спасибо Александр....эх как я негодовал....
.. когда он рядом с БТО проскакал, а я как назло работал на "сутках"....и ясно было...вот не пруха ![Cry :'(](https://astronomy.ru/forum/Smileys/kolobok/cry.gif)
Володя по твоей просьбе:
(164121) 2003 YT1
Display all designations for this object / # of variant orbits available = 3
Object is a Goldstone radar target during 2016/10/01-2016/11/(1: Physical studies requested.
Perturbed ephemeris below is based on 8-opp elements from MPO 372193. Last observed on 2015 Sept. 21.
Discovery date : 2003 12 18
Discovery site : Catalina
Discoverer(s) : CSS
Further observations? Not necessary for orbit improvement. Desirable as radar target. [PHA]
G4121 [H=16.2]
Date UT R.A. (J2000) Decl. Delta r El. Ph. V Sky Motion Object Sun Moon Uncertainty info
h m s "/min P.A. Azi. Alt. Alt. Phase Dist. Alt. 3-sig/" P.A.
2016 11 01 000000 05 35 40.5 +68 48 34 0.036 1.010 117.9 60.3 11.1 54.16 357.9 184 +66 -42 0.01 121 -50 N/A N/A / Map / Offsets
2016 11 01 003000 05 35 29.2 +69 15 34 0.036 1.010 117.7 60.5 11.2 53.86 357.8 177 +66 -38 0.02 121 -46 N/A N/A / Map / Offsets
2016 11 01 010000 05 35 17.5 +69 42 24 0.036 1.010 117.5 60.7 11.2 53.55 357.8 171 +65 -32 0.02 121 -42 N/A N/A / Map / Offsets
2016 11 01 013000 05 35 05.5 +70 09 04 0.036 1.009 117.2 61.0 11.2 53.24 357.8 166 +63 -27 0.02 120 -37 N/A N/A / Map / Offsets
2016 11 01 020000 05 34 53.2 +70 35 36 0.036 1.009 117.0 61.2 11.2 52.92 357.8 162 +61 -22 0.02 120 -32 N/A N/A / Map / Offsets
2016 11 01 023000 05 34 40.6 +71 01 57 0.036 1.009 116.7 61.4 11.2 52.61 357.8 159 +59 -17 0.02 120 -27 N/A N/A / Map / Offsets
2016 11 01 030000 05 34 27.9 +71 28 10 0.036 1.009 116.5 61.7 11.2 52.30 357.8 157 +57 -11 0.02 120 -22 N/A N/A / Map / Offsets
2016 11 01 033000 05 34 15.1 +71 54 13 0.036 1.009 116.3 61.9 11.2 51.99 357.8 156 +55 -06 0.02 119 -17 N/A N/A / Map / Offsets
2016 11 01 040000 05 34 02.2 +72 20 07 0.036 1.009 116.0 62.1 11.2 51.68 357.8 156 +52 -01 0.02 119 -12 N/A N/A / Map / Offsets
2016 11 01 043000 05 33 49.2 +72 45 52 0.036 1.009 115.8 62.4 11.2 51.38 357.9 156 +50 +04 0.02 119 -07 N/A N/A / Map / Offsets
2016 11 01 050000 05 33 36.3 +73 11 28 0.037 1.009 115.5 62.6 11.3 51.09 357.9 156 +48 +09 0.02 119 -02 N/A N/A / Map / Offsets
2016 11 01 053000 05 33 23.5 +73 36 55 0.037 1.009 115.3 62.8 11.3 50.81 358.0 157 +46 +13 0.02 118 +03 N/A N/A / Map / Offsets
2016 11 01 060000 05 33 10.8 +74 02 14 0.037 1.009 115.1 63.1 11.3 50.53 358.0 158 +44 +17 0.02 118 +07 N/A N/A / Map / Offsets
2016 11 01 063000 05 32 58.1 +74 27 25 0.037 1.008 114.8 63.3 11.3 50.26 358.1 159 +42 +21 0.02 118 +12 N/A N/A / Map / Offsets
2016 11 01 070000 05 32 45.6 +74 52 28 0.037 1.008 114.6 63.5 11.3 50.01 358.1 161 +40 +24 0.02 118 +16 N/A N/A / Map / Offsets
2016 11 01 073000 05 32 33.3 +75 17 24 0.037 1.008 114.3 63.8 11.3 49.76 358.2 162 +38 +27 0.02 117 +19 N/A N/A / Map / Offsets
