A A A A Автор Тема: Новости проекта ISON (ПулКОН)  (Прочитано 93759 раз)
Оффлайн kismetАвтор темы
  • Благодарностей: 810
    • Сообщения от kismet
Re: Новости проекта ISON (ПулКОН)
« Ответ #2820 : 05 Июн 2017 [23:24:25] »
http://adsabs.harvard.edu/abs/2017AJ....153..270V
Vokrouhlický, David; Pravec, Petr; Ďurech, Josef; Hornoch, Kamil; Kušnirák, Peter; Galád, Adrián; Vraštil, Jan; Kučáková, Hana; Pollock, Joseph T.; Ortiz, Jose Luis; Morales, Nicolas; Gaftonyuk, Ninel M.; Pray, Donald P.; Krugly, Yurij N.; Inasaridze, Raguli Ya.; Ayvazian, Vova R.; Molotov, Igor E.; Colazo, Carlos A. Detailed Analysis of the Asteroid Pair (6070) Rheinland and (54827) 2001 NQ8. The Astronomical Journal, Volume 153, Issue 6, article id. 270, 17 pp. (2017).
The existence of asteroid pairs, two bodies on similar heliocentric orbits, reveals an ongoing process of rotational fission among asteroids. This newly found class of objects has not been studied in detail yet. Here we choose asteroids (6070) Rheinland and (54827) 2001 NQ8, the most suitable pair for an in-depth analysis. First, we use available optical photometry to determine their rotational state and convex shapes. Rotational pole of Rheinland is very near the south ecliptic pole with a latitude uncertainty of about 10°. There are two equivalent solutions for the pole of 2001 NQ8, either (72°, −49°) or (242°, −46°) (ecliptic longitude and latitude). In both cases, the longitude values have about 10° uncertainty and the latitude values have about 15° uncertainty (both uncertainties). The sidereal rotation period of 2001 NQ8 is 5.877186 ± 0.000002 hr. Second, we construct a precise numerical integrator to determine the past state vectors of the pair's components, namely their heliocentric positions and velocities, and orientation of their spin vectors. Using this new tool, we investigate the origin of the (6070) Rheinland and (54827) 2001 NQ8 pair. We find a formal age solution of 16.34 ± 0.04 kyr. This includes effects of the most massive objects in the asteroid belt (Ceres, Pallas, and Vesta), but the unaccounted gravitational perturbations from other asteroids may imply that the realistic age uncertainty is slightly larger than its formal value. Analyzing results from our numerical simulation to 250 kya, we argue against a possibility that this pair would allow an older age. Initial spin vectors of the two asteroids, at the moment of their separation, were not collinear, but tilted by .
« Ответ #2821 : 06 Июн 2017 [11:49:51] »
Успешные наблюдения гамма-всплеска в Абастумани на 70-см АС-32:
TITLE:   GCN CIRCULAR
NUMBER:  21203
SUBJECT: GRB 170604A: AbAO optical observations
DATE:    17/06/05 15:48:31 GMT
E. Mazaeva (IKI),  R. Inasaridze (AbAO), A. Pozanenko (IKI), A. Volnova
(IKI),  V. Ayvazian  (AbAO),  O. Kvaratskhelia (AbAO), G. Inasaridze
(AbAO), I. Molotov (KIAM), report on behalf of larger GRB follow-up
collaboration:
We observed the field of the Swift  GRB 170604A (Page et al., GCN 21191)
  with AS-32 (0.7m) telescope of Abastumani Observatory starting on
June, 04 (UT)  23:52:07. We obtained several unfiltered images of the
field.   Within enhanced XRT error circle  (Page et al., GCN   21196) we
detected the afterglow (Izzo et al, GCN 21192; Izzo et al, GCN 21197;
Schady, , GCN 21200). Preliminary photometry of the afterglow is following
Date        UT start   t-T0     Filter Exp.   OT   Err UpLim (3 sigma)
                       (mid, days)       (s)
2017-06-04 23:52:07   0.19950   CR     5*60  19.13 0.18  21.0
2017-06-05 00:00:50   0.20675   CR     7*60  19.23 0.16  21.1
2017-06-05 00:13:02   0.21885   CR    13*60  19.30 0.22  20.6
Photometry is based on nearby USNO-B1.0 stars (R2 magnitudes)
USNO-B.1_id    R2
0746-0830331 14.71
0746-0830367 14.76
0746-0830438 15.14
0746-0830455 14.77
0747-0821123 14.60
« Ответ #2822 : 06 Июн 2017 [12:13:57] »
Molotov I., Voropaev V., Borovin G., Yudin A., Ivanov D., Tereshina M., Pavlova E. Prototype of new ISON telescope to improve the completeness and accuracy of the catalog of space objects. Program and abstracts of XVI international seminar "Mathematical models&modeling in laser plasma processes&advanced science technologies, Petrovac, Montenegro, 5-10 June, 2017, p.65.
