A A A A Автор Тема: Яркий болид над Краснодарским краем  (Прочитано 8482 раз)
Оффлайн Cyanometer
  • Благодарностей: 51
  • Global Meteor Network
    • Сообщения от Cyanometer
Re: Яркий болид над Краснодарским краем
« Ответ #20 : 01 Фев 2019 [21:11:40] »
Не буду коверкать текст своим переводом
Hi all,
I am attaching the full trajectory solution, it seems that the fireball ended at 28 km with a velocity of around 3 km/s. It's very hard to measure the photometry because the fireball was seen through the clouds, but it was -14 or more at the peak (a bit brighter than the full Moon). The time of the astrometric picks on the static image is made up, but that doesn't matter much because the video data was used for velocity estimation.
I believe that there might be some small (walnut sized) meteorites on the ground. Dark flight modelling still has to be done, but I'm not sure if the search would be worth it because the terrain seems difficult, unless they ended up in the Vladimirovka quarry north of Novorossiysk. In that case, finding a black rock in a white stone quarry would be trivial. If there are people in the area who are interested in the search, I can most certainly do the dark flight modelling and point them in the right direction.
This was a very good test of RMS methods at least, the trajectory solutions seems to be quite good!
Cheers,
Denis
Параметры траектории выложу в теме RMS.
Global Meteor Network: RU0001, 2, T, H, Y
Оффлайн curiosity
  • Благодарностей: 21
    • Сообщения от curiosity
« Ответ #21 : 02 Фев 2019 [00:40:42] »
Прокинул обратный адрес по своим координатам. 10км это большая разница , впрочем я мог и накосячить.Траекторию немного перекинул но суть не изменилась.
https://yadi.sk/i/MxOEMmkziHxwNg обратный адрес
https://yadi.sk/i/-EtvWpjxbAWNng траектория
Идея с карьерами весьма любопытная!
Оффлайн Александр Иванов
  • Благодарностей: 624
  • МРС - C40, МРС - D04, MPC - M77
    • Skype - ial1963
    • Сообщения от Александр Иванов
    • НАА
« Ответ #22 : 02 Фев 2019 [11:19:04] »
Интересные результаты.
Но судя по размерам из письма: "...Окончательная масса была, конечно, не больше 100 грамм,..."
Сложность поиска иголки в стоге. Но а так чисто интересно. :)
Храни Вас Господь!
Оффлайн Грехов Михаил
  • Благодарностей: 822
    • Сообщения от Грехов Михаил
« Ответ #23 : 02 Фев 2019 [11:30:36] »
Куда такие размеры рисунка выкладывать то? Аж более 6тыс пикселей по горизонтали....
А почему рассчитывается такой снос из-за ветра что ли? Неужели существенно влияют....
Оффлайн Serj
  • Благодарностей: 98
    • Сообщения от Serj
    • Тверской астроклуб
« Ответ #24 : 02 Фев 2019 [11:47:07] »
А в чём сомнения? То что килограммовый булыжник сдует на два км при падении с двадцати?
« Ответ #25 : 02 Фев 2019 [12:04:41] »
Ну не на 2км.... а больше. По моделированию типа видно, что наиболее тяжелые камни летят до высоты 15км.... потом там резко разворачиваются и летят уже в другом направлении со сносом порядка 20км. Это как вообще? Какой ветер может так сдуть камень, летящий со сверхзвуковой скоростью? Это раз.
Картинки по траекториям не соответствуют друг другу.... 3D картинка - это одно.... а двумерная - совсем другие траектории и их вид. Что то он там перемудрил и перепутал.
Оффлайн a.v.g.u.s.t.
  • Благодарностей: 30
    • Сообщения от a.v.g.u.s.t.
« Ответ #26 : 02 Фев 2019 [12:07:59] »
В общем, мне кажется, тут какая-то лажа... На рисунке линией указал расположение моего дома относительно север-юг. Точкой помечено место (+/- сотня метров) откуда наблюдал. Так вот, из этой точки я видел уже самый конец пролёта болида, когда закончилась основная вспышка и уже летели осколки (на видео - практически последняя секунда). На высоте градусов 50 - начало наблюдения и градусов 30 - момент когда болид погас. То есть, я хочу сказать, что основные события полёта происходили восточнее линии север-юг, линии расположения моего дома. И соответственно - начало траектории было значительно восточнее. Если на красную траекторию наложить кадр Олега Милантьева с его оллскай камеры, то я видел последнюю четверть траектории. Или даже меньше. То есть крайнюю левую четверть. На указанных высотах.
