Уже есть новее, .0.76
Но напрягает в этом деле только Аском 6, уж очень противоречивые отзывы о его работоспособности...
На совсем понятно с какой целью на сайте рекомендуют : 1. Backup your system ini files (My Documents\FocusMax). Все равно старые конфиги не подходят.
Вдруг все сдохло и на текущую версию нужно после восстановления просто конфиги накатить?
dont have Canon Utilities going or set up for remote shootingConfigure Maxim DL for your camera (in camera set up window)Use Maxim Dl for all your camera control (shutter speed, ISO etc)I have found that it works better on a slightly brighter star. Focus max reccommends a 4th mag star for CCD cameras. I sometimes use even 2nd mag with the DSLR.Then run your calibration set up (V Curve) as if it is a CCDThen click and focus.Then disconnect from DL and use Canon remote shooting (well I suppose you could use DL but I havent worked out icnr delay yet in DL). The only drama is you have to manually reset your exposure to bulb on camera.Obviously if you need to refocus its the same in reverse - disconnect canon utilities, connect DL, and focus
FocusMax 3.8.0.8
