но к сожалению большая погрешность в расстоянии от точки наблюдения до луны (сравнивал с орбитроном), а также в расчете пр. восхождения и склоненияКакой размер невязок?+- 0.5 град.
Dist 409427.10192282428 LatLune -10.728224427141967 LonLune 139.36119864118135 H -48.802665821805221 Az 106.21991237721139
static void SunMoon( double T, double *Sun, double *Moon ){ static double AU = 1.49597870E+11; static double ABERTN = 99.3664E-06; /* constant of aberation in rad */ static double T0 = 2415020.0; /* epoch for this fourier series */ static double REarth = 6378140.0; double DT; double MEARTH, COSME, SINME, NURA; double LONSUN, COSL, SINL, RS, E, OB, SOB, COB; double LONPRT, NMOON, MR, MRi, LMMean, F, MM; double cosmm, cosf, sinmm, sinf, sin2d; double cos2d, sin2f, cos2f, sin2mm, cos2mm; double SL, CL, S, cosd, sind, LATMN, LONGMN; double MVENUS, MMARS, MJUP, DMNSUN; double myTrue[3]; /* convert Julian time to ephemeris time wrt to epoch 1900 Jan 0.5 ET*/ DT = (T - T0 + 6.31E-04 + 2.85E-08 * (T-2446066.5))/36525.0; /* compute earth mean anomaly, eqn 14 */ MEARTH = fmod(6.25658358 + 628.30194572 * DT, M2PI ); COSME = cos( MEARTH ); SINME = sin( MEARTH ); /* Mean anomalies for perturbing bodies */ MVENUS = fmod(3.70795199 + DT * 1021.32292286, M2PI); MMARS = fmod(5.57772322 + DT * 334.05561740, M2PI); MJUP = fmod(3.93187774 + DT * 52.96346477, M2PI); /* mean elongation of the moon from the sun, eqn 15 */ DMNSUN = fmod(6.12152394 + DT * 7771.37719393, M2PI); /* celestial longitude of the mean asc node of the moon's orbit, eqn 16 */ NMOON = fmod(4.52360151 - DT * 33.757146246, M2PI); NURA = -83.55E-06 * sin( NMOON ); /* nutation of ra ? eqn 25 */ /* perturbation expressions are from Newcomb, Tables of the sun A.P.A.E. vol. 6, pp.14-18 (1898)*/ LONPRT = 23.4553E-06 * cos( 5.220309 + MVENUS - MEARTH ) /*eqn 13 */ + 26.7908E-06 * cos(2.588556 + 2.0 * (MVENUS - MEARTH)) + 12.1058E-06 * cos(5.514251 + 2.0 * MVENUS - 3.0 * MEARTH) + 9.9047E-06 * cos(6.001983 + 2.0 * (MEARTH - MMARS)) + 34.9454E-06 * cos(3.133418 + MEARTH - MJUP) + 12.6051E-06 * cos(4.593997 - MJUP) + 13.2402E-06 * cos(1.520967 + 2.0 * (MEARTH - MJUP)) + 31.0281E-06 * cos(4.035026 + DT * 0.352556) + 31.2898E-06 * sin( DMNSUN ) + NURA - ABERTN; LONSUN = fmod(4.88162793 + DT * (628.33195099 + DT * 5.2844E-06), M2PI) + SINME * (33495.79E-06 - 83.58E-06 * DT + COSME * (701.41E-06 - 3.50E-06 * DT + COSME * 20.44E-06)) + LONPRT; COSL = cos( LONSUN ); SINL = sin( LONSUN ); RS = AU * (1.0002806 - COSME * (1675.104E-05 - 4.180E-05 * DT + COSME * 28.060E-05)); /* true obliquity of the ecliptic, eqn 1 & 26 */ OB = 0.40931970 - 2.27111E-04 * DT + 4.465E-05 * cos ( NMOON ); COB = cos( OB ); SOB = sin( OB ); E = NURA * COB; /* eqn of equinoxes, eqn 2 */ /* convert to cartesian coordinates, eqns. 6-10 scaled to meters */ Sun[0] = RS * (COSL + SINL * COB * E ); Sun[1] = RS * (SINL * COB - COSL * E ); Sun[2] = RS * SINL * SOB; /* lunar ephemeris is based on Lrown's Lunar Theory Ammended. The expressions are adapted from Woolard, theory of the rotation the Earth, A.P.A.E Vol.15, Part 1 (1953), Tables 4, 6, and 7. The moon vector is computed at the Earth's center in the geometric direction of the moon. Neglecting the light travel time of 1.3 sec between Earth and moon gives a negligible error of 0.0002 deg for the moons's direction. */ LMMean = fmod( 4.71996657 + DT * (8399.70914492 - DT * 1.9780E-05), M2PI); F = fmod( 0.19636505 + DT * (8433.46629117 - DT * 5.6044E-05), M2PI); MM = fmod( 5.16800034 + DT * (8328.69110367 + DT * 1.60425E-04),M2PI); DMNSUN -= (2.5065E-05 * DT * DT); /* eqn 33 */ NMOON += (3.6264E-05 * DT * DT); /* fundamental frequency sines and cosines */ cosmm = cos(MM); sinmm = sin(MM); cosd = cos(DMNSUN); sind = sin(DMNSUN); cosf = cos(F); sinf = sin(F); /* double frequency sines and cosines */ sin2d = 2.0 * sind * cosd; cos2d = cosd * cosd - sind * sind; sin2f = 2.0 * sinf * cosf; cos2f = cosf * cosf - sinf * sinf; sin2mm = 2.0 * sinmm * cosmm; cos2mm = cosmm * cosmm - sinmm * sinmm; /* lunar longitude */ LONGMN = sind * (-607.0 + 84.0 * COSME - 131.0 * cosmm ) + sin2d * (11490.0 + 134.0 * cos2d + 239.0 * cos2f + 683.0 * COSME + cosmm * (23098.0 + 392.0 * cos2d + 918.0 * COSME - 80.0 * cos2f + 138.0 * cos2mm) + cos2mm * (1096.0 + 300.0 * cos2d)) + sin2f * (-1996.0 - 295.0 * cos2d + cosmm * (-411.0 - 20.0 * cos2d)) + SINME * (-3238.0 + 90.0 * cosd - 919.0 * cos2d - 72.0 * COSME + cosmm * (-1248.0 - 1222.0 * cos2d) - 84.0 * cos2mm) + sin2mm * ( 3876.0 + 10.0 * COSME + cos2d * ( -956.0 - 296.0 * cos2d ) ) + (sin2mm * cosmm + cos2mm * sinmm ) * ( 175.0 -59.0 * cos2d ) + 68.9 * sin( 6.042967 + 2.318888 * DT ) - 49.0 * sin( NMOON ) + sinmm * ( sin2d * ( -1052.0 * SINME -72.0 * sin2f ) + COSME * ( 184.0 - 804.0 * cos2d ) + cos2d * ( -21305.0 - 352.0 * cos2d ) + cos2f * ( -27.0 + 8.0 * cos2d ) + 49.0 * cosd + 109936.0 ); LONGMN = LONGMN * 1.0E-06 + LMMean; /* lunar latitude */ LATMN = cosf * ( -49.0E-06 * sind + sin2d * ( 3592.0E-06 + 119.0E-06 * COSME + 2008.0E-06 * cosmm + 85.0E-06 * cos2mm ) + SINME * ( -55.0E-06 - 24.0E-06 * cos2d - 112.0E-06 * cosmm ) + sinmm * ( 9744.0E-06 - 1540.0E-06 * cos2d + 10.0E-06 * COSME ) + sin2mm * ( 455.0E-06 - 49.0E-06 * cos2d ) ) + sinf * (-3.0E-06 * cosd - 2454.0E-06 * cos2d - 60.0E-06 * cos2f + 6.0E-06 * sinmm * SINME + sin2d * (-157.0E-06 * SINME+248.0E-06 * sinmm-79.0E-06 * sin2mm ) + COSME * ( -7.0E-06 - 53.0E-06 * cos2d ) + cosmm * ( 50.0E-06 + 72.0E-06 * cos2d + 4.0E-06 * COSME ) + cos2mm * (147.0E-06 - 87.0E-06 * cos2d ) + 89473.0E-06 ); SL = sin( LATMN ); CL = cos( LATMN ); /* the following numerator is the inverse of the constant of sine parallax for the moon, 3422.451 arc-sec, but iin radians. */ MRi = 9999237.0 - 2858.0 * cosd + sin2d * ( 6481.0 * SINME + sin2mm * (-1715.0 + 2144.0 * cos2d)) + sinmm * (-2083.0 * sin2f + SINME * ( 6142.0 - 4067.0 * cos2d ) + sin2d * (91230.0 + 3260.0 * cos2d + 3027.0 * COSME)) + cos2d * ( 82488.0 + 1526.0 * cos2d) + COSME * ( -1169.0 + 4727.0 * cos2d + 67.0 * cos2mm) + cosmm * (541309.0 - 2089.0 * cos2f + 3634.0 * cos2mm + cos2d * (109264.0 + 3764.0 * cos2d) + SINME * ( 5691.0 * sin2d + 1350.0 * sinmm) + COSME * ( 596.0 + 4091.0 * cos2d )) + cos2mm * ( 28598.0 + cos2d * ( -61.0 + 2204.0 * cos2d )); MR = REarth * 60.26816E+07 / MRi; myTrue[0] = CL * cos( LONGMN ); S = CL * sin( LONGMN ); myTrue[1] = ( S * COB - SL * SOB); Moon[2] = MR * ( S * SOB + SL * COB ); /* convert x and y components from true equinox to mean equinox of date so components are based on true equator and mean equinox. */ Moon[0] = MR * ( myTrue[0] + myTrue[1] * NURA ); Moon[1] = MR * ( myTrue[1] - myTrue[0] * NURA ); return;}
В книгах Астрономические алгоритмы Jean Meeus есть разложения для долготы, широты, расстояния солнца, планет и тд.Где их можно взять в электронном виде (киньте кто нибудь мне) или подскажете более новые разложения.
Возьмите DE405, получите координаты и по ним получите расстояния. Полный ряд для Луны это для гурманов. Не полный - думаю уже заметили, люди мучительно решают чей калькулятор правее и авторитетней Имейте ввиду. Исходник с хорошей точностью сразу счастья не даст. Там весело будет уже начиная со времени. Для начала нужно вести базу с секундами (TAI - UTC), далее регулярно сливать файлы с EOP и по точкам интерполировать. А без хорошего времени не будет и полной точности.
Если вас не затруднит скиньте мне DE405 пожалуйста, а немного запутался в поисках на файловых серверах...
На счет Луны, это отдельная тема и сейчас она не обязательна, но потом поспорю где-же все таки правее...
Суперская точность конечно не нужна, но лучше чем преобразованиями Кеплера да...
Дело не в том где лучше/хуже. Под конкретную задачу выбирается. Это же просто интересно знать как мы летим на шарике Язык реализации алгоритмов вам какой роднее?
Kirillчто касается языка то паскаль , но язык для меня не главное, а главное само разложения с коэффициентами и алгоритмом расчета.Если вас не сильно затруднит , от сканируйте страницы из Альманаха...
