A A A A Автор Тема: Новости проекта ISON (ПулКОН)  (Прочитано 94178 раз)
Оффлайн kismetАвтор темы
  • Благодарностей: 810
    • Сообщения от kismet
Re: Новости проекта ISON (ПулКОН)
« Ответ #2320 : 26 Июл 2015 [23:28:13] »
Первый свет нашего нового телескопа в Австралии. Готовим к работе.
Сегодня под утро дали погоду. Снимал астероиды для получения номера MPC.
« Ответ #2321 : 27 Июл 2015 [14:24:02] »
С нашим участием открыта двойственность еще у двух астероидов:
http://www.cbat.eps.harvard.edu/iau/cbet/004100/CBET004122.txt
Electronic Telegram No. 4122
Central Bureau for Astronomical Telegrams
INTERNATIONAL ASTRONOMICAL UNION
CBAT Director:  Daniel W. E. Green; Hoffman Lab 209; Harvard University;
 20 Oxford St.; Cambridge, MA  02138; U.S.A.
e-mail:  cbatiau@eps.harvard.edu (alternate cbat@iau.org)
URL http://www.cbat.eps.harvard.edu/index.html
Prepared using the Tamkin Foundation Computer Network
(8474) RETTIG
V. Chiorny, Kharkiv Observatory; V. Benishek, Belgrade Astronomical Observatory, Serbia; P. Pravec and P. Kusnirak, Ondrejov Observatory; Yu. N. Krugly, Kharkiv Observatory; J. Oey and R. Groom, Blue Mountains Observatory, Leura, NSW, Australia; V. Reddy, Planetary Science Institute; D. Pray, Sugarloaf Mountain Observatory, South Deerfield, MA, U.S.A.; W. Cooney and J. Gross, Sonoita Research Observatory, Sonoita, AZ, U.S.A.; D. Terrell, Southwest Research Institute; R. Inasaridze, V. Ayvazian and V. Zhuzhanidze, Abastumani Observatory; R. Montaigut and A. Leroy, OPERA Observatory, France; and I. Molotov, Keldysh Institute of Applied Mathematics, Moscow, report that photometric observations obtained during May 19-July 23 reveal that minor planet (8474) is a binary system with an orbital period of 30.54 +/- 0.01 hr.  Mutual eclipse/occultation events that are 0.60- to 0.93-magnitude deep indicate a lower limit on the secondary-to-primary mean-diameter ratio of 0.86.  Rotations of the components appear to be synchronous with the orbital motion and an amplitude of the combined primary plus secondary rotational lightcurve is 0.34 mag at solar phases 7-15 deg.
http://www.cbat.eps.harvard.edu/iau/cbet/004000/CBET004097.txt
CBET 4097
(4541) MIZUNO
D. Pray, Sugarloaf Mountain Observatory, South Deerfield, MA, U.S.A.; P. Pravec, K. Hornoch, P. Kusnirak, J. Vrastil and H. Kucakova, Ondrejov Observatory; Yu. N. Krugly and V. Shevchenko, Kharkiv Observatory; R. Inasaridze and V. Ayvazian, Abastumani Observatory; J. Oey, Blue Mountains Observatory, Leura, NSW; W. Cooney and J. Gross, Sonoita Research Observatory, Sonoita, AZ, USA; D. Terrell, Southwest Research Institute; and I. Molotov, Keldysh Institute of Applied Mathematics, Moscow; report that photometric observations obtained during Feb. 24-Apr. 25 reveal that minor planet (4541) is a binary system with an orbital period of 29.68 ± 0.01 hr. The primary shows a period of 2.82784 ± 0.00005 hr, and it has a lightcurve amplitude of 0.08 mag at solar phases 3-15 deg, suggesting a nearly spheroidal shape. Mutual eclipse/occultation events that are 0.06- to 0.15-magnitude deep indicate a lower limit on the secondary-to-primary mean-diameter ratio of 0.24. The mean absolute R magnitude of the system is H_R = 12.50 ± 0.04 and the slope parameter G = 0.11 ± 0.04. V. Reddy and D. Takir, Planetary Science Institute, Tucson, report that near-infrared spectroscopic observations (0.7-2.5 microns) of minor planet (4541), obtained on Apr. 26 using the NASA Infrared Telescope Facility on Mauna Kea, show that it is an S-type minor planet with surface composition dominated by the minerals olivine and pyroxene.
