orbiters during the entry, descent and landing phase and while operating on the surface of Mars...
...The UHF system on Phoenix is compatible with relay capabilities of NASA’s Mars Odyssey and Mars Reconnaissance Orbiter, and with the European Space Agency’s Mars Express...
...The Phoenix spacecraft’s UHF signal might also be receivable directly via the Green Bank Telescope in West Virginia. Data transmission is most difficult during the critical sequence of entry, descent and landing activities, but communication from the spacecraft is required during this period in order to diagnose any potential problems that may occur. An antenna on the back shell will transmit during entry and descent. Another, on the lander deck, will transmit and receive during the final moments of descent and throughout the surface operations phase of the mission...
http://phoenix.lpl.arizona.edu/faq.php
Meade 90az-adr
WO Megrez 90FD
Оффлайн Space_eyes
    • Сообщения от Space_eyes
« Ответ #422 : 29 Мая 2008 [09:32:25] »
Было бы замечательно если это звуки с микрофона, а не радиосигнала ;)
bob
« Ответ #423 : 29 Мая 2008 [09:37:23] »
А это что, не вода? Или такие залежи углекислого газа!
Залежи  газа. Однозначно.
Оффлайн Borislаv
  • Благодарностей: 32
  • Unsichtbar - vielleicht
    • Сообщения от Borislаv
« Ответ #424 : 29 Мая 2008 [17:26:09] »
29.05.2008 / 10:39    "Феникс" на Марсе приступил к развертыванию руки-манипулятора
     Американские ученые начали в среду операцию по развертыванию роботизированной руки-манипулятора находящегося у северного полюса Марса космического аппарата Phoenix, передает ИТАР-ТАСС. Об этом сообщил руководитель научного проекта Барри Гольдштейн. Миссией Phoenix управляет Лаборатория реактивного движения (ЛРД) в Пасадене (штат Калифорния), а научным экспериментом руководит Университет Аризоны.
     Изначально планировалась, что рука-манипулятор земного робота будет развернута еще во вторник, но этому помешали технические проблемы. Из-за сбоя в программном обеспечении искусственный спутник Красной планеты - «Марсианский орбитальный разведчик» - отключил свой высокочастотный передатчик, через который на Phoenix передаются команды с Земли. Но эту неполадку ученым удалось обойти менее, чем за сутки.
     Рука-манипулятор Phoenix буквально привязана к корпусу аппарата, что позволило ей пережить путешествие и посадку на Марс. Для того, чтобы развернуться, манипулятору необходимо несколько раз повернуть свое «запястье», чтобы высвободить «локоть» и «предплечье» из защитного «рукава», сообщил эксперт из ЛРД Боб Бониц. На эту операцию у робота уйдут два дня, отметил он.
     - К.И.
Блог Занептунье
https://za-neptunie.livejournal.com/
Оффлайн Borislаv
« Ответ #425 : 29 Мая 2008 [17:28:43] »
Тем временем на уже отснятых участках планируются грунтовые работы. При посадке аппарат был специально ориентирован "лицом" (манипулятором) на север, чтобы участок раскопок все время был в тени и не слишком сильно таял.
На этой схеме цветом показана топография участка в зоне досягаемости манипулятора, красное - это углубления, синие - бугры. Копать планируется в канаве по направлению на северо-восток, а ссыпать грунт неподалеку на участок по направлению на СЗ. Ну и в том же районе планируется попробовать взять первые образцы для анализа. Уже начаты операции по расчековке манипулятора, но пока он останется лежать на " палубе", в движение его приведут позже.
по материалам planetary.org
http://www.novosti-kosmonavtiki.ru/phpBB2/viewtopic.php?t=6987&postdays=0&postorder=asc&start=435
Блог Занептунье
Оффлайн Borislаv
« Ответ #426 : 29 Мая 2008 [22:51:12] »
Вроде круговую панораму заполнили.
Блог Занептунье
Оффлайн zverolovlev
  • Подпись под аватаром
    • Сообщения от zverolovlev
    • Алексей Звероловлев ЖЖ
« Ответ #427 : 30 Мая 2008 [00:25:21] »
А что это у Феникса за длинная штанга, торчащая вертикально, с "висюлькой" наверху? Сегодня смотрел компьютерную анимацию миссии и обратил на неё внимание. На круговой панораме она примерно на 19:30
Оффлайн Muxa
    • Сообщения от Muxa
« Ответ #428 : 30 Мая 2008 [00:52:17] »
Часть Meteorological Station (MET) (http://phoenix.lpl.arizona.edu/science_met.php), похоже.
