ВНИМАНИЕ! На форуме начался конкурс астрофотография месяца - СЕНТЯБРЬ!
Парашют для Марса: http://news.rambler.ru/25347344/
We present VIDE, the Void IDentification and Examination toolkit, an open-source Python/C++ code for finding cosmic voids in galaxy redshift surveys and N-body simulations, characterizing their properties, and providing a platform for more detailed analysis. At its core, VIDE uses a greatly enhanced version of ZOBOV (Neyinck 2008) to calculate a Voronoi tessellation for estimating the density field and a watershed transform to construct voids. The watershed levels are used to place voids in a hierarchical tree. VIDE provides significant additional functionality for both pre- and post-processing: for example, VIDE can work with volume- or magnitude-limited galaxy samples with arbitrary survey geometries, or dark matter particles or halo catalogs in a variety of common formats. It can also randomly subsample inputs and includes a Halo Occupation Distribution model for constructing mock galaxy populations. VIDE outputs a summary of void properties in plain ASCII, and provides a Python API to perform many analysis tasks, such as loading and manipulating void catalogs and particle members, filtering, plotting, computing clustering statistics, stacking, comparing catalogs, and fitting density profiles. VIDE has been in development for several years and has already been used to produce a wealth of results, which we summarize in this work to highlight the capabilities of the toolkit. VIDE is publicly available at this http URL and this http URL
Мы представляем Vide , Пустоты выявление и изучение инструментарий , с открытым исходным кодом на языке Python / C + + код для поиска космических пустот в галактических красного смещения обследований и моделирования N- тела , характеризующие их свойства , и предоставляет платформу для более детального анализа . По своей сути, VIDE использует значительно улучшенную версию Зобов ( Neyinck 2008 г.) для расчета тесселяции Вороного для оценки поля плотности иводораздела построить пустоты . Уровни водораздел используются для размещения пустоты в виде иерархического дерева . VIDE обеспечивает значительную дополнительную функциональность для обоих пред-и пост - обработки : например, VIDE может работать с объемом - или величины ограниченной образцов галактик с произвольными геометрий опроса, или частиц темной материи или гало каталогов в различных распространенных форматов . Он может также случайно субсемплировать входы и включает в себя модель Halo Профессия Distribution построения макет населения галактик . VIDE выводит сводку недействительными свойств в простом ASCII , а также предоставляет API Python для выполнения многих задач анализа , такие как загрузка и манипулирования недействительными каталоги и членов частиц , фильтрации , построение , вычисления статистических данных кластеризации , укладки, сравнивая каталоги и фитингов профилей плотности . VIDE находится в разработке уже несколько лет и уже используется для производства богатство результатов, которые мы суммируем в этой работе , чтобы выделить возможности инструментария . VIDE находится в открытом доступе на этом HTTP URL , и этот HTTP URL
Астрономы нашли кандидата в объекты Ландау-Торна-Житковhttp://lenta.ru/news/2014/06/06/landau/
arxiv:1406.0001 Обнаружение кандидата в объекты Торна-Житков в Малом Магеллановом облаке (Discovery of a Thorne-Zytkow object candidate in the Small Magellanic Cloud)Authors: Emily M. Levesque et al.Comments: 5 pages, 3 figures; accepted for publication in MNRAS LettersОбъекты Торна-Житков, это ожидаемый (но пока - гипотетический) класс источников, являющихся продуктом эволюции двойных систем: нейтронная звезда оказывается внутри звезды-гиганта. Их пытаются искать по особенностям химического состава. Иногда появляются заявления об обнаружении хороших кандидатов. Вот очередное. Важно, что это действительно наиболее сильный на данный момент кандидат.Речь идет о звезде HV 2112 в Малом Магеллановом облаке. У нее обнаружен ряд химических аномалий, которые проще всего объяснить, предположив, что это объект Торна-Житков, т.е., что внутри сидит нейтронная звезда. http://xray.sai.msu.ru/~polar/sci_rev/314.html#arxiv/1406.0001
