Dear astro friends,
I recently bought a TAL-2 Newton reflector telescope and tried to collimate it because it has not been used for over 20 years. I noticed that the secondary mirror could not come to the correct position, just below the focuser. See the picture ... When the secondary mirror is moved to the maximum to the left, it still needs to be moved a little more to be exactly in the middle below the focuser. In this position, the central screw is fully screwed on and can no longer be moved backwards ... Other components such as the secondary carrier (spider) or the focuser cannot be moved but are fixed. I wonder if any of you have had similar experiences with this telescope and how this can be solved?
Thanks in advance for the help,
Slobodan Nikolic, Serbia
