A A A A Автор Тема: Новости проекта ISON (ПулКОН)  (Прочитано 93441 раз)
Оффлайн kismetАвтор темы
  • Благодарностей: 810
    • Сообщения от kismet
Re: Новости проекта ISON (ПулКОН)
« Ответ #2500 : 11 Дек 2015 [16:11:11] »
Про открытие 4-й кометы LeonidOSa и 6-й проекта ISON
Официальный циркуляр CBET
                                                  Electronic Telegram No. 4216
Central Bureau for Astronomical Telegrams
Mailing address:  Hoffman Lab 209; Harvard University;
 20 Oxford St.; Cambridge, MA  02138; U.S.A.
e-mail:  cbatiau@eps.harvard.edu (alternate cbat@iau.org)
URL http://www.cbat.eps.harvard.edu/index.html
Prepared using the Tamkin Foundation Computer Network
COMET C/2015 X4 (ELENIN)
     Leonid Elenin reports his discovery of a diffuse comet with slight
condensation on three CCD images taken with a 0.4-m f/3 astrograph at the
ISON-NM observatory near Mayhill, NM, USA, on Dec. 3.5 UT (discovery
observations tabulated below); he noted a coma with diameter about 12" and a
15" tail in p.a. 280 deg.
     2015 UT             R.A. (2000) Decl.       Mag.   Observer
     Dec.  3.48520    6 02 39.78   +21 36 39.3   18.2   Elenin
           3.49481    6 02 39.41   +21 36 33.5   17.8     "
           3.50440    6 02 39.05   +21 36 28.0   18.0     "
After the comet was posted on the Minor Planet Center's PCCP webpage, other
CCD astrometrists also noted the object's cometary appearance.  Ten stacked
60-s images obtained by C. Jacques, E. Pimentel, and J. Barros on Dec. 3.7 UT
with an iTelescope 0.51-m f/4.5 reflector at Siding Spring show a condensed
coma 5" in diameter, elongated 8" towards p.a. 145 deg.  H. Sato, Tokyo,
Japan, notes that that eight stacked 60-s exposures taken with an iTelescope
0.51-m f/6.8 astrograph (+ luminance filter) near Mayhill, NM, U.S.A., on
Dec. 3.73 show the comet to be strongly consensed with a coma 15" in diameter
and a short tail 15" long toward p.a. 280 degrees; the w-band magnitude was
16.5 as measured within a circular aperture of radius 8".8.  E. Guido,
Castellammare di Stabia, Italy, writes that twenty stacked 120-s unfiltered
exposures, obtained remotely with an iTelescope 0.32-m f/8 astrograph near
Nerpio, Spain, on Dec. 3.9, show a compact coma nearly 8" in diameter (with
red mag 17.1-17.2), elongated toward p.a. 120 deg.  E. Bryssinck, Kruibeke,
Belgium, relates that four stacked 120-s images obtained on Dec. 4.9 with a
0.4-m f/3.8 astrograph shows a condensed circular coma 12" across.  J.-F.
Soulier obtained unfiltered images with a 0.30-m f/3.8 Newtonian reflector
at Maisoncelles, France, on Dec. 4.90-4.95 that show a 13" coma and a tail
10" long in p.a. 315 deg.  Twenty 2-min exposures taken by D. T. Durig and
S. P. Hearn on Dec. 8.23-8.27 with a 0.3-m f/2.5 Schmidt-Cassegrain reflector
at the Cordell-Lorenz Observatory, Sewanee, TN, USA, show a short tail about
17" long in p.a. 303 deg.
     The available astrometry, the following elliptical orbital elements by
G. V. Williams, and an ephemeris appear on MPEC 2015-X105.
     T = 2015 Nov.  2.6423 TT         Peri. = 176.1520
     e = 0.813430                     Node  = 262.6351  2000.0
     q = 3.393964 AU                  Incl. =  29.4998
       a = 18.191358 AU    n = 0.0127030    P =  77.6 years
NOTE: These 'Central Bureau Electronic Telegrams' are sometimes
      superseded by text appearing later in the printed IAU Circulars.
