ВНИМАНИЕ! На форуме начался конкурс - астрофотография месяца СЕНТЯБРЬ!
#!/usr/bin/env python# Gimp-Python - allows the writing of Gimp plugins in Python.# Copyright (C) 1997 James Henstridge <james@daa.com.au>## This program is free software; you can redistribute it and/or modify# it under the terms of the GNU General Public License as published by# the Free Software Foundation; either version 2 of the License, or# (at your option) any later version.## This program is distributed in the hope that it will be useful,# but WITHOUT ANY WARRANTY; without even the implied warranty of# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the# GNU General Public License for more details.## You should have received a copy of the GNU General Public License# along with this program; if not, write to the Free Software# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
from gimpfu import *import timegettext.install("gimp20-python", gimp.locale_directory, unicode=True)
def foggify(img, layer, name, colour, turbulence, opacity): gimp.context_push() img.undo_group_start() if img.base_type is RGB: type = RGBA_IMAGE else: type = GRAYA_IMAGE fog = gimp.Layer(img, name, layer.width, layer.height, type, opacity, NORMAL_MODE) fog.fill(TRANSPARENT_FILL) img.add_layer(fog, 0) gimp.set_background(colour) pdb.gimp_edit_fill(fog, BACKGROUND_FILL) # create a layer mask for the new layer mask = fog.create_mask(0) fog.add_mask(mask) # add some clouds to the layer pdb.plug_in_plasma(img, mask, int(time.time()), turbulence) # apply the clouds to the layer fog.remove_mask(MASK_APPLY) img.undo_group_end() gimp.context_pop()
register( "python-fu-foggify", N_("Add a layer of fog"), "Adds a layer of fog to the image.", "James Henstridge", "James Henstridge", "1999,2007", N_("_Fog..."), "RGB*, GRAY*", [ (PF_IMAGE, "image", "Input image", None), (PF_DRAWABLE, "drawable", "Input drawable", None), (PF_STRING, "name", _("_Layer name"), _("Clouds")), (PF_COLOUR, "colour", _("_Fog color"), (240, 180, 70)), (PF_SLIDER, "turbulence", _("_Turbulence"), 1.0, (0, 10, 0.1)), (PF_SLIDER, "opacity", _("Op_acity"), 100, (0, 100, 1)), ], [], foggify, menu="<Image>/Filters/Render/Clouds", domain=("gimp20-python", gimp.locale_directory) )
main()