« Ответ #2322 : 29 Июл 2015 [09:40:15] »
В Сайдинг Спринг пока дальше тестов не пошло  :(
Колдуем над системой, которую внезапно посетил Синий экран  :) И наш телескопчик виден.
Оффлайн r1bgg
  • Благодарностей: 15
    • Сообщения от r1bgg
« Ответ #2323 : 29 Июл 2015 [09:59:19] »
Лучшее средство от синего экрана на удаленке - работа под гипервизором (ESXI сервер в нашем случае), и использование серверного оборудования с функцией типа IPMI. В этом случае до тех пор, пока оборудование физически исправно для исправления любых программных проблем (вплоть до переустановки OS) достаточно сетевого доступа.
Оффлайн LeonidOS
  • Благодарностей: 289
  • H15, Q60, N82, O75
    • Сообщения от LeonidOS
« Ответ #2324 : 29 Июл 2015 [11:17:36] »
Понял, но мы купили для машины управления самый дешевый из доступных компов на i5. Так что... В НМ все работает уже 5 лет. Здесь откатили систему и все вроде бы снова в норме (тьфу, тьфу, тьфу). Так что продолжаем работу.
Оффлайн Алексей Юдин
  • Благодарностей: 1129
    • Сообщения от Алексей Юдин
« Ответ #2325 : 29 Июл 2015 [11:26:23] »
Так 200 баксов и все дела. http://www.amazon.com/Supermicro-Motherboard-uATX-DDR3-MBD-X10SLH-F-O/dp/B00D65R43C
Оффлайн LeonidOS
« Ответ #2326 : 29 Июл 2015 [11:27:31] »
Сам комп что-то в 3 раза дороже чем эта мама. Плюс нужно было готовое решение. Но будем иметь ввиду.
Оффлайн r1bgg
« Ответ #2327 : 29 Июл 2015 [11:40:46] »
Ровно так. Еще один неявный бонус - возможность запустить в одном физическом сервере несколько экземпляров разных операционок. Допустим есть ПО, которое не запустить внутри одной WINDOWS по какой то причине, или нужно протестить новую версию ПО и при этом нельзя портить работающую конфигурацию.
« Ответ #2328 : 29 Июл 2015 [11:44:53] »
На Астрохостингах нет свободы выбора. Они предлагают только решения, с которыми умеют работать (или где имеют процент с продаж).
Поэтому фразу Лёни про самое дешевое нужно читать - выбрали подешевле из списка того, чего нам предложили.
Оффлайн r1bgg
« Ответ #2329 : 29 Июл 2015 [11:47:11] »
На Астрохостингах нет свободы выбора. Они предлагают только решения, с которыми умеют работать.
Проникновение виртуализации на сегодня тотальное. Скорее всего вам не откажут в установке ESXI вместо windows, это еще проще.
« Ответ #2330 : 29 Июл 2015 [11:48:35] »
К чему этот бессмысленный спор?
Решение уже выбрано и реализовано.
« Ответ #2331 : 29 Июл 2015 [11:50:00] »
На астрохостингах не сидят айтишники, там астродельцы мелкобуржуазно-кулацкого толка с суровой примесью деревни. Для них ангар с телескопами - хорошая замена коровнику, главное чтобы доился!
« Ответ #2332 : 29 Июл 2015 [11:51:49] »
У наших коллег есть решение с серверами.
Там полно своих проблем.
Так что панацеи, думаю, нет. Всегда есть свои плюсы и минусы.
Оффлайн r1bgg
« Ответ #2333 : 29 Июл 2015 [11:53:14] »
Это технология, которая у Вас не используется, которая требует минимум ресурсов для реализации, и которая может принести большую пользу, как минимум в решении проблем с синим экраном.
