A A A A Автор Тема: AAVSO Special Notice #299: Observations needed TODAY of SDSS J164248.52+134751.4  (Прочитано 944 раз)
Оффлайн Sergei38Автор темы
  • Благодарностей: 8
  • Познайте Истину,и Истина освободит Вас!
    • Сообщения от Sergei38
October 10, 2012
Dr. Boris Gaensicke (leader of the consortium observing CVs
with the HST COS instrument; see AAVSO Alert Notice 471 and
AAVSO Special Notice #297 for details and instructions) writes
with an urgent message:
"STScI would like an update on SDSS J164248.52+134751.4 by
~16UT TODAY (2012 October 10), when the star is not easily
visible for most of our observers. Any observations from Europe
early this evening will be most welcome."
HST is scheduled to observe this CV on October 12 and the team,
which has to make a go/no-go decision later today, is anxious
that it might not be at minimum, as it has small brightenings
from 18th magnitude.
If it is at all possible, please observe
SDSS J164248.52+134751.4 and report your observations to the
AAVSO International Database at once, using the name
SDSS J164248.52+134751.4. Use this name to generate charts
with the AAVSO Variable Star Plotter (www.aavso.org/vsp).
Coordinates:   R.A. 16 42 48.51      Dec. +13 47 51.5   (2000.0)
This AAVSO Special Notice was compiled by Elizabeth O. Waagen.
SUBMIT OBSERVATIONS TO THE AAVSO
Information on submitting observations to the AAVSO may be found at:
http://www.aavso.org/observing/submit/
SPECIAL NOTICE ARCHIVE AND SUBSCRIPTION INFORMATION
A Special Notice archive is available at the following URL:
http://www.aavso.org/publications/specialnotice/
Subscribing and Unsubscribing may be done at the following URL:
http://www.aavso.org/publications/email/
Я наблюдал все,что происходит на небе,-как светила,которые на небе не изменяют своих путей,как все они восходят и заходят по порядку,каждое в свое время,не преступая своих законов.
  • Благодарностей: 8
AAVSO Специальное Уведомление #299
Наблюдения необходимы СЕГОДНЯ SDSS J164248.52+134751.4
10 октября 2012
Д-р Борис Gaensicke (лидер консорциума наблюдений CVs
с HST COS инструмент, см. AAVSO бдительности и 471
AAVSO Специальное Уведомление #297 подробные сведения и инструкции) пишет
с срочное сообщение:
"STScI хотел бы получить обновления на SDSS J164248.52+134751.4 по
TW 16UT СЕГОДНЯ (2012 г. 10 октября), когда звезда не легко
видимым для большинства наших наблюдателей. Любые замечания из Европы
сегодня вечером будет только приветствоваться."
HST запланировано соблюдать этот CV на 12 октября и в команде,
что должен сделать go/no-go решении позже сегодня, обеспокоена
это не могло быть на минимуме, так как имеет небольшие известь
с 18-го масштаба.
Если это вообще возможно, пожалуйста, соблюдайте
SDSS J164248.52+134751.4 и сообщать о своих наблюдениях в
AAVSO Международной Базе данных одновременно, используя имя
SDSS J164248.52+134751.4. Используйте это имя для создания диаграмм
с Переменных Звезд AAVSO (Плоттер www.aavso.org/vsp).
Координаты: Р.А. 16 42 48.51 Dec. +13 47 51.5 (2000.0)
Это AAVSO Особое внимание составлен Элизабет о. Waagen.
ПРЕДСТАВИТЬ СВОИ ЗАМЕЧАНИЯ К AAVSO
Информация о представлении замечаний к AAVSO, может быть найдена на:
ОСОБОЕ ВНИМАНИЕ АРХИВ И ПОДПИСКА
Специального Уведомления архив доступен по следующему адресу:
Подписка и отказ от подписки, может осуществляться на следующих URL:
Оффлайн Денис Денисенко
  • Благодарностей: 379
  • Рост: 190+/-2
    • Сообщения от Денис Денисенко
    • Будни астронома, учителя, моржа и велосипедиста
Поздно прочитал это сообщение, к сожалению. Объект вечерний, на восточных МАСТЕРах в Тунке и Благовещенске он уже зашел за горизонт, а в Кисловодске проводятся технические работы. Могу только сказать, что звездочка вспыхивает достаточно часто - вероятно, раз в два месяца. В этом году вспышки до 15-й величины были 29 февраля, 9 мая и 5 сентября:
2012-02-29 21:48:30  15.19  MASTER-Tunka
2012-02-29 22:34:10  15.22  MASTER-Tunka
2012-05-09 17:21:19  15.12  MASTER-Amur
2012-05-09 18:07:10  15.11  MASTER-Amur
2012-09-05 11:18:33  14.95  MASTER-Amur
2012-09-05 12:05:05  15.24  MASTER-Amur
(указаны моменты середины экспозиций в UT).
