Кстати, иранский спутник пошел со второго раза? В КНДР, imho, работа над ошибками каждый раз затягивается из-за нищеты.
North rocket count down…Government ' Flight setup ' Thrust 2009 April 04th 00:15 [The anchor the [thu] which carries on shoulder] Rocket firing of North Korea is early and (4th) rises with the qualitative thing today and tomorrow (5th) to accomplish is forecast and the feeling of tension is becoming larger. The government the diplomatic security department rushed meantime prepares a scenario by counter-measure to flight setup. Journalist who will be a sincerity reports. [Journalist] North Korea is quick and today or tomorrow is observed will fire the rocket. One well-informed person of the government seems with the fact that the rocket fuel implantation almost ends and revealed that the possibility which will fire tomorrow is big. This well-informed person forecast but the rocket fires with the fact that the weather of the Hamgyong-Bukdo anhydrous simple interest which has the rocket launching site will put the cloud weekend to, the excessiveness is not said to analysis of information authorities. In order for North Korea to use the oxidizer of nitric acid channel with the fuel after fuel implanting firing must come to accomplish is analysis inside 3~4 days. Consequently the government prepared the scenario by counter-measure to relate with rocket firing of North Korea and into the readiness which is real entered. The government when becoming known with case and the missile which will be confirmed as the artificial satellite, and when the judgment does not become, divided with etc. 3 kind scenario and prepares a relation countermeasure electrolysis with the fact that came. The foreign affairs department led and immediately rocket firing of North Korea is confirmed the United States, after tuning the different view of relation country of Japanese etc. and, name electrolysis with the fact that will reveal an opinion came. Also PSI formal participation etc. is a WMD non-proliferation conception declaration investigates the fact that will do. * Interview: Door [thay] zero/foreign affairs department spokesman - " North Korea is made to shoot the missile and the fact that participates actively in PSI the whole surface investigates. Currently with the interagency is in the process of discussing about problem. " Meantime, Korean Executive Presidential Mansion and Ministry of Foreign Affairs and Trade, Ministry of Unification and the Ministry of National Defense etc. diplomatic security department entered into a semiretirement setup. These department missile situation countermeasure half the United States, with Japanese etc. circumference country rocket firing trend of North Korea with a real-time maintains the close coordination setup in the center and is grasping.
ООН, 4 апр - РИА Новости, Дмитрий Горностаев. Пуск северокорейской ракеты ожидается около 06.00 по московскому времени в субботу, сообщил РИА Новости дипломатический источник в ООН.По его словам, в этом случае Совет безопасности ООН соберется в субботу на экстренное заседание по инициативе Японии и США."Если запуск ракеты состоится, как ожидается, сегодня в 22 часа по нью-йоркскому времени (06.00 мск в субботу), то в субботу, скорее всего, в 15 часов (23.00 мск) состоится экстренная встреча Совета безопасности ООН", - сказал собеседник агентства.Власти КНДР заявляли о готовности осуществить пуск ракеты "Ынха-2" ("Млечный путь") в период с 4 по 8 апреля.
Цитата: krypton от 01 Апр 2009 [00:02:15]Кроме того, на снимке, кажется, просматриваются тени площадок обслуживания 1, 2-й ступеней и ГЧ?Два уровня обслуживания я точно вижу. (У Сафира их кстати штук шесть было)
Запуск северокорейской ракеты, который ожидался 4-5 апреля, скорее всего, будет перенесен из-за плохой погоды на несколько дней позже - 6-8 апреля. Об этом заявили южнокорейские эксперты, ссылаясь на ожидаемый в эти дни прогноз погоды. Напомним, что КНДР заявила о своем намерении запустить в период с 4 по 8 апреля ракету-носитель с экспериментальным спутником связи. Ожидалось, что испытания пройдут в первые два дня заявленного периода, но теперь, похоже, дату придется скорректировать.Гидрометеоцентр Южной Кореи выдал прогноз, согласно которому в районе ракетного полигона в местечке Мусудан, что на северо-восточном побережье КНДР, 4 апреля ожидается дождь или снег, а 5 апреля небо будет затянуто облаками. Ясная погода, которая считается самой благоприятной для ракетных запусков, будет в том районе с 6 по 10 апреля.Сотрудник южнокорейского НИИ авиакосмических исследований пояснил: "Погода является главным фактором, определяющим конкретное время запуска. Сильный ветер, большая облачность, не говоря уже о снеге или дожде, не подходят для запусков, так как такие условия мешают работе электронного оборудования". В этой связи он высказал мнение, что, если прогноз не изменится, то КНДР будет вынуждена произвести запуск только тогда, когда небо прояснится, то есть 6-8 апреля. Другие местные специалисты высказали схожее мнение, напомнив, что два предыдущих аналогичных запуска КНДР - в 1998 и 2006 годах - не были успешными, поэтому Пхеньян сделает все возможное, чтобы максимально подстраховаться. При этом исследователь НИИ имени короля Сечжона Пэк Хак Сун выразил твердую уверенность в том, что запуск в итоге состоится. "Сейчас для КНДР немыслимо отказаться от своих планов. Это будет означать для нее полную потерю лица", - подчеркнул Пэк.Тем временем с уже стоящей на стартовом столе северокорейской ракеты сняли колпак, который закрывал ее верхнюю часть. Что под ним находится интересует всех. КНДР утверждает, что будет запускать спутник, а ее критики, включая США, Южную Корею и Японию, говорят, что Пхеньян хочет провести испытания боевой баллистической ракеты. Различия заключаются как раз в верхней части. Правда представители южнокорейского правительства, подтвердив, что ракета теперь полностью открыта, затруднились сказать что-либо конкретное по поводу ее верхней части. "Фотографии со спутников показали, что колпак убран, но, является верхняя часть боеголовкой или спутником, мы пока сказать не можем", - заявил в воскресенье южнокорейскому информагентству "Ёнхап" сотрудник в местном правительстве.
КНДР завершила приготовления к запуску спутника связиОфициальные СМИ Северной Кореи утром в субботу объявили, что к запуску ракеты со спутником связи все готово и старт состоится в "ближайшее время", передает Agence France-Presse. Примерное время запуска осталось неизменным - в период с 4 по 8 апреля между 6:00 и 11:00 по московскому времени. По данным южнокорейских военных, в Японское море вышли два военных корабля КНДР, которые будут собирать информацию о полете.
ЦитатаЗапуск северокорейской ракеты, который ожидался 4-5 апреля, скорее всего, будет перенесен из-за плохой погоды на несколько дней позже - 6-8 апреля. Об этом заявили южнокорейские эксперты, ссылаясь на ожидаемый в эти дни прогноз погоды. http://www.rg.ru/2009/03/30/sobkor-zapusk-anons.html
От себя замечу, что в Google Earth видел корабли в море у Мусудан-Ри, так что наблюдения они будут точно проводить.
Цитата: C-300 от 04 Апр 2009 [06:22:26]От себя замечу, что в Google Earth видел корабли в море у Мусудан-Ри, так что наблюдения они будут точно проводить.А снимки какого года?
Сообщение от 30 марта
Цитата: .Jack. от 04 Апр 2009 [06:25:00]Цитата: C-300 от 04 Апр 2009 [06:22:26]От себя замечу, что в Google Earth видел корабли в море у Мусудан-Ри, так что наблюдения они будут точно проводить.А снимки какого года?Да кто её знает? Везде 2009 пишут, но навряд ли.