Elenin L., Molotov I., Schildknecht T. ISON asteroid survey program: current state and future prospects. Program and abstracts of XVI international seminar "Mathematical models&modeling in laser plasma processes&advanced science technologies, Petrovac, Montenegro,
5-10 June, 2017, p. 67.
lppm3.ru/files/histofprog/LPpM3-2017-Programme.pdf
« Последнее редактирование: 06 Июн 2017 [12:22:43] от kismet »
« Ответ #2823 : 06 Июн 2017 [15:24:23] »
Нашел прошлогодний абстракт (цветом выделил астрофорумчан 8)):
Pozanenko A., Mazaeva E., Volnova A., Elenin L., Mokhnatkin A., Inasaridze R., Aivazyan V., Reva I., Kusakin A., Tungalag N., Schmalz S., Chornaya E., Matkin A., Erofeeva A., Litvinenko E., Polyakov K., Nevski V., Ivanov A., Krugly Yu., Paronyan G., Voropaev V., Molotov I. GRB afterglow observations by international scientific optical network (ISON). Program and abstracts of XV international seminar "Mathematical models&modeling in laser plasma processes&advanced science technologies, Petrovac, Montenegro, September 26 - October 1, 2016, p.55.
http://lppm3.ru/files/histofprog/LPpM3-2016-2-Programme.pdf
Оффлайн Грехов Михаил
  • Благодарностей: 820
    • Сообщения от Грехов Михаил
« Ответ #2824 : 06 Июн 2017 [17:11:37] »
Если бы еще почаще по-русски печатали бы. Может даже не стоит все выкладывать и все цифры..... а вот в общем и привести ссыль на материал....
Оффлайн serega2007
  • Благодарностей: 1127
    • Сообщения от serega2007
« Ответ #2825 : 07 Июн 2017 [08:19:33] »
     У Кисмета всегда фотографии зовущие в дорогу . Их надо побольше по возможности .
До встречи на Астрофесте !
                                            Серега .
« Ответ #2826 : 09 Июн 2017 [01:10:30] »
Вообще-то именно ссылки на материалы я и выкладываю - и на статьи, и на доклады.
В том числе много всего и на русском языке.
https://ria.ru/science/20170524/1494956015.html
Российские ученые открыли "неопознанные летающие пленки"
Фотометрия астероидов в рамках кооперации ISON в 2016 г.
(Jan-2017 by Yu. Krugly)
Здесь ссылки на доклады, в которых рассказывается о наших астероидных работах:
Доклады  Международной школы-семинара "Астрофотометрия: теория и практика",  2 июля - 14 июля 2016 года, Казахстан, Алаколь
http://aphi.kz/photometry2016/presentations.html
Ю.Н. Круглый.    Задачи фотометрии АСЗ.
https://drive.google.com/file/d/0BwxZPpRCaUzcSk5NLVlmc2VtMWc/view?pref=2&pli=1
Ю.Н. Круглый.   Современный взгляд на астероидную опасность.
https://drive.google.com/file/d/0BwxZPpRCaUzcQk04cUVDNk9pTnM/view?pref=2&pli=1
Ю.Н.  Круглый.  Фотометрия астероидов.
https://drive.google.com/file/d/0BwxZPpRCaUzcVjJhU1NjTnlFTUk/view?pref=2&pli=1
Презентация Молотова И.Е.  "Наблюдения астероидов российскими проектами"
на заседании Совета РАН по космосу 12 февраля 2016 г.
sovet.cosmos.ru/sites/default/files/2016_0212/prez-3-3-0212.ppt
Презентация Боровина Г.К.