                         (C) Copyright 2015 CBAT
2015 December 8                  (CBET 4216)              Daniel W. E. Green
Оффлайн Goodricke
  • Благодарностей: 975
  • Deaf astronomer
    • Сообщения от Goodricke
« Ответ #2501 : 11 Дек 2015 [16:14:08] »
Уже есть там https://astronomy.ru/forum/index.php/topic,137361.60.html
« Ответ #2502 : 11 Дек 2015 [16:43:29] »
Дык, я ж цитату из той темы сделал  :)
« Ответ #2503 : 11 Дек 2015 [18:04:55] »
Наблюдаем гамма-всплески в Абастумани, Нью-Мексико, Чугуеве, Хуралтоготе
http://adsabs.harvard.edu/abs/2015GCN..18287...1K
Krugly, Y.; Mazaeva, E.; Shevchenko, V.; Gromakina, T.; Molotov, I.; Pozanenko, A.
GRB 150910A: Chuguev observatory optical observations.
GRB Coordinates Network, Circular Service, 18287, 1 (2015)
00/2015
http://adsabs.harvard.edu/abs/2015GCN..18289...1M
Mazaeva, E.; Inasaridze, R.; Zhuzhunadze, V.; Molotov, I.; Pozanenko, A.
GRB 150910A: AAO optical observations.
GRB Coordinates Network, Circular Service, 18289, 1 (2015)
00/2015
http://adsabs.harvard.edu/abs/2015GCN..18307...1M
Mazaeva, E.; Schmalz, S.; Tungalag, N.; Volnova, A.; Molotov, I.; Pozanenko, A.
GRB 150911A: Khureltogot upper limit.
GRB Coordinates Network, Circular Service, 18307, 1 (2015)
00/2015
http://adsabs.harvard.edu/abs/2015GCN..18309...1K
Krugly, Y.; Shevchenko, V.; Gromakina, T.; Molotov, I.; Mazaeva, E.; Pozanenko, A.
GRB 150911A: Chuguev observatory upper limit.
00/2015
http://adsabs.harvard.edu/abs/2015GCN..18327...1M
Mazaeva, E.; Inasaridze, R.; Kvaratskhelia, O.; Molotov, I.; Pozanenko, A.
GRB Coordinates Network, Circular Service, 18327, 1 (2015)
00/2015
http://adsabs.harvard.edu/abs/2015GCN..18480...1E
Elenin, L.; Mazaeva, E.; Volnova, A.; Molotov, I.; Pozanenko, A.
GRB 151027A : ISON-NM early optical detection.
GRB Coordinates Network, Circular Service, 18480, 1 (2015)
00/2015
http://adsabs.harvard.edu/abs/2015GCN..18618...1E
Elenin, L.; Volnova, A.; Mazaeva, E.; Molotov, I.; Pozanenko, A.
GRB 151118A: ISON-NM early optical limit.
GRB Coordinates Network, Circular Service, 18618, 1 (2015)
00/2015
http://adsabs.harvard.edu/abs/2015GCN..18627...1M
Mazaeva, E.; Inasaridze, R.; Ayvazian, V.; Volnova, A.; Molotov, I.; Pozanenko, A.
GRB 151118A: AAO optical upper limit.
GRB Coordinates Network, Circular Service, 18627, 1 (2015)
00/2015
« Ответ #2504 : 12 Дек 2015 [15:17:37] »
Наблюдатели подводят промежуточные итоги по астероидным наблюдениям (цитирую с другого форума):
Прошел год с момента полного отказа от CoLiTec и перехода на новый софт. Итоги года.
Обсерваторией H15 открыты 4 АСЗ, включая 1 PHA. С августа 2015 года, на обсерватории Q60 открыты 4 АСЗ. На обсерватории H15 открыта новая комета - P/2014 X1 (Elenin).