Оффлайн Kosmos-9
    • Сообщения от Kosmos-9
« Ответ #429 : 30 Мая 2008 [10:06:05] »
В Лаборатории реактивного движения НАСА сообщили о завершении операции по развертыванию основного инструмента аппарата Phoenix Mars Lander. 2,35-метровая рука-манипулятор из титана и алюминия была успешно приведена в рабочее состояние и готова к выполнению своего основного задания - бурения Красной планеты в поисках воды, которая может находится под поверхностью.
Однако прежде чем начать работу в НАСА говорят, что хотели бы убедиться работоспособности манипулятора. Инженеры говорят, что рука-манипулятор имеет 4 "сустава", которые позволяют довольно гибко осуществлять позиционирование самого бура и системы забора проб грунта. В ближайшие дни манипулятор будет проверен на возможность сгибов во всех четырех степенях свободы...
http://www.cybersecurity.ru/space/49156.html
Оффлайн DiverHunter
    • Сообщения от DiverHunter
Манипулятор Феникса
« Ответ #430 : 30 Мая 2008 [11:04:11] »
- минуточку - разве на нём есть бур?? Насколько я понял из рисунков и предыдущих рапортов, на манипуляторе установлен КОВШ!?
Если бы не разряжённая атмосфера, можно было бы из модуля в модуль переходить, просто потеплее одевшись и задержав дыхание.
Все в зависимости от того из чего бы состояла эта более плотная атмосфера.
- ну дык понятно из чего - такая же точно, как щас.
...кто-то в лесу наступит на мину. Следи за собой, будь осторожен...
Оффлайн Bayaron
  • Благодарностей: 27
    • Сообщения от Bayaron
    • www.kreinin.com
« Ответ #431 : 30 Мая 2008 [11:44:29] »
да на счёт бура это новость, хотя по логике вещей бур конечно лучше ковша  :)
Оффлайн Kosmogen
    • Сообщения от Kosmogen
« Ответ #432 : 30 Мая 2008 [14:40:59] »
На шапках Марса лёд воды лежит под газом. И в месте посадки Феникса обязательно должна быть вечная мерзлота с водяным льдом под тонким слоем оттаявшего грунта. Рытьё канав в центре и вкрест ребер наблюдаемых полигонов это покажет. Будем смотреть скоро  ::)
Оффлайн Kosmogen
« Ответ #433 : 30 Мая 2008 [16:14:32] »
Там ещё и газовые гейзеры встречаются.
Оффлайн Kosmogen
« Ответ #434 : 30 Мая 2008 [16:22:10] »
Но в районе посадки Феникса полигональная структура оттаивания вечной мерзлоты аналогична приполярным областям Земли. Снимок с орбиты МРО:
Оффлайн Kosmogen
« Ответ #435 : 30 Мая 2008 [16:30:33] »
А это для сравнения участок тундры с оттаявшей поверхностью вечной мерзлоты в Канаде (из википедии).  Структуры весьма похожи, что окончательно могут подтвердить лишь результаты раскопок  :P
Оффлайн Kosmos-9
« Ответ #436 : 30 Мая 2008 [17:51:55] »
Что-то начинают терзать "смутные сомнения". Уж очень похож снимок этого участка на снимок, присланный с Марса ???
А тут еще путаница с рабочим органом руки-манипулятора: ковш или бур? Не говоря уж о нескольких днях, якобы необходимых на тестирование...
http://lenta.ru/news/2008/05/30/arm/
Оффлайн DiverHunter
Сомнения
« Ответ #437 : 30 Мая 2008 [18:00:32] »
 - то есть то же самое, что с Луной? Типа не были они там, а снимки - фальсификация?
Оффлайн Жданок Дмитрий
  • Благодарностей: 44
    • Сообщения от Жданок Дмитрий
« Ответ #438 : 30 Мая 2008 [18:41:06] »
это к узкому специалисту надо обращаться
Strawberry fields forever
Оффлайн Bayaron
    • www.kreinin.com
« Ответ #439 : 30 Мая 2008 [19:15:02] »
к психиатру ?  ;D