"О результатах и перспективах работы Центра сбора, обработки и анализа научной информации по объектам техногенного происхождения (ЦСИТО ) - Институт прикладной математики им. М.В. Келдыша РАН по проблеме «космического мусора»"
на заседании Совета РАН по космосу от 7 июля 2016 года
sovet.cosmos.ru/files/2016_0707/p4-pvd.pptx
"Работы ИПМ им. М.В. Келдыша РАН в области мониторинга опасных космических объектов и событий. Возможности повышения эффективности работы сегмента АСПОС ОКП по высоким орбитам":
« Последнее редактирование: 09 Июн 2017 [01:19:12] от kismet »
« Ответ #2827 : 09 Июн 2017 [23:35:04] »
http://vidauniversitaria.uanl.mx/telescopio-de-la-uanl-importante-para-proyecto-ison/
Telescopio de la UANL, importante para Proyecto ISON
Por las características, cantidad de datos recogidos y localización en el hemisferio, el director del International Scientific Optical Network (ISON), Igor Molotov, destacó el trabajo de la Facultad de Ciencias Físico Matemáticas por instalar un telescopio y sumarse a la red mundial rusa de monitoreo de basura espacial y asteroides.
Por Luis Salazar
“El Observatorio de la UANL es muy importante por varias razones”, aseguró el director general del proyecto ruso ISON y jefe del laboratorio del Instituto de Matemáticas Aplicadas del Instituto Keldysh de la Academia de Ciencias de Rusia, Igor Molotov.
Una de las razones, explicó el científico en entrevista para Vida Universitaria, es la estratégica e importante posición en el hemisferio, ya que sólo hay tres observatorios –de una red mundial de 38– en esta esquina del mundo.
El proyecto ISON tiene presencia en 50 países y emplea 200 investigadores alrededor del orbe para constituirse como la red de cobertura de observación espacial más grande del planeta. En ella se monitorea basura espacial, asteroides, incluso estallidos de rayos gamma para ayudar a entender las condiciones iniciales del universo.
El 7 de marzo, Igor Molotov visitó la ciudad para inaugurar el Observatorio Internacional de Monitoreo de Basura Espacial de la UANL. El director del ISON también brindó una charla en el 3er Taller de Astrofísica Planetaria y X Congreso Nacional de Astrobiología, celebrados en la Facultad de Ciencias Físico Matemáticas (FCFM).
Después de seis meses de la instalación, poner en marcha el telescopio y ante la necesidad de recoger datos con mayor precisión y calibración de los instrumentos y el software, Molotov asistió al observatorio para trabajar con los astrónomos de la UANL en el mejoramiento del proyecto.
El científico comentó que está muy satisfecho con la UANL por el trabajo que se ha hecho; y destacó que es importante que la Universidad haya programado a mediano plazo llevar el telescopio a la zona sur de Nuevo León, puesto que en el área metropolitana la contaminación lumínica es muy fuerte.
“Se facilitará el análisis por la baja contaminación lumínica y aumentará la cantidad de candidatos a observar; eso quizá los lleve a ser el observatorio que más genera resultados de todo el continente americano”, explicó.
Cuando iniciaron con el proyecto, tenían un servidor de mil terabytes para observar las imágenes. Pero, como crece mucho la red y cada imagen pesa alrededor de 50 megabytes –por ejemplo en el Observatorio de la FCFM se generan alrededor de 45 gigabytes al día–, es imposible manejar ese volumen de información. Entonces, lo que se hace es que cada observatorio procese sus datos y envían un informe a Rusia.