Все объекты при открытии имели блеск в пределах 18-20m. 5 из 9 объектов открыты в области Млечного пути.
За время работы обсерваторий проекта с ПО CoLiTec (2010-2015) открыты 3 кометы и 4 АСЗ. За год, с декабря 2014 по декабрь 2015 открыты 1 комета и 8 АСЗ (включая 1 PHA).
Общее количество измерение обсерватории H15 по годам.
2011 - 154970 (CLT)
2012 - 97878 (CLT)
2013 - 107989 (CLT)
2014 - 93567 (CLT)
2015 - 167587 (SkySift)
В дополнение открыта комета C/2015 X4 (ELENIN)
Прошедшей ночью на О75 выдалось много работы. Пронаблюдал:
8 NEOCP-объектов
- LM03rZl (не обнаружен, вероятно ложняк)
- LM03rQ6 (подтверждён, MPEC 2015-X55)
- WX3FB13 (снят с NEOCP, ИСЗ)
- WW91A3F (не обнаружен, вероятно утерян)
- WX98D61 (не обнаружен, слишком быстрый+тусклый)
- P10pHfN (подтверждён, MPEC 2015-X54)
- P10pKct (подтверждён, NEO-рейтинг 78, возможно останется без MPEC)
- WX99720 (не обнаружен, вероятно ложняк)
1 PCCP-объект
- WX3E94F (подтверждён, MPEC вышел за 15 минут до отправки измерений, позже будет MPEC Daily Orbit Update)
40 поисковых полей (см. вложение с картой) с рабочим проницанием по объектам ~18 маг.
P.S. При блинковке поисковый полей в М33 была обнаружена потенциальная Новая с блеском ~17.5 маг, к сожалению, она уже 6 дней как висит на TOCP. Если получится успеть, можно отправить подтверждение, дабы быть включёнными в CBET. Меня это событие весьма воодушевило - глаза на месте, объект обнаружил, не зная о нём. Есть коварный план: временно попробовать искать малые тела нарочно исключительно во Млечном Пути, попутно выискивая Новые.
Ссылка на циркуляры MPC, в которые включены результаты удаленных наблюдений в Монголии http://sergiuspro.de/astronomy/O75/
« Ответ #2505 : 13 Дек 2015 [01:30:31] »
Вольнова А., Позаненко А., Мазаева Е., Еленин Л., Литвиненко Е., Рева И., Ерофеева А., Маткин А., Степура А., Иванов А., Варда Д., Синяков Е., Невский В., Линьков В., Инасаридзе Р., Шмальц С., Круглый Ю., Слюсарев И., Тунгалаг Н., Буянхишиг Р., Байбарат Т., Миникулов М., Гулямов М., Абдуллоев С., Куприянов В., Воропаев В., Молотов И. Наблюдения оптического послесвечения гамма-всплесков  в сети ISON. Тезисы докладов Международной конференции. "Настоящее и будущее малых и средних телескопов" SMT-2015, п. Нижний Архыз, КЧР, Россия, 19-22 октября 2015 г., стр. 32-34
Молотов И.Е., Юдин А.Н. Сеть НСОИ АФН/ISON, результаты и перспективы. Тезисы докладов Международной конференции "Настоящее и будущее малых и средних телескопов" SMT-2015, п. Нижний Архыз, КЧР, Россия, 19-22 октября 2015 г.,  стр. 62-64
Cсылка на сборник тезисов конференции http://www.sao.ru/hq/lon/ConfSite/Book_of_SMT-2015.pdf
« Последнее редактирование: 13 Дек 2015 [22:35:18] от kismet »
« Ответ #2506 : 13 Дек 2015 [16:36:12] »
http://www.mk.ru/science/2015/12/13/rossiyskiy-astronom-leonid-elenin-otkryl-chetvertuyu-kometu.html
Российский астроном Леонид Еленин открыл четвертую комету
Четвертую за последние пять лет комету открыл астроном из Института прикладной математики им. Келдыша Леонид Еленин. В пятницу, 11 декабря C/2015 X4 (Elenin) прошла на ближайшем от Земли расстоянии - 359 млн. км. Как удается ученому открывать по одной комете в год, первооткрыватель рассказал «МК».
