Помоему они сохраняются у вас на флэшке
Проверьте "Readout mode"
Цитата: SAE от 03 Фев 2010 [08:37:45]Проверьте "Readout mode"Поменял на RAW color все заработало.Спасибо.
там же идет последний пункт - типа raw hard drive
Version 5.09Observatory Control: Allow "Sync to solved position" from Catalog tab. Focuser tab now shows position and temperature while compensation active, if available from the driver. Image Display: Added an adjustable center gap to the Crosshair display. Screen Stretch now includes new option to ignore hot pixels when auto-calculating Min/Max values. Calibration: Added the ability to apply different bad pixel maps for each calibration group. Remove Bad Pixels: Now automatically adjusts for subframes. Stack: Can now export image alignment parameters. Fixed a rare crash. Two star alignment now tags the circular cursor with the star number, to reduce confusion during tagging. Orion: Added support for Parsec 8300M and 8300C cameras. New DLLs for the StarShoot Autoguider were supplied by Orion. Nikon: added support for new models. Starlight Xpress: Added support for dithering when running non-SX main camera. Fixed an intermittent crash on disconnecting SX AO. SBIG: Fixed glitch in AO driver fan enable control. Changed method of camera model enumeration, to allow for differentiation between ST-402 and ST-8300.Miscellaneous: Prevent Set Calibration from creating a master frame for an empty group. Improved autosave sequence time estimate. Image processing only version now supports scripting. Autoguider output control now releases when changing ports or disconnecting camera. Fixed problem with focus offsets for autoguider. Minor updates to Apogee driver. Fixed problem in Annotate command. Fixed problem in Open Photometry File command. Fixed bugs in ASCOM camera driver cooler control and ASCOM Direct pulse guiding.
Зафиналили и зарелизили Maxim DL 5.09 final версию
скажите пожалуйста, какая версия максим дл идёт под вин7. 5.02-толком не работает
Цитата: Глеб Комаров от 18 Июл 2010 [16:45:17]скажите пожалуйста, какая версия максим дл идёт под вин7. 5.02-толком не работает Толком это как? 5.09 Win7-32 всё пучком.
5.02 под висту в экспертный режим не заходит. Кряк под нее не работает.
Рабочие кряки дают тут.
Нужен дополнительный затвор на камеру.
скрипт который блокирует подачу управляющих команд на монтировку и прерывает процесс съемки.