El primer emisario de ISON en la FCFM fue el ingeniero Dimitri Ivanov. Él instaló un equipo que llegó por partes; primero la montura y después él mismo trajo el tubo del telescopio. Por su parte, la UANL contribuye con la infraestructura: la caseta, las computadoras e internet. Se instalaron los telescopios y el software en las computadoras, pero, hasta entonces, nunca usaron un manual.
“Lo que les ha gustado [a los rusos] es que rápido agarramos la onda. En otros observatorios era que se conectaban remotamente y les explicaban”, comparó el doctor Enrique Pérez León, responsable del Observatorio del Proyecto ISON de la FCFM-UANL.
Después de varias semanas de trabajo, cuentan con más de 2.5 terabytes de información recabados en el Observatorio de la FCFM-UANL.
“Ellos, desde Rusia, hacen un análisis complementario e implementan otros cálculos con parámetros de posición o si se está en riesgo de colisión. Eso nos conviene a nosotros porque recordemos que aún tenemos tres satélites mexicanos en servicio. Es una forma de prevenir el buen funcionamiento de nuestra infraestructura orbital”, planteó el investigador.
Uno de los acuerdos del convenio entre la UANL y el Instituto de Matemáticas Aplicadas del Instituto Keldysh de la Academia de Ciencias de Rusia, es que el 50 por ciento del tiempo del telescopio es para el Proyecto ISON y el otro 50 por ciento es para proyectos internos de la UANL.
Actualmente, se encuentra en proceso una investigación que forma parte de los estudios de la maestría en Astrofísica de la FCFM. “Es una tesis que caracteriza parámetros orbitales de un asteroide que tiene una cercanía muy próxima a la tierra”, aclaró Pérez León.
El servicio satelital mundial destaca por categorizarse en diferentes alturas. El proyecto ISON está dedicado a los satélites que prestan servicio de localización global y son la gran mayoría de los satélites en funcionamiento. Molotov explicó que la franja menos poblada de satélites y que orbitan a más baja distancia son los satélites de uso militar.
« Ответ #2828 : 11 Июн 2017 [14:36:13] »
Успешно отнаблюдали гамма-всплеск на Терсколе, на модернизированной нами 80-ке
TITLE:   GCN CIRCULAR
NUMBER:  21237
SUBJECT: GRB 170607A: ISON/Terskol optical observations
DATE:    17/06/09 18:33:32 GMT
A. Volnova (IKI),  A. Pozanenko (IKI), V. Agletdinov (KIAM),  E. Mazaeva
(IKI), A. Mokhnatkin (KIAM),   I. Molotov (KIAM)  report on behalf of
larger GRB follow-up collaboration:
We observed the field of GRB 170607A (D’Ai et al., GCN 21214) with K-800
(0.8m) telescope  of ISON/Terskol   observatory
starting  on June, 08
(UT) 23:23:04, about 1 day after the burst onset.  We obtained several
unfiltered images of 20 s exposure. The optical afterglow (D’Ai et al.,
GCN 21214; Heintz  et al., GCN 21217; Lipunov et al., GCN 21220)  is
still bright and clearly visible in a combined image. Preliminary
Date       UT start  t-T0   Filter  Exp.   OT    Err. UL
                      (mid, days)     (s)
2017-06-08 22:21:31 1.01959 CR      128*20 18.50 0.28 18.90
Photometry is based on nearby SDSS DR9 stars
SDSS id                   R_Lupton
J002930.50+091415.3       16.314
J002920.28+091527.1       15.963
J002925.73+091637.7       14.803
Оффлайн Rabbit
  • Благодарностей: 43
    • Сообщения от Rabbit
« Ответ #2829 : 11 Июн 2017 [16:07:28] »
Язык форума русский.
Зачем постить статьи на испанском?
« Ответ #2830 : 11 Июн 2017 [18:12:16] »
Мы ж не виноваты, что про нас написали на испанском. А те форумчане, кому это интересно (например, Дмитрий Иванов, про которого там пишут), могут понять о чем там речь. Ну и картинки не нуждаются в переводе.
