Подскажите плиз. После обновления пикса на HDD сожралось 15гб места... Терминтор после обновления работал нормально.
После обновления плагинов он перестал работать... Как я понял нуждается в обновлении какого-то файла?
Можно пояснительную бригаду? Пожалуйста.
Текст ошибки:
*** Error: ERROR: MLLoad() could not load tensorflow graph. Error 3: Converting GraphDef to Graph has failed. The binary trying to import the GraphDef was built when GraphDef version was 440. The GraphDef was produced by a binary built when GraphDef version was 1645. The difference between these versions is larger than TensorFlow's forward compatibility guarantee. The following error might be due to the binary trying to import the GraphDef being too old: NodeDef mentions attr 'explicit_paddings' not in Op output:T; attr=T:type,default=DT_FLOAT,allowed=[DT_HALF, DT_BFLOAT16, DT_FLOAT, DT_DOUBLE, DT_INT32, DT_INT64, DT_UINT8, DT_INT16, DT_INT8, DT_UINT16, DT_QINT8]; attr=ksize:list(int),min=4; attr=strides:list(int),min=4; attr=padding:string,allowed=["SAME", "VALID"]; attr=data_format:string,default="NHWC",allowed=["NHWC", "NCHW", "NCHW_VECT_C"]>; NodeDef: {{node BXT/max_pooling2d_14/MaxPool}}. (Check whether your GraphDef-interpreting binary is up to date with your GraphDef-generating binary.).
