Scope of Delivery:-- Bino Viewer-- 1.6X Barlow Nose Piece-- Two 20 mm Wide Angle Eyepieces-- Protective Caps-- Boxвсе в комплекте у вас? а у вас х2 барлоу??
А по сути я так и не понял бинки прикол...мне лично не удобно было
Когда примерно покупали?
А по сути я так и не понял бинки прикол...мне лично не удобно было. Наверно дело привычки
Примерно тоже самое что Вы сказали:The WO unit is a great way to introduce oneself to the binoviewing experience, and many users dont feel the need to progress to the more expensive alternatives. I use my WO bino in a f5.1 dob. At first found they wouldnt come to focus with the supplied 1.6x barlow, (not enough "in focus" because of the approx 100mm light path distance through the unit). There are two ways to address this problem, a) bring the primary mirror forward towards the secondary/ bring the focuser assembly down ways towards the primary, or, b) obtain an extension tube that can be obtained from WO that fits between barlow and bino body nose piece /use some [two or three 1.25"] filter bodies to screw onto the nose piece and barlow onto this. In my case with my sono tube dob I used option (a) moved my focuser/spider assembly down tube by around 2 3/4"-3" and as a result my binos work just fine. There is another possibility. WO also sells 2x barlows for these units, which for some folks this solves the problem when this is swapped out for the 1.6x. Stephen.(45deg.S.)Единственно что не понятно что за удлинитель между барлухой и бино в случае B) и интересно Televue-шная барлуха решит проблему - короче интересно если кто-то уже использовал вариант с барлухой подскажите как решается проблема с Ньютонами и какие барлоу подойдут ...