Очередная находка произошла 3-го декабря. Работая на удаленной обсерватории ISON-NM, Леонид открыл свою 4-ю комету. 8 декабря ей уже дали официальное название C/2015 X4 (Elenin), а 11 декабря она прошла на самом ближайшем к Земле расстоянии в 359 млн километров.
По словам Еленина, его новая комета имеет блеск 17.5 звездной величины (то есть видна только в профессиональный телескоп) и относится к семейству комет Нептуна (или комет семейства Галлея). Она уже побывала в ближайшей точке от Солнца — на расстоянии 3.4 астрономические единицы, и теперь удаляется от него по направлении к Нептуну. В следующий раз комета C/2015 X4 (Elenin) вернется к нам только через 77 лет (таков ее период обращения вокруг Солнца), а именно, в 2092 году.
Нам удалось побеседовать с Леонидом Елениным по поводу его открытия по телефону.
- Леонид, мы вас поздравляем от всей души! Каков приблизительный размер вашей новой кометы?
- Комета не большая, скорее всего, ее ядро не превышает размер в несколько километров.
- Есть ли среди астрономов такие же как вы мультиоткрыватели комет?
- Конечно, у меня достаточно скромный результат. Астрономы работающие на профессиональных обзорных телескопах, имеют на счету десятки комет. Например австралийский астроном, шотландского происхождения Роберт МакНот открыл 82(!) кометы. Сейчас открывать кометы становится все сложнее, так как нам приходится конкурировать с американскими большими обзорными телескопами.
- Тем не менее, четыре кометы за пять лет, - это достижение. Признайтесь, у вас есть какой-то секрет или счастливая примета?
- Я называю это закономерной случайностью, базирующийся на каждодневной работе. Например свою 3-ю комету я открыл 12 декабря 2014 года, и после года интенсивной работы, случай подарил мне очередную комету. Кстати, 3 из 4 своих комет я открыл в декабре, и здесь нет мистики. Просто в северном полушарии в декабре самые длинные наблюдательные ночи. Как я писал, конкуренция со стороны американских обзоров очень высока (наши телескопы в разы меньше их телескопов). Приходится искать там, где они предпочитают не искать - на фоне Млечного пути. Это сложная работа, так как кометы и астероиды «прячутся» на фоне звезд, которых в этих областях очень много. Например, на одном кадре может быть более 100 тысяч звезд! Приходится заниматься тяжелой работой, чтобы добиться успеха.
Напомним, что высокие технологии сегодня позволяют астрономам (ими пользуется и Леонид Еленин), сидя у себя в кабинете, наблюдать за небом в телескоп, расположенный в другой стране. Так, упомянутая им обсерватория ISON- NM (обсерватория, дистанционно управляемая по российскому проекту ISON) расположена в штате Нью-Мехико в США. Специальная программа, запущенная Елениным, сканирует определенные участки неба, делает снимки, которые он может изучать в Москве.
Справка МК
Кометы, открытые Леонидом Елениным:
2010 год — долгопериодическая, впервые долетевшая к нам из облака Оорта, которая вскоре разрушилась.
2011 год — комета из семейства Сатурна. Вернется к Земле в 2023 году.
2014 год — комета из семейства Сатурна. Вернется к Земле в 2029 году.
2015 год — комета из семейства Нептуна. Вернется к Земле в 2092 году.
Орбита кометы C/2015 X4 (Elenin)
Оффлайн АК-7 4
  • Благодарностей: 283
    • Сообщения от АК-7 4
« Ответ #2507 : 13 Дек 2015 [18:06:40] »
Леонид! Ещё раз искренне поздравляем и желаем тебе увидеть комету C/2015 X4 (Elenin) при следующем её визите в 2092 году!
