A A A A Автор Тема: Журнал наблюдений Тяньгун (Tiangong)  (Прочитано 26563 раз)
Оффлайн Александр Репной
  • Благодарностей: 581
    • Skype - Aleksandr-19901
    • Видимость ИСЗ.
Re: Журнал наблюдений "Тяньгун" и "Шэньчжоу"
« Ответ #100 : 06 Окт 2011 [00:11:04] »
TIANGONG-1 SIGHTINGS: China's first space station, an 8.5-ton experimental module named Tiangong-1 (Heavenly Palace-1), is flying over the United States this week. Last night, Tavi Greiner saw it gliding over Shallotte, North Carolina: http://spaceweather.com/submissions/large_image_popup.php?image_name=Tavi-Greiner-2011Oct04Tiangong1TG_1317777673.jpg "The Tiangong 1 passed between Cygnus and Cassiopeia shortly after sunset," says Greiner. "It was surprisingly bright, easily seen with the unaided eye."
Readers, check Spaceweather's Satellite Tracker for sighting opportunities in your hometown. You can also turn your smartphone into a Tiangong-1 tracker by downloading the Simple Flybys app.
more images: from Jim Saueressig II of Burlington, Kansas; from Justin Cowart of Carbondale, Illinois; from Stuart McDaniel of Lawndale, North Carolina;
http://www.spaceweather.com/
48.6657°N - 33.1137°E, 155m.
UTC + 2(3):00.
    • Видимость ИСЗ.
UTC + 2(3):00.
Оффлайн Звездочёт
  • Благодарностей: 16
  • Trollface рулит.
    • Сообщения от Звездочёт
« Ответ #102 : 17 Ноя 2011 [10:25:11] »
China's new space station, the Tiangong 1, is making a series of evening flybys over the United States this week. Sky watchers who go out to see it might spot a second spacecraft. The unmanned Shenzhou 8 probe is traveling alongside Tiangong 1 as it concludes maneuvers designed to test the craft's rendevous and docking capabilities. Check the Satellite Tracker or your smartphone for local flyby times.
On Nov. 14th, David Blanchard watched the docked spacecraft glide past the Andromeda galaxy in the crystal-clear skies of Flagstaff, Arizona:
Рефрактор Сelestron 70/700
    • Видимость ИСЗ.
« Ответ #103 : 17 Ноя 2011 [17:48:36] »
http://spaceweather.com/submissions/large_image_popup.php?image_name=David-Blanchard-2011_1114_DBP_Tiangong_1321346891.jpg
UTC + 2(3):00.
    • Видимость ИСЗ.
« Ответ #104 : 17 Ноя 2011 [22:25:14] »
Сегодня вечером наблюдал в бинокль один видимый пролет орбитального модуля Tiangong 1 в 1546 UTC или в 1746 по киевскому времени на высоте 17° в ВК над южным горизонтом. Блеск Tiangong 1 оценил в 3m без вариаций, модуль также был виден и невооруженным глазом. Вчера вечером у меня была одна видимость КК Shenzhou 8 после расстыковки с модулем Tiangong 1, но мне к сожалению не удалось его отнаблюдать из-за пасмурной погоды.
« Последнее редактирование: 23 Ноя 2011 [20:28:19] от Александр Репной »
UTC + 2(3):00.
    • Видимость ИСЗ.
UTC + 2(3):00.
    • Видимость ИСЗ.
UTC + 2(3):00.
    • Видимость ИСЗ.
« Ответ #107 : 23 Ноя 2011 [20:34:38] »
Сегодня вечером наблюдал в бинокль один видимый пролет орбитального модуля Tiangong 1 в 1544 UTC или в 1744 по киевскому времени на высоте 21° в ВК над южным горизонтом. Блеск Tiangong 1 оценил в 4m без вариаций до входа в тень.
Сегодня вечером наблюдал в Yukon 30x50 также один видимый пролет SZ-8 MODULE в 1609 UTC или в 1809 по киевскому времени на высоте 14° в ВК над юго-западным горизонтом. Блеск SZ-8 MODULE оценил в 6.5m без вариаций.
UTC + 2(3):00.
    • Видимость ИСЗ.