Остальное время объект болтается около 17-18 величины. По каталогу SDSS величины в спокойном состоянии такие: u=17.73 g=17.89 r=17.82 i=17.59 z=17.63.
J0209+2832 = BS Tri, J2319+3647 = V776 And, NSV 1485 = NN Cam, V713 Cep, GRB 920925C, (130) Электра / 2UCAC 31525121 27.08.2007, 2007 VN84 = Rosetta, J1845+4831, J0733+2619, SN 2011hz, 2011ip, J1650-2426, J2112+2421, J0426+3541, 2013hi, 2013hm, 2013ho, 2014af, 2014am, PHA 2014 UR116, C/2015 K1...
Feanor
Переменная звезда?  Хотелось бы высказать даже не просьбу, а предложение, если не трудно - и не обязательно к автору темы (каждый человек может быть занят и ему хватит времени только на главный пост).  Объект явно необычный и интересный.  Какого рода объект?   Галактический или внегалактический? Чем от интересен?  Конечно, развернутое описание и обсуждение - это скорее для другого раздела, но хотя бы немного, чтобы пользователям было понятно в общих чертах.
  • Рост: 190+/-2
Самому интересно стало, почему именно на эту звезду в первую очередь решили навести Хаббла! Раньше про нее ничего не слышал. Сейчас вот открыл статью Саутворта и др. по результатам наблюдений на NTT и VLT в 2007 году, сразу после открытия звездочки на Слоане. Пишут, что у этой катаклизмической переменной необычное распределение яркости в аккреционном диске по профилю, полученному методом Доплеровской томографии. А именно: на диске присутствуют два максимума яркости в линии H_альфа, один из которых находится с противоположной стороны от горячего пятна. Далее: линии водорода H_альфа и гелия He I двухпиковые (это вполне обычно); при этом в линии H_альфа скорость на аккреционном диске меньше скорости линии, которая соответствует внутренней поверхности вторичного компонента (условно говоря, точке Лагранжа, через которую перетекает вещество с красного карлика на белый)! То есть формально получается, что в этой системе нарушается 3-й закон Кеплера, по которому скорость аккреционной струи в периастре (в точке падения на диск) должна быть больше, чем в апоастре (на истечении из донора) обратно пропорционально их расстояниям.
Что касается внешних проявлений, это карликовая новая с орбитальным периодом (по спектроскопии) 113.6 минут. Вспышки, кстати, имеют достаточно необычный профиль: довольно медленный подъем, небольшая амплитуда и быстрый спад. Первой среди всех 40 с лишним объектов в этой кампании выбрана, вероятно, потому, что скоро войдет в соединение с Солнцем, и следующих наблюдений придется ждать полгода.
Для любителей астрономии представляет, пожалуй, только умозрительный интерес: вспыхнет она или не вспыхнет за сутки, оставшиеся до наблюдений на Хаббле, и если вспыхнет, то спалит или не спалит камеру спектрографа COS? Для реальных наблюдений с любительскими телескопами интереснее будут более яркие катаклизмические переменные 14-й величины в Орионе и Персее, которые недавно открыты на наших телескопах (см. тему "Новые переменные звезды").
Feanor
Спасибо за комментарий!
  • Рост: 190+/-2
Да, еще: тут в исходном сообщении упоминался AAVSO-шный Alert Notice 471. Вот ссылка на этот документ с описанием программы и списком всех объектов для наблюдений: http://www.aavso.org/aavso-alert-notice-471 (Мониторинг катаклизмических переменных для наблюдений с КТХ).
Задачи программы наблюдений на Хаббле там сформулированы так: "спектрограф COS последовательно проведет ультрафиолетовую спектроскопию ~40 катаклизмических переменных с целью определить температуры, состав атмосфер, скорости вращения и в итоге массы их белых карликов".
