ВНИМАНИЕ! На форуме началось голосование в конкурсе - астрофотография месяца - ИЮНЬ!
TITLE: GCN CIRCULARNUMBER: 17784SUBJECT: GRB 150413A: CrAO optical observationsDATE: 15/04/28 19:47:55 GMTFROM: Alexei Pozanenko at IKI, MoscowV. Rumyantsev (CrAO), K. Antoniuk (CrAO), E. Mazaeva (IKI), A. Pozanenko (IKI) report on behalf of larger GRB follow-up collaboration:We observed the field of the GRB 150413A (Markwardt et al., GCN 17688) with AZT-11 telescope of CrAO observatory starting on Apr. 13 (UT) 17:39:02. Several images were take in R-filter. The afterglow (Ivanov et al., GCN 17689) is clearly detected in all single images of 180 s exposure. Preliminary photometry is followingDate, UT start, OT, OT_err2015-04-13 17 40 32.11 16.56 0.122015-04-13 17 43 36.17 16.97 0.302015-04-13 17 46 40.21 16.48 0.072015-04-13 17 49 44.26 16.73 0.112015-04-13 17 52 48.30 16.48 0.152015-04-13 17 55 52.37 16.62 0.132015-04-13 17 58 56.41 16.74 0.092015-04-13 18 02 00.58 16.63 0.132015-04-13 18 05 04.68 16.78 0.102015-04-13 18 08 08.76 16.77 0.092015-04-13 18 11 12.83 16.63 0.072015-04-13 18 14 16.87 16.74 0.062015-04-13 18 17 20.95 16.74 0.042015-04-13 18 20 25.30 16.76 0.062015-04-13 18 23 29.10 16.77 0.102015-04-13 18 26 33.15 16.90 0.082015-04-13 18 29 37.20 16.74 0.072015-04-13 18 32 41.25 16.71 0.052015-04-13 18 35 45.30 16.78 0.042015-04-13 18 38 49.36 16.77 0.032015-04-13 18 44 31.44 16.88 0.032015-04-13 18 47 35.48 16.81 0.032015-04-13 18 50 39.57 16.87 0.032015-04-13 18 53 43.66 16.92 0.032015-04-13 18 56 47.73 16.98 0.032015-04-13 18 59 51.90 17.02 0.032015-04-13 19 02 55.98 16.95 0.042015-04-13 19 06 00.64 16.94 0.042015-04-13 19 09 04.22 17.08 0.072015-04-13 19 12 08.35 17.05 0.06The photometry is based on nearby USNO-B1.0 1618-0098185 (Xu et al., GCN 17693) assuming R=15.59.
Приветствую всех следящих за темой!)Павильон обшит профнастилом. Завтра установка рольставни и косметика по мелочам.
TITLE: GCN CIRCULARNUMBER: 17815SUBJECT: GRB 150512A: CrAO optical observationsDATE: 15/05/14 19:30:18 GMTFROM: Alexei Pozanenko at IKI, MoscowE. Mazaeva (IKI), V. Rumyantsev (CrAO), A. Pozanenko (IKI) report on behalf of larger GRB follow-up collaboration:We observed the two OT candidates (Singer et al., GCN 17809) of the Fermi GRB 150512A (Zhang et al., GCN 17811) with ZTSh telescope of CrAO observatory starting on May. 13 (UT) 21:04:53. Both candidats are clearly visible in our images. Photometry of the candidates is followingiPTF15asn:Date UT start t-T0 Filter Exp. Source Err. (mid, days) (s)2015-05-13 21:04:53 1.45795 R 16*120 19.20 0.03iPTF15asm:Date UT start t-T0 Filter Exp. Source Err. (mid, days) (s)2015-05-13 21:46:49 1.48417 R 12*120 19.40 0.02Photometry of iPTF15asm might be biased by nearby galaxy SDSS J134044.09+631954.4. However both sources do not fade in comparison with early observations (Singer et al., GCN 17809) and most probably cannot be considered as afterglow.Photometry is in Vega, and based on following SDSS starsSDSS9_id R_LuptonJ135741.63+650759.8 16.82J135738.44+650852.4 18.03J135752.58+650922.2 18.14
Раньше у них тут стофл неавтоматизированный старый спаренный телескоп (40-см Шмидт и 60-см Кассегрен). Они решили с ним не возиться, а протсо демонтировать
Фасад юг.Сейчас морочусь с фланцами колонн - надо было заказать у вас. Напомню для крепления монтировки там есть отверстие - 30мм проходное сквозное и диаметром 65 -непроходное - глубиной 5 мм. Нужен фрезер. А его нет.Может быть всё же привезёте 2 шт со своим специалистами? Приварить их будет дело 10 мин.Можно конечно сделать всё по-колхозному: 30 мм прожечь сваркой, вместо углубления подложить монетки и т.п. Но будет конечно это не круто и неэстетично...
С нашим техником Серегой занимался ремонтно-такелажными работами на загородной станции. Приводим в порядок хозяйство АЗТ-8. Купол-створки-телескоп. Есть планы ручное открывание створок сделать от моторчика с редуктором. Механику телескопа надо доводить до штатной работы к запуску системы автоматического наведения.На следующей неделе планируем снятие Бейкер-Шмидта с АПШ-5 для начала работы по установке червячной пары по дельта.Еще по павильонам - решаем какую делать систему откатывания крыш.Пока, Юра