« Ответ #2334 : 29 Июл 2015 [12:00:28] »
И которая требует привлечения своих специалистов, которых у нас не хватает  8)
Мы уже имеем опыт работы на удаленке с несколькими виртуальным ядрами. Ничего радостного сказать не можем. С Сайдинг Спринг и Нью-Мексико разбирается сам Леонид. А в Кисловодске каждый шаг требовал привлечения системного администратора - что само по себе уже сложная проблема.  :)  Почти год только софт ставили и отлаживали.  :-\  А на то, чтобы выйти на нормальную работу, потребовалось 2 года. Так что это только кажется, что все легко и просто.
На форуме есть темы посвященные удаленкам и их техническим решениям.  Большая просьба здесь в этой теме не развертывать технические дискуссии. Помним, что тема находится в разделе "Астрономия и общество", т.е. не в техническом. ;)  Здесь это оф-топ.
« Последнее редактирование: 29 Июл 2015 [12:06:43] от kismet »
Оффлайн r1bgg
« Ответ #2335 : 29 Июл 2015 [12:09:48] »
принято
« Ответ #2336 : 29 Июл 2015 [12:15:22] »
Если же Вы реально хотите помочь нашему проекту, то тогда просьба открывать нам глаза на нашем собственном форуме, где Ваши посты прочтет куда большее количество технических специалистов и наблюдателей. Ссылка на наш сайт - у меня под аватарой.
« Ответ #2337 : 29 Июл 2015 [22:31:21] »
В Сайдинг Спринг постепенно налаживается. Заменили переходник USB/компорт.
Радует монтировка. После прописывания модели ведет 150 секунд великолепно без гида. Больше пока не пробовал. В НМ хуже, но видимо вес сказывается. Там телескоп примерно на 25 кг (четверть от грузоподъемности) тяжелее.
« Ответ #2338 : 29 Июл 2015 [22:39:22] »
http://turkmenistan.gov.tm/?id=9302
Намечается модернизация обсерватории Душак-Эрекдаг
В Институте сейсмологии и физики атмосферы Академии наук Туркменистана прошла встреча с научным сотрудником Института прикладной математики имени М.В.Келдыша Российской Академии наук Игорем Молотовым. Цель его визита состояла в изучении возможностей сотрудничества в области наблюдений за космическими объектами с помощью астрономических телескопов.
Как известно, близ Ашхабада, на горе Душак-Эрекдаг, на высоте 2400 метров над уровнем моря, находится астрономическая обсерватория, располагающая тремя телескопами с зеркалами большого диаметра. Причём именно наша, туркменская обсерватория является одной из лучших в мире с точки зрения проведения астрономических наблюдений: до 2 тысяч 100 часов в год.
Оптические телескопы могут обеспечить высокую точность прогнозов и измерений параметров орбит космических аппаратов, астероидов, комет, космического мусора и т.п. Освоение галактического пространства даёт множество преимуществ для дальнейшего развития земной цивилизации. Это – устойчивая связь, прогноз погоды, глобальная навигация, мониторинг полезных ресурсов, опасных космических событий, научные исследования и т.д. Вместе с тем, как уточнил И.Молотов, «жизнеспособность» околоземного космического пространства во многом зависит от реалий его использования. С каждым годом увеличивается количество околоземных космических объектов – сейчас их отслеживается порядка 25 тысяч. По имеющимся данным, на сегодняшний день их общее число приближено к 500 тысячам!
Потому не удивительно, что обстановка в околоземном космическом пространстве стала предметом пристального внимания многих организаций, в том числе на уровне Организации Объединенных Наций. Все государства стремятся иметь собственные средства мониторинга космического пространства или доступ к независимым источникам информации, одним из которых является российская Научная сеть оптических инструментов для астрометрических и фотометрических наблюдений (НСОИ АФН). Командой специалистов данного научного проекта была разработана эффективная и экономичная технология наблюдений за космическим мусором с использованием небольших автоматизированных обзорных телескопов и налажено их серийное производство.
На сегодняшний день НСОИ АФН является основным поставщиком измерительной информации для системы Роскосмоса, в частности, для «Автоматизированной системы предупреждения об опасных ситуациях в околоземном космическом пространстве (АСПОС ОКП)». НСОИ АФН является самой большой подобной сетью в мире. С ней сотрудничают 35 обсерваторий из 15-ти стран, наладив работу по наблюдениям в общей сложности посредством 84 телескопов. В солидном списке партнёров – обсерватории Узбекистана (Китаб и Майданак), Казахстана (Тянь-Шань), Таджикистана (Гиссар и Санглок), Монголии (Хуралтогот), Грузии (Абастумани), Армении (Бюракан) и т.д.
