A A A A Автор Тема: "А кто это так бумкнул?" (с)  (Прочитано 3769 раз)
polar
« : 20 Июн 2006 [10:40:21] »
http://lenta.ru/news/2006/06/19/supersupernovae/
(Обратите внимание, что New scientist пишет таки о другом созвездии http://www.newscientist.com/article.ns?id=dn9360&feedId=online-news_rss20)
Циркуляр IAU об открытии таков
No. c546     (15 June 2006)
        * VARIABLE OBJECT IN BOOTES
               K. Dawson, Physics Division, Lawrence Berkeley National
              Project (G. Aldering, K. Barbary, K. Dawson, V. Fadeyev, G. Goldhaber,
Laboratory, Berkeley, reports on behalf of the Supernova Cosmology
A. Gude, X. Huang, A. Kim, M. Kowalski, N. Kuznetsova, W. Lee, J.
Meyers, P. Nugent, S. Perlmutter, D. Rubin, D. Schlegel, T. Spadafora,
N. Suzuki, and L. Wang, Lawrence Berkeley National Laboratory; M. Doi,
Y. Ihara, T. Morokuma, N. Takanashi, K. Tokita, and N. Yasuda,
University of Tokyo; C. Lidman, European Southern Observatory; and R.
Amanullah, A. Goobar, and V. Stanishev, Stockholm University) that an
unusual transient located at R.A. = 14h32m27s.42, Decl. = +33o32'25".1
(equinox 2000.0), with a rise time of > 100 days, was discovered in
images taken on Feb. 22 using the Advanced Camera for Surveys (ACS) on
the Hubble Space Telescope, and was observed at intervals of 15-25 days
until just after peak magnitude on June 5.  The new variable has
increased by more than a factor of 200 in flux, with an estimated rise
time of approximately 100 days in the observer frame; it has displayed
little or no evolution in color, maintaining [F775W]-[F850LP] = -0.1
for more than 100 days with a scatter of 0.05 mag.  Deep ACS reference
images with exposure times of approximately 6400 s in F850LP and 1200 s
in F775W show no indication of a host galaxy to an approximate limiting
mag of 26.5 at 5-sigma confidence in both filters.  Selected F850LP
magnitudes for the new variable:  2006 Jan. 29 (and two earlier images,
stacked), > 26.5 (not visible); Feb. 22, 23.7; May 22, 21.2; June 5,
21.3.  Selected F775W magnitudes for the new variable:  2006 Jan. 29,
> 26.5; Feb. 22, 23.5; May 22, 21.1; June 5, 21.2.  From Feb. 22 to May
22, the object increased monotonically in flux.
     A Keck-telescope LRIS spectrum obtained on May 29 shows no obvious
Fe, He, Si, or H features.  Redward of 600 nm, the spectrum is blue and
relatively featureless, with only one shallow absorption feature at
about 635 nm.  There is significant absorption at wavelengths below about
600 nm, with several additional broad (FWHM approximately 20 nm)
absorption features at approximately 535, 485, and 430 nm.  Earlier
spectra obtained with Subaru on April 23 and the Very Large Telescope on
May 19 indicate that these features are not evolving rapidly.  If
absorption at about 600 nm can be attributed to Ca H and K, the
corresponding redshift would be z = 0.54, with peak magnitude approximately
one mag brighter than a typical type-Ia supernova at that redshift.  The
lower limit on the absolute magnitude of the host at this redshift would
be M > -14.5.  Although the latest photometric point suggests that the
target is now past maximum, it is still bright enough to be followed
spectroscopically with 8- to 10-m-class telescopes.  A finding chart can be
found at http://supernova.lbl.gov/ACSclustersearch/ .
NOTE: These 'Central Bureau Electronic Telegrams' are sometimes
      superseded by text appearing later in the printed IAU Circulars.
2006 June 15                     (CBET 546)               Daniel W. E. Green
Оффлайн Startreker
    • Сообщения от Startreker
Re: "А кто это так бумкнул?" (с)
« Ответ #1 : 20 Июн 2006 [12:11:50] »
Переводим на русский:Телескоп Hubble сфотографировал сверхъяркий объект в созвездии Весов, который астрономы пока не могут идентифицировать, пишет New Scientist. Неопознанный источник света сравнивают со сверхновой, но отмечают, что его блеск растет сильнее и дольше, а спектр не совпадает со спектром какого-либо известного тела.
Ученые говорят, что взрыв сверхновой - единственное, чем можно объяснить быстрый всплеск излучения точечного источника. Хотя явления, сопровождающиеся выбросом большей энергии, известны, все они происходят с телами, протяженность которых даже на периферии Вселенной телескопы позволяют различить.
Первый снимок объекта был получен в конце февраля. Исследователи ждали, что не позднее чем через 20 дней яркость станет максимальной, как это происходит с большинством сверхновых, однако она продолжает расти до сих пор. Все это время цвет объекта (то есть, строго говоря, его спектр) не менялся, тогда как его изменение должно неизбежно последовать за любым взрывом, сопровождающимся выбросом вещества и изменением состава.
Красное смещение в спектре, по которому обычно измеряют расстояние до внегалактических тел, соответствовало 5,5 миллиардам световых лет - и астрономы констатировали, что наиболее яркие из взорвавшихся звезд, будучи удаленными на такую дистанцию, светились бы по крайней мере в несколько раз слабее. Кроме того, ни одной галактики, в которой могла бы находиться сверхновая, в нужном участке созвездия Весов нет.
Hubble будет наблюдать за "сверхсверхновой" до 25 июня. Астрономы надеются, что за это время в спектре неопознанного объекта произойдут какие-либо изменения, которые позволят судить о его природе.http://www.rambler.ru/db/news/msg.html?s=260000267&mid=8080244
Оффлайн Startreker
« Ответ #2 : 20 Июн 2006 [12:17:12] »
Ныне новости сообщают что яркость этого обьекта продолжает расти...
Оффлайн Diletant
  • Благодарностей: 12
    • Сообщения от Diletant
« Ответ #3 : 20 Июн 2006 [14:09:35] »
А может это квазар родился? Тогда он насовсем останется.
ущеко
« Ответ #4 : 20 Июн 2006 [16:32:00] »
Это новая Вселенная родилась...
