A A A A Автор Тема: Монтировки SEBEN  (Прочитано 2069 раз)
Оффлайн Старик ХоттабычАвтор темы
  • Благодарностей: 12
  • Юрий
    • Сообщения от Старик Хоттабыч
Монтировки SEBEN
« : 17 Окт 2006 [17:05:41] »
Наткнулся а сайт этого производителя. Там куча всяких астрополезностей по радостным ценам.
По отзывам посетителей этого форума понял, что оптика Seben, мягко говоря, ацтой.
Но какие есть отзывы по монтиоровкам?
Там у них есть некая EQ EM10 - на вид крепкая, с полярным искателем, с автоуправлением по двум осям и цена 299 евро!
Вот, что сам производитель пишет про эту монтировку:
Mounts of this dimension with 2-axis drive, hand controller and pole finder are, to our knowledge, usually not available for less than 500 Euro from specialised dealers. Since we only have a small amount of these left, we can now offer them to you for a true bargain price!
The Seben EQ EM10 is a sturdy mount with a comfortable 2-axis motorisation. It is ideally suitable for the visual observation with Newton telescopes up to 8”/203mm (lightweight design), refractor telescopes up to 6”/150mm as well as Schmidt-Cassegrain telescopes and Maksutov telescopes.
Its stainless steel tripod is a big advantage in terms of vibrations compared to a standard aluminium tripod.
Because of its 2-axis motorisation the Seben ED EM10 becomes a very useful gadget for usage in astrophotography, too.
It’s a matter of course that the motor is incorporated into the housing of the mount so it doesn’t derange the outer design. Nonetheless you only have to loosen one screw of its quick release clutch to switch from motor driven usage to manual driven usage with the supplied hand wheels (if required).
Features / Seben EQ EM10:
2-axis drive with hand controller
Adjustable correction speed: 2x, 4x, 8x and 16x
Motor features a quick release clutch with extra hand wheels (Thus the mount
can be driven manually if required)
User-friendly incorporation of the motor into the housing of the mount
Stainless steel tripod: Possesses a much better stability than you typically get
from e.g. aluminium tripods
Pole Finder incorporated
to be connected to the telescope with the wide-spread prism bracket - it’s thus
suitable for most telescopes of the popular manufacturers
Suitable for northern and southern hemisphere (shift key)
Specifications / Seben EQ EM10:
Weight: 19kg / 42lb
Powered by 6 x 1.5V AA (Mignon) Batteries / Rechargeable Batteries
Height: 140cm / 55” (fully extended)
Lifting Capacity: ~8-9kg / ~17.6lb-19.8lb
Оффлайн Алексей Юдин
  • Благодарностей: 1155
    • Сообщения от Алексей Юдин
Re: Монтировки SEBEN
« Ответ #1 : 17 Окт 2006 [18:49:27] »
А что тут писать - это обычная EQ5 производства славной китайской фабрики Джиньхуа. У нас в России известна как Deepsky и Bresser, а с компьютеризированным приводом - как Meade LXD-75. Если Вам её удобно приобрести под маркой SEBEN, то можно смело рекомендовать её под малый инструмент. А цена действительно радует - практически движки с пультом бесплатно.
Оффлайн Олег Чекалин
  • Благодарностей: 1144
    • Сообщения от Олег Чекалин
« Ответ #2 : 17 Окт 2006 [18:54:23] »
Но назвать монтировку ЕМ 10 это очень сильный маркетинговый ход! Покупатели должны были сломать прилавок!
Олег.
Оффлайн Asafan
  • Благодарностей: 133
  • Андрей
    • Skype - Asafan1931
    • DeepSkyHosting: asafan
    • Сообщения от Asafan
    • Фотогалерея
« Ответ #3 : 17 Окт 2006 [19:15:44] »
 Доставку и таможню в цену включить не забыли  ;) ?
Ньютон 150/750, Ньютон 270/1060, DS 80/480 APO, HEQ5 Pro, 120MC-S, 533MC PRO, ASIAIR, ASIAir+, ZWO EAF
Оффлайн DeepPurple
    • Skype - deeppurple379
    • Сообщения от DeepPurple
« Ответ #4 : 17 Окт 2006 [22:24:15] »
Но КАК умеют пробуждать стремление к "халяве" ::) ;D
Иногда величина звезд зависит и от должности...
DeepSky 80x600; Celestron C4-R 102mm; Альтер 603 MAKSUTOV 152mm; DeepSky DT990X152; ТАЛ-200К; Yukon 6-100x100 zoom
HEQ-5 SynScan; EQ-3-2 с приводами; SKY-WATCHER multi function
Canon EOS 400D; DBK 21AU04.AS; VAC-135
  • Юрий
« Ответ #5 : 17 Окт 2006 [22:49:54] »
Я в Латвии живу, а торговая точка Seben есть в Германии. Доставка к нам до 30 кг. стоит 15-20 евро, растаможки нет - хоть какая-то польза от вступления в ЕС  ^-^
Оффлайн Владимир Николаевич
  • Благодарностей: 453
« Ответ #6 : 18 Окт 2006 [09:21:43] »
Обратите внимание на привода и пульт - они какие то левые ;D Должны быть скорости 2х-32х Есть даже двигатели в пластмассовых рассыпающихся корпусах. Пульт и двигатели марки DK-3 к EQ-5 Дипскай одни из самых качественных и дорогих \как внешне так и по исполнению\ и взаимозаменяемы с Виксеновскими. Но есть и другие вариации с пультом как у HEQ-5 и очень дешевыми двигателями.
А вообще монтировок наклепали море. Неплохо бы сюда кинуть фото того о чем речь.
PS неизвестный науке зверь! Похожа на EQ-5 от Синты
« Последнее редактирование: 19 Окт 2006 [11:37:26] от Vladim »