Оффлайн leviathan
  • Благодарностей: 1632
  • Смотри в оба !
    • Сообщения от leviathan
« Ответ #2831 : 11 Июн 2017 [18:28:41] »
усиленно изучает язык, иначе как полуобезьяна, никто с тобой и общаться не будет на равных
Всё-равно не будут.
Я видел всё небо !
Оффлайн ivanij
  • Благодарностей: 642
    • Сообщения от ivanij
« Ответ #2832 : 11 Июн 2017 [20:45:01] »
 Можно краткие аннотации давать.
« Ответ #2833 : 12 Июн 2017 [00:57:55] »
http://adsabs.harvard.edu/abs/2017MNRAS.467.3500V
Volnova, A. A.; Pruzhinskaya, M. V.; Pozanenko, A. S.; Blinnikov, S. I.; Minaev, P. Yu.; Burkhonov, O. A.; Chernenko, A. M.; Ehgamberdiev, Sh. A.; Inasaridze, R.; Jelinek, M.; Khorunzhev, G. A.; Klunko, E. V.; Krugly, Yu. N.; Mazaeva, E. D.; Rumyantsev, V. V.; Volvach, A. E.
Multicolour modelling of SN 2013dx associated with GRB 130702A
Monthly Notices of the Royal Astronomical Society, Volume 467, Issue 3, p.3500-3512
05/2017
« Ответ #2834 : 12 Июн 2017 [01:09:21] »
Не совсем понимаю в чем проблема - перевести интернет переводчиком - 2 кнопки нажать
телескоп UANL важен для проекта НСОИ АФН
В связи с характеристиками, объемом собранных данных и местом в полушарии, директор международной научной оптической сети (НСОИ АФН ), Игорь Молотов, отметил работу факультета физической и математических наук, установившего телескоп и присоединившегося к российскому проекту глобальной сети мониторинга космического мусора и астероидов.
По Луис Салазар
«Обсерватория UANL очень важна по нескольким причинам», сказал генеральный директор российского проекта НСОИ АФН и заведующий лабораторией Института прикладной математики имени М. В. Келдыша Российской академии наук Игорь Молотов.
Одна из причин, сказал ученый в интервью университетской газете, что обсерватория имеет стратегическое значение и важное место в полушарии, так как есть только три обсерватории в этом уголке мира всемирной сети из 38 обсерваторий.
Проект НСОИ АФН объединяет 17 стран и насчитывает 200 исследователей по всему миру , чтобы установить себя в качестве  крупнейшей в мире сети для наблюдения космического мусора, астероидов, а также гамма-всплесков , чтобы помочь понять начальные условия вселенной.
7 марта, Игорь Молотов посетил город, чтобы открыть здесь Международную обсерваторию UANL по мониторингу космического мусора. Директор НСОИ АФН также выступил с докладом на 3 -м семинаре для астрофизики и Планетарного X Национальный конгресс астробиологии, состоявшейся на факультете физической и математических наук (FCFM).
После шести месяцев с момента установки, запуска телескопа, калибровки приборов и программного обеспечения, и необходимого сбора данных с большей точностью, Молотов посетил обсерваторию для работы с астрономами на UANL в улучшении проекта.
Ученый сказал, что он очень доволен UANL для работы , которая была проделана; и он подчеркнул , что это важно , что университет наметил в среднесрочной перспективе переместить телескоп к югу от Nuevo Leon, так как в столичном районе очень сильное световое загрязнение.
«При низком уровне светового загрязнения будет облегчен анализ данных и увеличится количество кандидатов для наблюдения; Поэтому, перемещение телескопа требуется , чтобы быть обсерватория генерировала больше результатов по всей Америке», сказал он.
Когда начался проект, у них был сервер на тысячу терабайт , чтобы сохранять ПЗС-изображения. Но так же сеть растет , и каждый ПЗС-кадр весит около 50 мегабайт , например , в обсерватории НСОИ АФН собирается около 45 гигабайтов в день, это очень сложно справиться с таким объемом информации. Так что это после наблюдений обработка данных осуществляется на месте, в каждый из обсерваторий, чтобы затем полученные данные отправить в Россию.