Мёд Горного Алтая. Настоящий астрономический мёд!)
Оффлайн LeonidOS
  • Благодарностей: 289
  • H15, Q60, N82, O75
    • Сообщения от LeonidOS
« Ответ #2508 : 13 Дек 2015 [18:32:16] »
Спасибо! Буду стараться 😀
Оффлайн serega2007
  • Благодарностей: 1127
    • Сообщения от serega2007
« Ответ #2509 : 13 Дек 2015 [18:36:56] »
   Мне тоже понравилась именно эта комета . Возможно , она еще наведет шороху в поясе астероидов .
До встречи на Астрофесте !
                                            Серега .
« Ответ #2510 : 14 Дек 2015 [22:57:11] »
http://tass.ru/kosmos/2526789
Российский ученый открыл "сестру" кометы Галлея
Комету удалось "разглядеть" с помощью удаленного телескопа сети ISON в Нью-Мексико, а анализ данных, поступивших с телескопа, сделали в Институте прикладной математики им М.В. Келдыша.
САНКТ-ПЕТЕРБУРГ, 14 декабря. /Корр. ТАСС Наталия Михальченко/. Новую комету - "сестру" кометы Галлея обнаружил научный сотрудник Института прикладной математики им. М.В. Келдыша Леонид Еленин.
"Я обнаружил комету 3 декабря, 8 декабря ее под обозначением C/2015 X4 (Elenin) внесли о официальный международный циркуляр", - сообщил ученый корреспонденту ТАСС.
Он отметил, что комету удалось "разглядеть" с помощью удаленного телескопа сети ISON в Нью-Мексико, а анализ данных, поступивших с телескопа, сделали в Институте прикладной математики им М.В. Келдыша.
Притянута гигантами Солнечной системы
Новая комета, как рассказал ученый, принадлежит к "семейству" Нептуна или Галлея (группа получила название по имени самой известной кометы данной группы, в последний раз сближавшаяся с Землей в 1986 году).
"Это короткопериодические кометы, с периодом около 75-80 лет, которые в максимальном удалении от Солнца (афелии), заходят за орбиту Нептуна. Считается, что это бывшие долгопериодические кометы, пришедшие с окраин Солнечной системы (облако Оорта), которые были захвачены планетами-гигантами и перешедшие на короткопериодические орбиты", - пояснил ученый.
Далека и не опасна
Комета обнаружена на границе созвездий Близнецов и Ориона. Она находится над "головой" охотника (Орион по греческой мифологии был знаменитым охотником). Блеск кометы достигает 17,5 звездной величины и, по словам ученого, за декабрь может вырасти на половину звездной величины.
Невооруженному глазу комета не доступна, ее можно разглядеть лишь в телескопы с ПЗС-камерами. Орбита кометы построена так, что она примерно раз в 77 лет то приближается к Солнцу на 3,4 астрономической единицы (это в 3,4 раза дальше, чем от Земли до Солнца), то удаляется за Нептун.
По словам ученого, от нее не стоит ожидать тесных сближений с Землей, "опасность столкновения отсутствует". Опасность комет, уточнил он, определяется также, как и опасность астероидов. Но на данный момент, по словам Еленина, опасных объектов из числа комет ученые не обнаружили.
Список комет пополняют в декабре
Собеседник агентства рассказал, что открыть комету C/2015 X4 (Elenin) помогло то, что область неба, в которой она была замечена, "хорошо просматривается зимой". Для ученого это уже четвертая открытая комета, причем три из четырех открыты в декабре и одна в июле. "Это не мистика, просто в декабре в Северном полушарии самые длинные наблюдательные ночи", - пояснил он.
Астрономическая сеть ISON создана для слежения за космическим мусором, а также астероидами и кометами, сближающимися с Землей. Ее создатели из Института прикладной математики им. Келдыша поставили цель охватить небольшими телескопами всю небесную сферу. Эта задача выполнена пока на несколько процентов, но сеть активно развивается, в этом году в нее включился телескоп в Австралии.
