ВНИМАНИЕ! На форуме началось голосование в конкурсе - астрофотография месяца МАРТ!
гибридную звезду
Цитата: Oleg_P от Сегодня в 10:28:24гибридную звездучто это?
Тут интересен тот факт, что такие процессы и коллапсы "на пальцах" и мысленно уже никак не представить, нужны сложные моделирования с учетом квантовой хромодинамики. И результаты порой довольно неочевидные,
Подкласс компактных объектов с кварковым ядром
В таких моделях что придумаешь то и получишь. Как тренировка мозгов в математике хорошо. Но в практическом плане подставлять в алгоритм мифические компоненты не есть гут.
Что такое кварковое ядро?
Quark matter or QCD matter (quantum chromodynamic) refers to any of a number of hypothetical phases of matter whose degrees of freedom include quarks and gluons, of which the prominent example is quark-gluon plasma.[1] Several series of conferences in 2019, 2020, and 2021 are devoted to this topic.[2][3][4]Quarks are liberated into quark matter at extremely high temperatures and/or densities, and some of them are still only theoretical as they require conditions so extreme that they cannot be produced in any laboratory, especially not at equilibrium conditions. Under these extreme conditions, the familiar structure of matter, where the basic constituents are nuclei (consisting of nucleons which are bound states of quarks) and electrons, is disrupted. In quark matter it is more appropriate to treat the quarks themselves as the basic degrees of freedom.In the standard model of particle physics, the strong force is described by the theory of QCD. At ordinary temperatures or densities this force just confines the quarks into composite particles (hadrons) of size around 10−15 m = 1 femtometer = 1 fm (corresponding to the QCD energy scale ΛQCD ≈ 200 MeV) and its effects are not noticeable at longer distances.However, when the temperature reaches the QCD energy scale (T of order 1012 kelvins) or the density rises to the point where the average inter-quark separation is less than 1 fm (quark chemical potential μ around 400 MeV), the hadrons are melted into their constituent quarks, and the strong interaction becomes the dominant feature of the physics. Such phases are called quark matter or QCD matter.
A quark star is a hypothetical type of compact, exotic star, where extremely high core temperature and pressure has forced nuclear particles to form quark matter, a continuous state of matter consisting of free quarks.
Цитата: Oleg_P от 28 Сен 2021 [14:36:32]Подкласс компактных объектов с кварковым ядромЧто такое кварковое ядро?
Вся физика, это по сути создание моделей. К астрофизике это относится еще в большей степени.У вас есть конкретные претензии к модели в данной статье? Или вы против таких моделирований в целом?
Я против представления моделей как истинный физический процесс. Моделируйте, но позиционируйте именно как теоретическая модель.
Если модель согласуется с измерениями или предсказывает их, то хорошо, нет изменяем, или строим другую.
Термояд в солнце - это модель,
эта модель показала, что есть различия например в спектре гравитационных волн при коллапсе,
давайте камерад привидите мрнепримеры какие нужно провести измерения для того что бы ущнать состояние нейтронной звезды...
уже лучше... а спектр гравивол мы можем мерять с достаточной для выбора гипотез точностью?
GW amplitudes reach A+ ∼ 250 cm and the strong emission lasts about 4 ms after the second bounce time.
И никто не представляет компьютерное моделирование как "истинный физический процесс". Это вы как-то альтернативно прочитали\поняли.
Хотя более правдоподобно что то обычное. Пара нейтронных звезд или белых карликов, и гораздо ближе.
И спектр гравитационных волн наверно что у слияния ЧД, что у слияния нейтронных звезд,
Вам известны спектры слияния чд? Напишите статью. С практическим наблюдением. Всех благ.
По факту выходит наоборот. Взять регистрацию гравитационных волн. Факт есть. Но приписали слияние чд, построили мультик компьютерный, подогнали под форму графика полученного. И почти все население планеты убеждено что чд сливались, на расстоянии миллионы световых лет. Хотя более правдоподобно что то обычное. Пара нейтронных звезд или белых карликов, и гораздо ближе.
Кварки пока как бы математический прием. Не более.
Но как понимаю, для проверок таких моделей надо, как можно лучше получить данные по массам, магнитным полям и температуре, так же хорошо поможет измерения как изменяется температура со временем, от возраста нейтронной звезды.
Особенно уделить внимание для пульсарам и/или нейтронных звезд массами от 2х солнечных, для которых модели показывают возможное наличие кваркового вещества в ядре.
ОТО придумали давно и формы сигналов рассчитаны давно. Тем более куча статей и расчетов было за последние лет 10. А за последние годы было зарегистрировано много событий.
Цитата: leon10010 от 30 Сен 2021 [09:53:16]Кварки пока как бы математический прием. Не более.вообще-то нетнобелевку за подтверждение их существования напрасно ли дали?
Поскольку вопрос не требует академических источников, думаю будет достаточно пары цитат.