Первый эмиссар FCFM от НСОИ АФН был инженер Димитрий Иванов. Он совместно с командой университета UANL установил телескоп на крыше здания и программное обеспечение на компьютеры, подготовил инструкцию для местных наблюдателей. Со своей стороны, UANL организовал инфраструктуру: павильон, компьютеры и интернет.
«Что мне понравилось [русские] быстро схватили волну. В других обсерваториях все протекало гораздо медленнее, а тут мы постоянно поддерживаем с ними удаленную связь», объяснил д - р Энрике Перес, глава обсерватории  FCFM-UANL проекта НСОИ АФН/ISON.
После нескольких недель работы в обсерватории FCFM-UANL было собрано более чем 2,5 терабайт информации.
«Они, в России, делают дальнейший анализ и осуществляют вычисления параметров орбит и прогноз степени опасности возможных столкновений. Это нас устраивает , потому что помню , что у нас еще есть три мексиканских спутника, находящиеся в эксплуатации. И это один из способов обеспечить надлежащее функционирование нашей орбитальной инфраструктуры», заявил исследователь.
Один из пунктов соглашения между UANL и Институтом прикладной математики имени М. В. Келдыша Российской академии наук, в том , что 50 процентов времени телескоп наблюдает для проекта НСОИ АФН и 50 процентов для собственных проектов UANL.
Он в настоящее время проводит работы в рамках мастерских исследований в астрофизике FCFM. «Это тезис , который характеризует параметры орбиты астероида , который имеет очень тесную близость к Земле» сказал Перес Леон.
« Последнее редактирование: 12 Июн 2017 [01:38:39] от kismet »
Оффлайн Fidel
  • Благодарностей: 620
  • http://fidgor.narod.ru
    • Skype - FidelGorbunov
    • Сообщения от Fidel
« Ответ #2835 : 12 Июн 2017 [18:23:21] »
Да и без перевода всё было понятно  ;)
Оффлайн AVV
    • Сообщения от AVV
« Ответ #2836 : 12 Июн 2017 [18:51:51] »
Поддержу Игря Молотова и всю команду!
Не нравится, на непонятном языке - не читайте!
Заставляет кто что ли мучаться?
Не можете толком сказать по теме - не хрен умничать!
« Ответ #2837 : 14 Июн 2017 [22:11:38] »
http://lozga.livejournal.com/148718.html
Космические пленки
Первая новость изначально не вызывала доверия. Какие-то пленки, в желтом заголовке якобы охотящиеся на спутники, а в тексте статьи обозначенные как космический мусор. Странная информация о том, что они якобы видны в маленькие телескопы и не видны в большие. Также в новости есть классический признак недостоверной информации - отсутствие нормальной ссылки на то, кто именно это обнаружил и в каком серьезном источнике описал. Впрочем, упомянут Институт прикладной математики им. Келдыша. Две минуты поиска позволили найти первоисточник - вполне адекватного качества статью в РИА Новости с нормальными ссылками и прямой речью.
Благодаря этим наблюдениям появилась информация о новом классе объектов с удивительными характеристиками: совсем маленькая масса и огромная площадь. Скорее всего это какие-то летающие пленки, которые либо образуются при разрушениях спутников и ступеней ракет, либо просто отслаиваются даже от рабочих космических аппаратов. В результате получается этакий "искусственно-естественный" солнечный парус: приспособление, использующее для движения давление солнечного света.
Ученые Баллистического центра уже более 10 лет имеют возможность отслеживать баллистическую эволюцию подобных объектов, часть из которых под воздействием давления солнечного света то сходят с геостационарной орбиты, то возвращаются назад.
