A A A A Автор Тема: Влияет ли тип стекла призм на разрешающую способность?  (Прочитано 2359 раз)
Оффлайн alex183Автор темы
  • Благодарностей: 8
    • Сообщения от alex183
Приветствую!
Везде пишут что призмы из Вак-4 дают более яркую и контрастную картинку чем ВК-7. Т.е. по цвету и контрастности Вак-4 превосходит ВК-7. А вот по разрешающей способности (напр. разделить черные линии на белом фоне) есть ли разница между этими сортами стекла?
БПЦ 20х50 СОМЗ мод. "Беркут" 99 г.в.
Самодельная ЗТ 45х60 галилеевской системы
ЗТ Sturman 20-60x60
Оффлайн Boris Green
  • Благодарностей: 85
    • Сообщения от Boris Green
https://fishesandpie.blogspot.com/2011/12/bak4-vs-bk7-prisms.html  Пишут про дисперсию и критический угол отражения.
https://www.cloudynights.com/topic/681830-lets-talk-about-diagonals/?p=9761322
"N-BaK4 n=1.5688 nud=55.97 alpha=0.0017 cm-1
N-BK7   n=1.5168 nud=64.17 alpha=0.0021 cm-1
I get the critical angles are 39.60o and 41.25o respectively. We do however need to consider what happens to light when it enters the prism (the light bends toward the normal). I did a quick calculation and came up with an expression for the critical f-number -
D/F = 2 tan( sin-1(n sin(45o - thetaC))
From this I get that - on axis - a BaK4 prism is usable to f/3.35 and BK7 is usable to f/5.01. This suggests that neither should exhibit issues with the critical angle when used at sensible telescope f-ratios.
Next, I'll consider attenuation. Let's assume a clear aperture of 46mm, the path length through a 90 degree prism is 46mm or 4.6 cm This means the attenuation is 0.78% and 0.96% respectively, or about 0.008 and 0.01 magnitudes. It would seem attenuation through the material is negligible. Of course, you still lose a little at the surfaces which is why the coatings are so critical.
Finally, there's dispersion. Since BaK4 has more dispersion, let's consider its behaviour from 350-650 nm. The refractive index changes from 1.60 to 1.565. The effective path length is thus 46*1.6 mm at 350nm and 46*1.565 at 650nm. This is a change of 1.6 mm. At f/7, it contributes to a blur circle of .8/7 or 115 microns.This is certainly visible if your eyes are operating in their photopic range. Under mesopic conditions, the blur circle gets much smaller - perhaps 30 microns. It should still be visible but I'd expect it to be a lot less obvious. To be honest, this result actually surprises me. I use a prism and I've never noted it."
Оффлайн Lex1
  • Благодарностей: 214
    • Сообщения от Lex1
Если экономят на стекле призм (а оно недорогое), то и всё остальное будет не лучшего качества.
Надо полагать оно накладывается на хромоту объективов.
  • Благодарностей: 8
Короче говоря, стекло ВК-7 для астрономических приборов неприемлемо. Но для наземных гляделок сойдет.
ЗТ Sturman 20-60x60
Оффлайн Boris Green
Не на просвет, а в качестве подложки используют.
"Optical glass BK7 mirror blank"
http://www.gs-telescope.com/content.asp?id=126
Оффлайн Lex1
    • Сообщения от Lex1
Эм, BK7+F2 классика ахроматов
Оффлайн Алексей Юдин
  • Благодарностей: 1156
    • Сообщения от Алексей Юдин
Приветствую!
Бинокли не работают на дифракционном пределе, поэтому спад дифракционной ЧКХ из-за аподизации нарушением ПВО значим не будет.
Это лучший по качеству сорт стекла.
  • Благодарностей: 8
А оборачивающие призмы телескопов из какого стекла делают?
ЗТ Sturman 20-60x60
В телескопах не применяют оборачивающие призмы. Если вести речь о массовых несуразицах, комплектуемых призмой Амичи/Шмита, то там BK7 идёт на-ура, поскольку углы падения в призмах с крышей весьма острые.
Оффлайн dae33
  • Благодарностей: 352
    • Сообщения от dae33
Обзор бинокля с призмами из BK7. Отличный бин
Vixen SG 6.5x32
Оффлайн TM307
  • Благодарностей: 453
    • Сообщения от TM307
В 45* и 90* призмах - углы недалеко от 90* ушли.
« Последнее редактирование: 27 Авг 2020 [17:43:25] от TM307 »
Оффлайн Lex1
    • Сообщения от Lex1
Важен угол падения (между отражающей поверхностью и лучом), а он везде меньше 45 градусов.
Оффлайн Gleb1964
  • Благодарностей: 318
    • Сообщения от Gleb1964
Но если не применять специальных покрытий на крыше призмы, то длина хода для разных поляризаций будет разной и набежит эллиптическая поляризация. Причем, поляризация будет разной на половинках зрачка, разделенных линией крыши, а значит, дифракционное изображение существенно пострадает. Это важно для телескопа, а для бинокля, не работающего на дифракционном пределе, это несущественно.
« Последнее редактирование: 27 Авг 2020 [23:43:47] от Gleb1964 »
Оффлайн ekvi
  • Благодарностей: 419
    • Сообщения от ekvi
Разрешающая способность определяется остаточной волновой ошибкой всего прибора. Призма вносит положительную ошибку. Если в расчёте призма учтена, то разные стёкла должны давать одинаковое разрешение. Оптические стёкла по качеству бывают разные, но пузыри и включения осаживают только яркость, на разрешение влияют только свили. Как отметил А. Юдин, стекло К8 (заруб. аналог BK7) по технологии производства - самое отработанное.
Но самое главное - окулярные призмы стоят почти в фокусе, и их влияние на разр.способность ничтожно.
  • Благодарностей: 8
Ну вот в Селестроне 909 надевается такая блямба под 90 градусов дающая полностью прямое изображение. Там ВК-7 внутри или ВАК-4 ?
ЗТ Sturman 20-60x60
Оффлайн nolv
  • Благодарностей: 197
    • Сообщения от nolv
CDGM H-Bak4 там, инфа 100%
Оффлайн TM307
Втречал такое мнение, что BAK-4 больше увеличивает хроматизм объектива чем BK-7 из-за разных коэффициентов преломления (правда или нет - решать вам).
Оффлайн Boris Green
Ответ #1, последний абзац. Там расчет. Да, хроматизм есть, но чаще его не заметно. И ответ #2.
Оффлайн nitar
  • Благодарностей: 20
    • Сообщения от nitar
У Слюсарева в Расчете оптических систем, есть глава о хроматизме вносимом  призмами. Если ход в призмах занимает все расстояние от объектива до окуляра, то объектив должен быть на треть недоисправлен по хроматизму положения. И соответственно меньше ход, меньше влияние, больше дисперсия у стекла призм, больше влияние. Объективы биноклей (без призм) заметно хромотят в красной области.
« Последнее редактирование: 28 Авг 2020 [13:25:06] от nitar »
  • Благодарностей: 8
Ну вот, значит не с проста туда Вак-4 поставили. Хотя на f/10 могли бы и ВК-7 поставить, они же на длинном фокусе не дают ромбиков. Но нет, почему-то поставили Вак-4...
« Последнее редактирование: 28 Авг 2020 [19:19:35] от alex183 »
ЗТ Sturman 20-60x60