В Институте прикладной математики им.М.В.Келдыша РАН создана служба прогнозов опасных космических событий на высоких орбитах. Здесь каждый день проводится анализ позиционных измерений, поступающих от НСОИ АФН, обновляется банк данных измерений и орбит, изучается орбитальная эволюция объектов, ведутся прогнозирование, оценка параметров опасных сближений и прочие исследования.
– Учитывая, что Туркменистан также имеет собственный спутник на геостационарной орбите – «TürkmenÄlem 52°E», мы готовы вместе с вашими специалистами и учеными, участвовать в обеспечении его безопасности, рассчитывать точные прогнозы опасных сближений с фрагментами космического мусора, – сказал Игорь Молотов. – В этом плане очень важно возобновить работу уникальной обсерватории Туркменистана – Душак-Эрекдаг.
Показательно, что астроклимат туркменской обсерватории не имеет аналогов в странах СНГ по количеству наблюдательных ночей и качеству атмосферы. Обсерватория располагает тремя относительно крупными телескопами (1 м, 80 см и 50 см), которые нуждаются в модернизации. Участие собственной обсерватории в работах по обеспечению безопасности космического аппарата «TürkmenÄlem 52°E» позволит значительно повысить качество прогнозов. Эти измерения также могут быть востребованы для поддержки работ других спутников в регионе. В этом случае Национальное космическое агентство Туркменистана может участвовать в создании базы данных по космическим объектам в регионе и войти в Межагентский координационный комитет по космическому мусору (IADC).
Для скорейшего возобновления работы обсерватории Душак-Эрекдаг российская Научная сеть оптических инструментов для астрономических и фотометрических наблюдений готова передать Туркменистану обзорный автоматизированный телескоп в комплекте с необходимым оборудованием и программным обеспечением, а также провести обучение специалистов. Мы предлагаем свою помощь и в модернизации существующих телескопов обсерватории.
Что же касается астероидно-кометной опасности, то она является относительно новой задачей, поставленной перед человечеством, а потому одной из важных точек взаимодействия туркменских и зарубежных учёных в этом направлении может стать своевременное обнаружение, уточнение орбит небесных тел, исследование, поиск новых астероидов и комет, а также изучение их физических свойств.
Туркменские специалисты также рассчитывают на перспективное сотрудничество с российскими коллегами, предложение которых их весьма заинтересовало: оно отвечает задачам как Академии наук Туркменистана в целом, так и, в частности, Института сейсмологии и физики атмосферы и созданной в его структуре лаборатории современной геодинамики и физики атмосферы.
« Последнее редактирование: 30 Июл 2015 [13:37:15] от kismet »
« Ответ #2339 : 30 Июл 2015 [10:16:17] »
TITLE:   GCN CIRCULAR
NUMBER:  18094
SUBJECT: GRB 150728A: AAO optical observations
DATE:    15/07/29 18:30:31 GMT
E. Mazaeva (IKI), R. Inasaridze (AAO), Sh. Makandarashvili (AAO),   A.
Volnova (IKI), I. Molotov (KIAM), A. Pozanenko (IKI) report on behalf of larger GRB follow-up collaboration:
We observed the field of the Swift GRB 150728A (Krimm et al. GCN 18087)
  with AS-32 (0.7m) telescope of Abastumani Observatory starting on Jul.
28 (UT) 19:32:14.  Within the enhanced XRT error circle (Beardmore et al. GCN 18088) we detected the object coinciding with the object found by FTN (Dichiara et al. GCN 18090).  A photometry of the object is following
Date       UT start    t-T0     Filter  Exp.     OT
                        (mid, days)      (s)
2015-07-28 19:32:14    0.30491  None    28*120   20.6+/-0.25
The photometry is based on nearby USNO-B1.0 stars USNO-B.1_id  R2
1239-0338943 17.06
1239-0338998 16.69
The photometry could be biased by nearby star. Presently we cannot say nothing about variability of the object and more observation is necessary to confirm/reject the object as afterglow of GRB 150728A.