« Ответ #108 : 15 Дек 2011 [21:03:07] »
Утром 12 декабря наблюдал при помощи инструмента Yukon 30x50 один пролет орбитального модуля Tiangong 1 в 0326 UTC или в 0526 по киевскому времени на высоте 12° в ВК над юго-восточным горизонтом. Блеск Tiangong 1 оценил в 5m без вариаций, наблюдал станцию около минуты.
Утром 12 декабря наблюдал при помощи инструмента Yukon 30x50 один пролет SZ-8 MODULE в 0413 UTC или в 0613 по киевскому времени на высоте 18° в ВК над южным горизонтом. Блеск SZ-8 MODULE оценил в 6m без вариаций, наблюдал орбитальный отсек около минуты.
UTC + 2(3):00.
    • Видимость ИСЗ.
« Ответ #109 : 19 Дек 2011 [20:41:18] »
Кевин Феттер снял пролет орбитального модуля Tiangong 1: 37820-2.wmv.
UTC + 2(3):00.
    • Видимость ИСЗ.
UTC + 2(3):00.
    • Видимость ИСЗ.
« Ответ #111 : 23 Мая 2012 [21:58:31] »
Утром 21 и 22 мая наблюдал орбитальный модуль Tiangong 1 в 0045 UTC и 0109 UTC. При первом пролете, который наблюдался еще в сумерках, Tiangong 1 был довольно ярким, блеск порядка 2.5m без вариаций, во втором пролете, который наблюдался уже на светлом небе. Блеск Tiangong 1 оценил в 2m без всяких изменений в виду светлого неба. Высота спутника в ВК была 17° и 23° соответственно.
UTC + 2(3):00.
    • Видимость ИСЗ.
UTC + 2(3):00.
    • Видимость ИСЗ.
UTC + 2(3):00.
Оффлайн Okub62
  • Благодарностей: 601
    • Сообщения от Okub62
« Ответ #114 : 20 Июн 2012 [13:20:14] »
Надо же было так их подловить.
С уважением. Олег
    • Видимость ИСЗ.
« Ответ #115 : 23 Июл 2012 [20:09:17] »
Вчера вечером 22 июля в поселке Лазурном, Херсонская область, Украина я наблюдал в бинокль один пролет Tiangong 1 и орбитального китайского модуля SZ-9 MODULE. Пролет SZ-9 MODULE состоялся в 2200 по киевскому времени или 1900 UTC. Блеск SZ-9 MODULE не превышал 3.5m, вспышек не было. Пролет Tiangong 1 состоялся в 2215 по киевскому времени или в 1915 UTC. Блеск Tiangong 1 также не превышал 3.5m, вспышек не было.
UTC + 2(3):00.
    • Видимость ИСЗ.
« Ответ #116 : 24 Июл 2012 [15:47:04] »
Вариации блеска (вращение) были - или только за счёт изменения фазового угла?
Нет, блеск SZ-9 MODULE был полностью стабилен. По крайне мере сколько я его наблюдал, то пока не видел изменения в яркости.
UTC + 2(3):00.
    • Видимость ИСЗ.
« Ответ #117 : 26 Июл 2012 [21:44:01] »
Блестеть там и нечему, панели сняты.
Почему нечему? Там вроде бы есть какие-то блестящие штучки.
UTC + 2(3):00.
    • Видимость ИСЗ.
« Ответ #118 : 26 Июл 2012 [22:30:11] »
А вот, помимо панелей, даёт вспышки на "Кихоулах", понять сложно.
Да, тут может что угодно давать блики.
UTC + 2(3):00.
    • Видимость ИСЗ.
« Ответ #119 : 26 Июл 2012 [23:36:16] »
Сегодня вечером уже у себя дома наблюдал пролет SZ-9 MODULE и Tiangong 1 в 1838 UTC и в 1929 UTC соответственно. Блеск у SZ-9 MODULE и Tiangong 1 был сегодня примерно одинаков. Оценил их яркость в 3m без вариаций. В целом оба пролета были благоприятными.
Ну, ну это как бы не "Кихоул", а IMEWS.
Из серии разведывательных спутников.
UTC + 2(3):00.