Поясняет Игорь Молотов, руководитель группы координации проекта НСОИ АФН ИПМ им. М.В.Келдыша РАН:
"Эти пленки еще интересны тем, что они имеют сильно переменный блеск. Иногда подобные объекты открываются на маленьком телескопе, а на большом их при этом не видно. Некоторые обсерватории имеют по несколько телескопов различного размера, например Крымская. У них там есть телескоп 2,6 м – очень большой, и маленький — 22 см. И вот они видят эту пленку на 22 см телескопе, а когда переходят на телескоп 2,6 м, для того, чтобы провести фотометрические наблюдения, которые могут помочь понять из какого материала она состоит, — вообще не видят. Переходят обратно – на 22см — видят! Вероятно, так происходило потому, что пленка поворачивалась к Земле своим ребром и теряла блеск."
Игорь Евгеньевич Молотов - реально существующий человек, и, на всякий случай, я ему написал, чтобы проверить, действительно ли он это говорил, и что это за объекты по его мнению.
В ожидании ответа можно пораскинуть мозгами - есть ли на спутниках такие компоненты, которые имеют маленькую массу при большой площади поверхности? Есть - это многослойная металлизированная пленка, использующаяся для теплоизоляции. В России ее называют "экранно-вакуумная теплоизоляция", в США - Multi-layer insulation или MLI. На земле подобная пленка используется в спасательных или горных одеялах, потому что очень легкая, занимает мало места и хорошо сохраняет тепло.
На спутники ее уходит очень много.
А вот здесь хорошо видны несколько слоев.
Отдельный интересный вопрос - отваливается ли она сама по себе от спутников, из-за процессов старения, либо же обнаруженные пленки являются результатом каких-то столкновений. Также стоит отметить, что много лет экспериментально проверялись изменения характеристик различных материалов под воздействием космического пространства. Спейс шаттлы экспонировали на орбите большой эксперимент Long Duration Exposure Facility c 1984 по 1990 год, а сейчас на МКС идет эксперимент "Выносливость"
Уже после беседы с РЕН ТВ пришел ответ от Игоря Молотова, в котором он тоже высказал гипотезу теплоизоляции:
По одной из версий, это клочки термоизолирующей пленки, в которую заворачивают спутники.
Также он прислал мне ссылку на работу десятилетней давности, в которой более подробно описываются эти необычные объекты.
Подтверждено наличие на высоких орбитах объектов, безусловно связанных по своему происхождению с крупными объектами в области ГСО, но имеющих уникальные физические свойства. Они обладают очень большим отношением площади к массе - от 1 до 40 кв.м/кг, что превышает значения данного параметра для "обычных" объектов от 300 до 13000 раз. В силу этого орбитальная эволюция таких объектов претерпевает значительные изменения под воздействием давления потока светового излучения. Прогнозирование движения таких объектов существенно осложнено тем, что отношение площади к массе не является для них постоянной величиной из-за вращения относительно центра масс и, как следствие, не представляется возможным осуществлять точное прогнозирование влияния давления светового излучения на движение этих объектов. Единственная возможность не потерять эти объекты - постоянно их наблюдать.
Также в беседе меня спросили про правильность оценки количества космического мусора. В статье РИА Новости названо число 24 000 объектов, в ежеквартальном отчете NASA упомянуты 17 260 объектов. Космический мусор отслеживается радарами и оптическими телескопами, это необходимо для безопасной работы МКС и спутников.
Вывод: В серьезном издании рассказали про объекты, которые наблюдают уже десять лет. Откуда уже, не понимая и навешивая все более желтые заголовки, это потащили различные сайты.
Оффлайн Toth
  • Благодарностей: 198
    • Сообщения от Toth
« Ответ #2838 : 14 Июн 2017 [23:35:31] »
Космические пленки
Недавно, в конце марта, при очередной внекорабельной деятельности на МКС , астронавты "запустили" такой . Упустили кусок защитного экрана.
Сейчас это объект  № 42434, он же 1998-067LF, он же "ISS DEB ". За 2 месяца высота уменьшилась на 19 км.
Canon PowerShot SX130 IS
« Ответ #2839 : 15 Июн 2017 [23:41:20] »
От разгонных блоков не отваливаются. ВА считал одно время, что при запусках от разгонных блоков отделяются куски замороженных остатков топлива.