Леонид Еленин - один из ведущих ученых наблюдательной сети ISON. Среди россиян он на втором месте по числу открытых комет после Геннадия Борисова из Крымской астрономической обсерватории. Еленин открыл также 1500 астероидов, в том числе 12, сближающихся с Землей. Это треть всех астероидов, открытых в СССР и СНГ за все время наблюдений.
« Ответ #2511 : 15 Дек 2015 [17:31:39] »
Зарегистрирована еще одна переменная ISON_J034947.7+483628.
Звезда 14m в созвездии Персея, затменная типа W Б. Медведицы с периодом 7.67ч и амплитудой 0.54m.
« Ответ #2512 : 18 Дек 2015 [12:39:29] »
становишься астрономом! :)
На переменные звезды потянуло? С чего это?
Мы всегда позиционировали наш проект ISON, как научный. Поэтому пытаемся и будем пытаться извлекать научный результат из наших наблюдений. Ведь помимо космического мусора мы наблюдаем астероиды и оптическое послесвечение гамма-всплесков. Также одно время пробовали наблюдать сверхновые, и, вот, искать переменные звезды на кадрах с наблюдениями, допустим, гамма-всплесков.
Круг научных задач ISON ограничен возможностями привлечения ученых для анализа наших результатов и написания статей. Где смогли привлечь, там и наблюдаем.
« Ответ #2513 : 18 Дек 2015 [22:29:21] »
Зарегистрирована переменная ISON_J034508.1+482406.
Звезда 13,9m в созвездии Персея, затменная типа бета Лиры с периодом 11.37ч и амплитудой 0.21m.
« Ответ #2514 : 19 Дек 2015 [16:44:10] »
Цитируй правильно.
« Ответ #2515 : 21 Дек 2015 [18:16:10] »
TITLE:   GCN CIRCULAR
NUMBER:  18708
SUBJECT: GRB 151215A: TSHAO optical observations
DATE:    15/12/17 17:16:14 GMT
E. Mazaeva (IKI), I. Reva (Fesenkov Astrophysical Institute), A. Kusakin
(Fesenkov Astrophysical Institute), A. Volnova (IKI), A. Pozanenko (IKI)
report on behalf of larger GRB follow-up collaboration:
We observed the field of GRB 151215A (Gibson et al., GCN 18691)  with
Zeiss-1000 (East) 1-m telescope of Tien Shan Astronomical Observatory
starting on Dec. 15 (UT) 16:47:23.  We obtained several images in R
filter.  The afterglow  (Cenko, GCN 18692)  is detected  in a combined
image. Preliminary photometry of the afterglow is following
Date       UT start    t-T0     Filter  Exp.    OT     Err
                        (mid, days)      (s)
2015-12-15 16:47:23    0.61190  R       21*300  22.1   0.3
The photometry is based on nearby SDSS stars.
« Ответ #2516 : 21 Дек 2015 [18:47:05] »
Зарегистрирована переменная ISON_J034700.3+480515
Звезда 16.5m в созвездии Персея, затменная типа W Б. Медведицы с периодом 6.72ч и амплитудой 0.3m.
« Ответ #2517 : 21 Дек 2015 [22:50:47] »
Зарегистрирована высоко-амплитудная переменная звезда типа дельты Щита ISON_J034738.4+484614,  с периодом 2,66ч и амплитудой 0.4m.
« Ответ #2518 : 22 Дек 2015 [11:11:31] »
Зарегистрирована переменная ISON_J034224.0+481034.
Звезда 15.3m в созвездии Персея, затменная типа W Б. Медведицы с периодом 7.2ч и амплитудой 0.18m.
« Ответ #2519 : 23 Дек 2015 [12:36:38] »
Зарегистрированы еще 2 переменные типа W Б. Медведицы:
ISON_J034127.7+475222 - период 6.86ч, амплитуда 0.26m.
ISON_J034143.0+475728 - период 10.6ч, амплитуда 0.43m.
