A A A A Автор Тема: ISON в VO  (Прочитано 2968 раз)
Оффлайн LeonidOSАвтор темы
  • Благодарностей: 289
  • H15, Q60, N82, O75
    • Сообщения от LeonidOS
Re: ISON в VO
« Ответ #20 : 10 Авг 2014 [20:29:25] »
Dear Sir/Madame:
One of the roles of the HEASARC within the VAO collaboration has
been to ensure the operational quality of VO tools and services. As
part of this we periodically check Cone,SIA,TAP, and SSA
services within the Virtual Observatory to assess compliance with
existing standards and help ensure easy interoperability.
Congratulations. We are pleased to inform you that our latest tests
indicate that all services at your center are compliant.
Thank you for
your careful attention to the VO standards.  While this does not ensure
that there are issues that we have not detected, and focuses primarily
on the syntax of responses rather than semantics, having compliant
services enables a robust VO environment.
If you wish to see the results for your center please go to:
http://heasarc.gsfc.nasa.gov/vo/validation
and click on "View Results by Center" and then click on your center's name.
If you have any questions or concerns regarding what we are seeing or
the validation process in general please let us know.
Regards,
Michael Preciado
VO HEASARC
Michael.E.Preciado@nasa.gov
301-286-1949
Оффлайн 1212Lupus
  • Благодарностей: 196
    • Сообщения от 1212Lupus
    • http://belastro.net
Re: ISON в VO
« Ответ #21 : 10 Авг 2014 [22:19:07] »
И что даёт эта успешная валидация?
Если утро наступает в три -
(с) НОЛЬ
Re: ISON в VO
« Ответ #22 : 10 Авг 2014 [22:35:27] »
Ну то, что ресурс не заблокировали и признали рабочим.
