ВНИМАНИЕ! На форуме началось голосование в конкурсе - астрофотография месяца МАРТ!
Но даже, если и есть вокруг войд, то и местная группа галактик, и скопление Девы и сверхскопление Девы вполне могут в него входить.Войд это далеко не абсолютная пустота без галактик.
The fully nonlinear gravitationally induced trajectories of a nearly complete set of galaxies, groups, and clusters in the Local Supercluster are constructed in a Numerical Action Method (NAM) model constrained by data from the CosmicFlows survey and various distance indicators. We add the gravity field due to inhomogeneities external to the sample sphere by making use of larger scale peculiar flow measurements. Assignments of total masses were made to find the best overall set of mutual attractions, as determined by a goodness criterion based on present day radial velocities, individually for the Virgo Cluster, M31, and the Milky Way (MW), and via a mass-to-light ratio relationship for other masses. The low median chi-square found indicates the model fits the present day velocity flow well, but a slightly high mean chi-square may indicate that some masses underwent complex orbits. The best fit, when setting the value of H0 to the CosmicFlows value of 75 km/s/Mpc and the WMAP value for Ωm=0.244 consistent with that H0, occurs with the following parameters: Ωorphan=0.077±0.016, M/LK= 40±2 L0.1510 M⊙/L⊙ (L10 is K-band luminosity in units of 1010L⊙), a Virgo mass of 6.3±0.8×1014M⊙ (M/LK=113±15M⊙/L⊙), and a mass for the MW plus M31 of 5.15±0.35×1012M⊙. The best constant mass-to-light ratio is M/L K=58±3M⊙/L⊙. The Virgocentric turnaround radius is 7.3±0.3 Mpc. We explain several interesting trends in peculiar motions for various regions now that we can construct the 3D orbital histories.
Полностью нелинейные гравитационно-индуцированные траектории почти полного набора галактик, групп и кластеров в локальном суперкластере построены в модели численного действия (NAM), ограниченной данными исследования CosmicFlows и различными индикаторами расстояния. Мы добавляем гравитационное поле из-за неоднородностей, внешних по отношению к сфере образца, используя более крупные измерения удельного расхода. Присвоения суммарной массы были сделаны для того, чтобы найти лучший общий набор взаимных аттракционов, определяемый критерием доброты, основанным на сегодняшних лучевых скоростях, индивидуально для кластера Девы, М31 и Млечного пути (MW) отношение света к другим массам. Найденный низкий средний хи-квадрат указывает, что модель хорошо соответствует сегодняшнему скоростному потоку, но слегка высокий средний хи-квадрат может указывать на то, что некоторые массы подверглись сложным орбитам. Наилучшее соответствие при установке значения H0 в значение CosmicFlows 75 км / с / Мпк и значение WMAP для Ωm = 0,244, согласующееся с этим H0, происходит со следующими параметрами: Ωorphan = 0,077 ± 0,016, M / LK = 40 ± 2 L0,1510 M⊙ / L⊙ (L10 - светимость K-диапазона в единицах 1010L⊙), масса Девы 6,3 ± 0,8 × 1014M⊙ (M / LK = 113 ± 15M⊙ / L⊙) и масса для MW плюс M31 5,15 ± 0,35 × 1012 М⊙. Наилучшее постоянное отношение массы к свету - M / L K = 58 ± 3M⊙ / L⊙. Радиус поворота Virgocentric составляет 7,3 ± 0,3 Мпк. Мы объясняем несколько интересных тенденций в особых движениях для различных регионов, теперь мы можем построить трехмерные орбитальные истории.
Эффект очень мал на уровне галактик.
Как известно ускоренное расширение нашей Вселенной началось при z=1.8 или около 2
Это всего лишь гипотеза.Не исключено, что переменная кривизна пространства стационарной Вселенной интерпретируется через это расширение.Другими словами, иллюзия расширения создается переменной кривизной, присущей наблюдаемому пространству Вселенной.
Цитата: Geen от 20 Янв 2018 [23:15:35]Эффект очень мал на уровне галактик.Что за эффект? Не может такое событие в жизни Вселенной не отразится на видимом веществе.
Цитата: аФон+ от 20 Янв 2018 [23:34:24]Это всего лишь гипотеза.Не исключено, что переменная кривизна пространства стационарной Вселенной интерпретируется через это расширение.Другими словами, иллюзия расширения создается переменной кривизной, присущей наблюдаемому пространству Вселенной.Это чего это?Не понял, можно подробнее
На всякий случай - в этой теме нельзя.
есть публикации на такую тему что ли?
Была такая тема
Цитата: Geen от 20 Янв 2018 [23:58:36]Была такая тема Может быть возможно её открыть, для продолжения обсуждений? (кликните для показа/скрытия)https://astronomy.ru/forum/index.php/topic,139480.msg3558447.html#msg3558447
вроде бы это установлено в 1998 г по
Цитата: (Антонн) от 21 Янв 2018 [00:20:28]вроде бы это установлено в 1998 г по Вы не поняли, речь была о том, что никак невозможно отличить расширение нестационарной Вселенной от переменной кривизны пространства стационарной Вселенной.
