A A A A Автор Тема: Кометы видимые невооруженным взглядом  (Прочитано 6954 раз)
Оффлайн semenov
  • Благодарностей: 18
    • Сообщения от semenov
Re: Кометы видимые невооруженным взглядом
« Ответ #20 : 19 Дек 2013 [00:27:05] »
Яркие кометы с 1935 года
Обновлено в ноябре 2013 года
Brightest comets seen since 1935
Below are listed, in order of apparent brightness (magnitude), the brightest comets observed by ground-based observers since 1935, chiefly as documented in the ICQ archive and IAU Circulars (but also consulting the reports in the Harvard College Observatory Announcement Cards, QJRAS, Sky and Telescope, Observatory, PASP, and JBAA). The "peak m1" is the maximum observed total visual magnitude as seen by ground-based observers; this is an average value determined from the most experienced observers [in other words, some brighter magnitudes have been excluded for some comets; the paucity of observers working to make good magnitude estimates many years ago, and the problems involved when comets are very near the sun and/or are much brighter than available comparison stars/planets, make it difficult to determine what the peak values should have been (this is also why we chose the cut-off to be 1935, instead of an earlier date)]. A good example of this is regarding the bright "Eclipse comet" of 1948, which was stated by two observers to have a nuclear condensation brighter than Venus, but to be several magnitudes fainter at brightest by most other accounts; so the uncertainty in peak total visual magnitude is something like -2 ± 3 magnitudes! [See also Bortle's "Bright-Comet Chronicles".] Peak magnitudes in parentheses are more highly uncertain (or not completely determined). Only those comets brighter than fourth magnitude are listed below.
One can see from this that, on average, we are able to view a comet that is brighter than fourth magnitude once every two years, a comet brighter than second mag once every 5.5 years or so, a comet brighter than first magnitude every 10 years or so, and a comet brighter than mag 0 roughly once every 15 years; of course, sometimes there will be two bright comets in a span of a year, while at other times there will be a 20-year interval between such apparitions. [updated 2013 Nov. 17]
  peak
   m1         Comet
(-10)       C/1965 S1 (Ikeya-Seki)
 (-5.5)     C/2006 P1 (McNaught)
  -3.0      C/1975 V1 (West)
 (-3)       C/1947 X1 (Southern comet)
 (-1)       C/1948 V1 (Eclipse comet)
 (-1)       C/2011 S3 (Lovejoy)
  -0.8      C/1995 O1 (Hale-Bopp)
 (-0.5)     C/1956 R1 (Arend-Roland)
 (-0.5)     C/2002 V1 (NEAT)
   0.0      C/1996 B2 (Hyakutake)
   0.0      C/1969 Y1 (Bennett)
  (0)       C/1973 E1 (Kohoutek)
  (0)       C/1962 C1 (Seki-Lines)
   0.5      C/1998 J1 (SOHO)
   1.0      C/1957 P1 (Mrkos)
  (1.0)     C/2011 L4 (PANSTARRS)
  (1)       C/1970 K1 (White-Ortiz-Bolelli)
   1.7      C/1983 H1 (IRAS-Araki-Alcock)
  (2)       C/1941 B2 (de Kock-Paraskevopoulos)
  (2.2)     C/2002 T7 (LINEAR)
   2.4     1P/1982 U1 (Halley)
  (2.4)   17P         (Holmes)  [Oct. 2007]
   2.5      C/2000 WM_1 (LINEAR)
   2.7      C/1964 N1 (Ikeya)
   2.8      C/2001 Q4 (NEAT)
   2.8      C/1989 W1 (Aarseth-Brewington)
   2.8      C/1963 A1 (Ikeya)
   2.9   153P/2002 C1 (Ikeya-Zhang)
   3.0      C/2001 A2 (LINEAR)
   3.3      C/1936 K1 (Peltier)
  (3.3)     C/2004 F4 (Bradfield)
   3.5      C/2004 Q2 (Machholz)
   3.5      C/1942 X1 (Whipple-Fedtke-Tevzadze)
   3.5      C/1940 R2 (Cunningham)
   3.5      C/1939 H1 (Jurlof-Achmarof-Hassel)
   3.5      C/1959 Y1 (Burnham)
   3.5      C/1969 T1 (Tago-Sato-Kosaka)
   3.5      C/1980 Y1 (Bradfield)
  (3.5)     C/1961 O1 (Wilson-Hubbard)
  (3.5)     C/1955 L1 (Mrkos)
   3.6      C/1990 K1 (Levy)
   3.7      C/1975 N1 (Kobayashi-Berger-Milon)
   3.9      C/1974 C1 (Bradfield)
   3.9      C/1937 N1 (Finsler)
Оффлайн Sergey B
  • Благодарностей: 380
    • Сообщения от Sergey B
« Ответ #21 : 19 Дек 2013 [05:26:00] »
Или в 1973 и 75-м Когоутека или Веста?
Комету Веста посчастливилось увидеть в феврале-марте 1976г., причем случайно.В тогдашних СМИ такой информации было очень мало.
Это была моя первая комета.На предрассветном небе и с очень шикарным хвостом, такого больше не было.Почему-то не догадался сфотогра
фировать.
Оффлайн nikbor1
  • Благодарностей: 144
    • Сообщения от nikbor1
« Ответ #22 : 22 Дек 2013 [22:30:54] »
Возьмём к примеру комету Беннет ,  ей почему то приписывают 0 звёздную величину , хотя луна по сравнению с ней была бледным пятном . На утреннем небе за пять минут до восхода Солнца комета была видна до половины небосвода а голова была низко над горизонтом и занимала примерно два градуса . По видимости эта комета была самой крупной на земном небе . Остальные кометы прошлого века да и нынешнего по сравнению с ней это мелочь . Крупнее кометы Бенетта я не видел . Да их и не было .
