ВНИМАНИЕ! На форуме начался конкурс - астрофотография месяца АПРЕЛЬ!
Цитата: olegtitov от 07 Июл 2012 [06:47:04]Цитата: VimanaPro от 07 Июл 2012 [06:22:36]Цитата: olegtitov от 07 Июл 2012 [05:55:47]Мне интересно, как долго Вы будете пропагандировать во всех ветках "ошибочные воззрения".Время размещения на всех ветках ("на всех ветках" - это гипербола) "ошибочных воззрений" и ошибочных воззрений истеклоИ даже чаю не попьете?Чаю попью, тем более что у нас за тридцать градусов по Цельсию, но без сахара. А какое, кстати, имеет отношение чаепитие к данной теме ? Это какая-то аллегория ?
Galaxies congregate in clusters and along filaments, and are missing from large regions referred to as voids. These structures are seen in maps derived from spectroscopic surveys that reveal networks of structure that are interconnected with no clear boundaries. Extended regions with a high concentration of galaxies are called 'superclusters', although this term is not precise. There is, however, another way to analyse the structure. If the distance to each galaxy from Earth is directly measured, then the peculiar velocity can be derived from the subtraction of the mean cosmic expansion, the product of distance times the Hubble constant, from observed velocity. The peculiar velocity is the line-of-sight departure from the cosmic expansion and arises from gravitational perturbations; a map of peculiar velocities can be translated into a map of the distribution of matter. Here we report a map of structure made using a catalogue of peculiar velocities. We find locations where peculiar velocity flows diverge, as water does at watershed divides, and we trace the surface of divergent points that surrounds us. Within the volume enclosed by this surface, the motions of galaxies are inward after removal of the mean cosmic expansion and long range flows. We define a supercluster to be the volume within such a surface, and so we are defining the extent of our home supercluster, which we call Laniakea. A key component of this paper is an accompanying movie that can be viewed (also in 3D) and downloaded at this http URL or this http URL
We evaluate the Hadamard function, the vacuum expectation values (VEVs) of the field squared and the energy-momentum tensor for a massive scalar field with general curvature coupling parameter in the geometry of two parallel plates on a spatially flat Friedmann-Robertson-Walker background with a general scale factor. On the plates, the field operator obeys the Robin boundary conditions with the coefficients depending on the scale factor. In all the spatial regions, the VEVs are decomposed into the boundary-free and boundary-induced contributions. Unlike to the problem with the Minkowski bulk, in the region between the plates the normal stress is not homogeneous and does not vanish in the geometry of a single plate. Near the plates, it has different signs for accelerated and deccelerated expansions of the universe. The VEV of the energy-momentum tensor, in addition to the diagonal components, has a nonzero off-diagonal component describing an energy flux along the direction normal to the boundaries. Expressions are derived for the Casimir forces acting on the plates. Depending on the Robin coefficients and on the vacuum state, these forces can be either attractive or repulsive. An important difference from the corresponding result in the Minkowski bulk is that the forces on the separate plates, in general, are different if the corresponding Robin coefficients differ. We give the applications of general results for the class of α-vacua in the de Sitter bulk. It is shown that, compared with the Bunch-Davies vacuum state, the Casimir forces for a given α-vacuum may change the sign.
Мы оцениваем функцию Адамара, вакуумные средние (VEVs) поля в квадрат и тензор энергии-импульса для массивного скалярного поля с общей кривизной параметра связи в геометрии двух параллельных пластин на пространственно плоском фоне Фридмана-Робертсона-Уокера с общим коэффициентом масштабирования. На пластинах, оператор поля подчиняется граничным условиям Робина с коэффициентами, зависящими от масштабного фактора. Во всех пространственных областей, VEVs разлагаются на граничных свободных и граничных индуцированных вкладов. В отличие от проблемы с наливом Минковского, в области между пластинами нормальное напряжение не является однородным и не обращается в нуль в геометрии одной пластины. Рядом с пластин, она имеет разные знаки для ускоренных и deccelerated расширения Вселенной. VEV тензора энергии-импульса, в дополнение к диагональных компонент, имеет ненулевую внедиагональная компонент, описывающий поток энергии вдоль направления нормали к границам. Получены выражения для сил Казимира, действующих на пластинах. В зависимости от коэффициентов Робина и на вакуумном состоянии, эти силы могут быть либо притяжения или отталкивания. Важное отличие от соответствующего результата в объеме Минковского является то, что силы, действующие на отдельные пластины, в общем случае, различны, если соответствующие коэффициенты Robin различаются. Приведем применения общих результатов для класса альфа-вакуумами в объеме де Ситтера. Показано, что, по сравнению с вакуумным состоянием Bunch-Davies, силы Казимира для данного альфа-вакуума может изменить знак.
Цитата: VimanaPro от 09 Окт 2012 [14:38:24]Оставляю для Golossvyshe, и тех немногих кому ещё интересно, это новостное сообщение (поэтому не в ЛС).Есть такая квантовомеханическая система из электрона и позитрона со спином, равным либо единице либо нулю - позитроний. Она ( система ) исчезает, аннигилируя в зависимости от спина на два или три гамма-кванта. Последние работы R. Brent Tully, S. J. Robles-Pérez, ... позволили получить квантовомеханическую систему из электрона и CPT-электрона ( не позитрона ). В отличие от аннигилирующего позитрония, квантовомеханическая система из электрона и CPT-электрона исчезает без появления гамма-квантов
Там что отрицательная масса и энергия?
то есть нарушается закон сохранения энергии?
Поскольку народ не понял, повторяю, тема на грани закрытия из-за постороннего флуда!
