A A A A Автор Тема: Unimap: помогите протестировать?  (Прочитано 2657 раз)
Оффлайн Kirill Grishin
  • Благодарностей: 68
    • Сообщения от Kirill Grishin
Re: Unimap: помогите протестировать?
« Ответ #20 : 12 Июл 2010 [18:03:11] »
russian Language too?
Оффлайн LifeIsGood
  • Благодарностей: 48
    • Skype - dennissakva
    • Сообщения от LifeIsGood
« Ответ #21 : 12 Июл 2010 [18:04:35] »
Only if you translate it  ;)
Оффлайн larrylartАвтор темы
    • Skype - larrylart
    • Сообщения от larrylart
    • my website
« Ответ #22 : 12 Июл 2010 [19:48:02] »
Yes, at the moment only the top menu options are translated and that with automated online translators. If you go in menu->Options->Preferences and there in Formats tab - you will find a language options. Once you select and ok you will need to close the application and start it again.
Well, I am sure if people find the application useful that they will help me translated in russian as well :)
Larry
Оффлайн LeonidOS
  • Благодарностей: 289
  • H15, Q60, N82, O75
    • Сообщения от LeonidOS
« Ответ #23 : 12 Июл 2010 [23:39:13] »
Hi Larry!
Thank you for the very interesting project. I tried to use your program and I have several questions...
1. Can Unimap read some parameters directly from FITS header? For example OBJCTRA, OBJCTDEC (or CRVAL) and information about image scale?
2. What do you think about add UCAC3 support?
3. I tried to load asteroids in the field, after very long process (fetching ASTORB data from Vizier, translate it to local format and sorting) Unimap stop respond...
4. Can I manually measure astrometric position of object on the image?
    • Skype - larrylart
    • my website
« Ответ #24 : 12 Июл 2010 [23:53:23] »
It used to but not at the moment - I have a bug with fits since unicode conversion and possible with the latest version of cfitsio library. I working to fix it and and it be working in the next update.
It will be added in the next update as well.
This should work. If you can send me/email the image along with the details (date/time etc) I can try to see what's happening.
What do you mean by manually measure the astrometric position ?
Оффлайн LeonidOS
« Ответ #25 : 13 Июл 2010 [00:00:34] »
OK, thanks!
I test this function on "capricornus" image from Unimap package.
Can I calculate coordinates for any object by clicking on it?
    • Skype - larrylart
    • my website
« Ответ #26 : 13 Июл 2010 [02:41:06] »
Yes, double click on it and it should popup a window with details.
I will check the asteroids problem and get back to you.
Larry
Оффлайн LeonidOS
« Ответ #27 : 13 Июл 2010 [11:54:02] »
OK, but perhaps you can create another separate command for calculate coordinates and magnitudes. Standart "double click" work slowly.
And can I measure centroid which not identified by stars catalogues?
    • Skype - larrylart
    • my website
« Ответ #28 : 13 Июл 2010 [12:14:53] »
Yes, I think you right ... a faster way just to get the basic info could be handy - I will add this to the todo list.
Yes, you just need to do the first step (detection) which will calculate the centroids data. Then use the same double click - for now - but in this case it should be faster because it wont fetch online data.
Оффлайн LeonidOS
« Ответ #29 : 13 Июл 2010 [14:13:33] »
OK Larry!
Do you use selfmade object extraction algorithm, or SExtractor?
I'm very interested in Automatic Object Discovery And Trajectory Reconstruction feature, can you provide more detail information about this feature?
Then we will sort all trajectoriesby highest score and add them the group profile.
How Unimap calculate score for the each trajectory? What trajectory have highest score?
    • Skype - larrylart
    • my website
« Ответ #30 : 11 Окт 2010 [01:23:48] »
Version 0.0.2 pre-alpha is now available for download from:
http://larryo.org/work/information/unimap/download.html
Larry
