CONSTANT LARGE APERTUREThe nominal aperture value of an ordinary vari-focal lens usually refers to the aperture value when the lens focuses at the wide-angle end. As the lens focuses toward the telephoto end, the focal length increases and the aperture decreases.The Hikvision constant aperture lens retains the same aperture value even when the focal length is adjusted. In other words, there is no need to slow down the shutter speed to allow more light to reach the sensor. Slowing down the shutter causes ghosting, which results in an unusable image. However, a slower shutter speed is not necessary because of the high quality of the components, which allow more light to reach the sensor. Thus, the image remains bright when the focal length varies.
К QHY 5LII подойдет?
Цитата: smol69 от 26 Ноя 2018 [15:08:05]К QHY 5LII подойдет?Почему бы и нет... Но лучше проконсультироваться со Star Hunter https://astronomy.ru/forum/index.php?action=profile;u=14082, вдруг какой-то переходник потребуетсяUPD. Насколько я понял, нужно проставочное кольцо 5мм. Такие у меня есть, могу вложить в посылку.