Strangers in the ку…
Оффлайн curiosity
« Ответ #27 : 02 Фев 2019 [12:59:39] »
Область поиска по двум расчетам:
Дениса Вида и моим.
Коридор поиска в границах зеленых линий. Траектории и высоты сильно расходятся.
https://yadi.sk/i/tB9Pdo_nh8RHYg
Оффлайн Serj
    • Сообщения от Serj
« Ответ #28 : 02 Фев 2019 [13:47:48] »
Кроме того, что они зеркальные (широта в другую сторону), отличий не вижу.
« Ответ #29 : 02 Фев 2019 [14:09:59] »
Ну вот во первых надо бы перевернуть. Во-вторых - выделил красным.... тело летит ровно, а на виде сверху (выделил красными кружками) там почему-то искривления. Почему так?
Второе - траектории при виде сверху вообще становятся обратными.... резко причем. А вроде по 3Д виду прорисовал как на самом деле по идее должно быть. Коряво получилось, но суть ясна.
Оффлайн mihon4ik
  • Благодарностей: 58
    • Сообщения от mihon4ik
« Ответ #30 : 02 Фев 2019 [14:33:27] »
Не знаю, есть ли в этом ценность :)
В IMO обработали отчеты, присланные очевидцами: http://fireballs.imo.net/members/imo_view/event/2019/504
Оффлайн Cyanometer
« Ответ #31 : 02 Фев 2019 [14:46:33] »
Нашлось ёще одно видео, с автомобильного видеорегистратора - https://vk.com/wall-45744892_4662
Оффлайн boch
  • Благодарностей: 712
    • Сообщения от boch
« Ответ #32 : 02 Фев 2019 [14:57:26] »
С регистратора это падение на Кольском.
Оффлайн Cyanometer
« Ответ #33 : 02 Фев 2019 [15:01:11] »
Журнализды, %:?*;№",  слов нет!
Тащат первое попавшееся в качестве иллюстрации...
Оффлайн boch
    • Сообщения от boch
« Ответ #34 : 02 Фев 2019 [15:04:04] »
Это обычная практика. Донести факт, а какими способами - их не волнует. Кукарекнуть для галочки, типа "мы пахали".
На данном падении проявился факт важности специализированных средств. Все видео- фото- свидетельства только от специалистов работающих на грани профессиональной науки. Можно сказать зачатки метеорной сети в этой окрестности имеются.
Оффлайн mihon4ik
« Ответ #35 : 02 Фев 2019 [15:12:33] »
Да, вот автор видео: https://vk.com/wall313254585_869
Оффлайн Michail
  • Благодарностей: 23
  • 42
    • Сообщения от Michail
« Ответ #36 : 03 Фев 2019 [15:06:01] »
создал тему на форуме любителей металлопоиска
https://www.reviewdetector.ru/index.php?showtopic=2102037
учитывая что шансы чрезвычайно  малы - то чем больше народу будет знать тем лучше, любая находка успех, а она рано или поздно "всплывет".
"30.01.2019 года на Кранодарским краем пролетел яркий болид, он дробился на множество фрагментов которые, вероятно, выпали на землю.
 Предполагаемое место падения обломков рассчитано Дениом Вида (https://www.researchgate.net/profile/Denis_Vida) к югу от пос. Верхнебака́нский (в 15 км северо-западнее центра Новороссийска),  на линии  44.823671° СШ, 37.689802° ВД -  44.791541° СШ- 37.586845° ВД.
Возможно зона выпадения  смещена к югу от этой зоны в пределах 2,5 километров. Точка угасания болида- 44.792226°, 37.680385°, но оттуда шел ветровой снос.
Если там и выпали метеориты, то скорее всего каменные, но содержащие железо (каменные содержат 10-30% железа) на металлодетекторе видны как горячие камни, висят на сильном неодимовом магните, снаружи черные матовые оплавленные, внутри на сломе  серый камень.
Дополнительная информация- Яркий болид над Краснодарским краем
Шансы конечно малы но они есть…если кого либо из тех краев заинтересует- удачи!!!.
Оффлайн curiosity
« Ответ #37 : 03 Фев 2019 [15:34:21] »
Севернее тоже может быть. Больше шансов что кто-то случайно найдет.
« Ответ #38 : 03 Фев 2019 [15:37:16] »
А что там с поверхностью сейчас? Снега и сугробы? Или же как? Есть ли удобные площадки для поиска?
Оффлайн curiosity
« Ответ #39 : 03 Фев 2019 [15:38:53] »
На заднем плане снега не видать
