A A A A Автор Тема: Навигация на приливно-синхронной планете  (Прочитано 2296 раз)
Оффлайн xd
  • Благодарностей: 379
    • Skype - deimos.belastro.net
    • Сообщения от xd
Комментарий модератора Андрей Астрофизический, первое предупреждение по пункту 3.1а
Оффлайн Ultima Thulean
  • Благодарностей: 233
  • All empires fall
    • Сообщения от Ultima Thulean
In the particular (but frequent) case of synchronous satellites, four more poles can be defined. They are the near, far, leading, and trailing poles. For example, Io, one of the moons of Jupiter, rotates synchronously, so its orientation with respect to Jupiter stays constant. There will be a single, unmoving point of its surface where Jupiter is at the zenith, exactly overhead – this is the near pole, also called the sub- or pro-Jovian point. At the antipode of this point is the far pole, where Jupiter lies at the nadir; it is also called the anti-Jovian point. There will also be a single unmoving point which is farthest along Io's orbit (best defined as the point most removed from the plane formed by the north-south and near-far axes, on the leading side) – this is the leading pole. At its antipode lies the trailing pole. Io can thus be divided into north and south hemispheres, into pro- and anti-Jovian hemispheres, and into leading and trailing hemispheres
То есть, выделяются ближний, дальний, ведущий и ведомый полюса
Lumi peittää mustan maan
Tiensä päähän sen ansaiten
Hänen silmänsä valkoiset
Mustan jumalan kirkkauden
