Для тех, кто пользует - вчера вышло новое обновление 2.0.29.
Извиняюсь, что привожу описаловку на аглицком, но пользователям д.б. понятно.
![Wink ;)](https://astronomy.ru/forum/Smileys/kolobok/wink.gif)
"Full distribution in English
Size is 12.6 megabytes
December 24 , 2008 Download
New features in version 2.0.29
- Native integration of the GCVS catalogue (General Catalogue of Variable Stars). This catalogue is now fully integrated with the standard distribution of C2A.
- Additional options have been added to Deep Sky object filter dialog box. It is now possible to set filters on object magnitude and size. The key * is a shortcut to remove all the filters on deep sky objects (except the automatic magnitude filter if it is set).
- It is now possible to copy in the Clipboard the coordinates and magnitude of the stars that have been solved through the Astrometric process with PinPoint (this is done through a mouse right click on the solved object in the image processing window).
- The utility Reset.exe has been modified and now allow the user to delete the file where C2A stores it asteroid and come orbital elements (version 2.3).
- The current date is used as the default orbital element epoch when no date is provided in the imported orbital elements.
- The SAO catalogue has been updated (it was included numerous errors on star distances).
- A module to perform image acquisition has been added in the image processing window. Only the Maxim DL interface is supported at the moment.
- A King process has been implemented in the image processing window to facilitate the polar alignment of a mount. This requires to have Maxim DL installed on the same platform as C2A."
С уважением,
Олег.