2016 11 01 080000 05 32 21.0 +75 42 13 0.037 1.008 114.1 64.0 11.3 49.52 358.2 164 +37 +29 0.02 117 +23 N/A N/A / Map / Offsets
2016 11 01 083000 05 32 08.7 +76 06 54 0.037 1.008 113.8 64.2 11.3 49.29 358.3 166 +36 +30 0.02 117 +25 N/A N/A / Map / Offsets
2016 11 01 090000 05 31 56.5 +76 31 29 0.037 1.008 113.6 64.5 11.4 49.07 358.3 168 +35 +31 0.02 117 +28 N/A N/A / Map / Offsets
2016 11 01 093000 05 31 44.3 +76 55 57 0.037 1.008 113.3 64.7 11.4 48.85 358.4 170 +34 +30 0.02 116 +29 N/A N/A / Map / Offsets
2016 11 01 100000 05 31 31.9 +77 20 18 0.038 1.008 113.1 64.9 11.4 48.64 358.4 172 +34 +29 0.03 116 +30 N/A N/A / Map / Offsets
2016 11 01 103000 05 31 19.2 +77 44 34 0.038 1.008 112.9 65.2 11.4 48.43 358.4 174 +34 +28 0.03 116 +30 N/A N/A / Map / Offsets
2016 11 01 110000 05 31 06.1 +78 08 43 0.038 1.008 112.6 65.4 11.4 48.23 358.4 176 +33 +25 0.03 115 +30 N/A N/A / Map / Offsets
2016 11 01 113000 05 30 52.6 +78 32 46 0.038 1.007 112.4 65.6 11.4 48.02 358.4 178 +34 +22 0.03 115 +28 N/A N/A / Map / Offsets
2016 11 01 120000 05 30 38.3 +78 56 43 0.038 1.007 112.1 65.9 11.4 47.82 358.3 179 +34 +19 0.03 115 +27 N/A N/A / Map / Offsets
2016 11 01 123000 05 30 23.1 +79 20 34 0.038 1.007 111.9 66.1 11.5 47.62 358.2 181 +34 +15 0.03 115 +24 N/A N/A / Map / Offsets
2016 11 01 130000 05 30 06.7 +79 44 19 0.038 1.007 111.6 66.4 11.5 47.41 358.2 183 +35 +11 0.03 114 +21 N/A N/A / Map / Offsets
2016 11 01 133000 05 29 48.9 +80 07 57 0.038 1.007 111.4 66.6 11.5 47.20 358.1 184 +35 +06 0.03 114 +17 N/A N/A / Map / Offsets
2016 11 01 140000 05 29 29.3 +80 31 29 0.038 1.007 111.1 66.8 11.5 46.98 357.9 185 +36 +01 0.03 114 +14 N/A N/A / Map / Offsets
2016 11 01 143000 05 29 07.7 +80 54 55 0.039 1.007 110.9 67.1 11.5 46.76 357.8 187 +37 -04 0.03 114 +09 N/A N/A / Map / Offsets
2016 11 01 150000 05 28 43.6 +81 18 13 0.039 1.007 110.6 67.3 11.5 46.53 357.6 188 +38 -09 0.03 113 +05 N/A N/A / Map / Offsets
2016 11 01 153000 05 28 16.5 +81 41 24 0.039 1.007 110.4 67.5 11.5 46.28 357.4 188 +39 -14 0.03 113 +00 N/A N/A / Map / Offsets
2016 11 01 160000 05 27 46.0 +82 04 27 0.039 1.006 110.2 67.7 11.6 46.03 357.2 189 +40 -20 0.03 113 -05 N/A N/A / Map / Offsets
2016 11 01 163000 05 27 11.5 +82 27 22 0.039 1.006 109.9 68.0 11.6 45.77 357.0 189 +41 -25 0.03 112 -10 N/A N/A / Map / Offsets
2016 11 01 170000 05 26 32.2 +82 50 09 0.039 1.006 109.7 68.2 11.6 45.49 356.7 189 +42 -30 0.04 112 -15 N/A N/A / Map / Offsets
2016 11 01 173000 05 25 47.4 +83 12 47 0.039 1.006 109.5 68.4 11.6 45.21 356.4 189 +43 -35 0.04 112 -20 N/A N/A / Map / Offsets
2016 11 01 180000 05 24 56.1 +83 35 16 0.040 1.006 109.2 68.7 11.6 44.91 356.1 189 +44 -41 0.04 112 -25 N/A N/A / Map / Offsets
2016 11 01 183000 05 23 57.1 +83 57 35 0.040 1.006 109.0 68.9 11.6 44.60 355.7 189 +45 -45 0.04 111 -30 N/A N/A / Map / Offsets
2016 11 01 190000 05 22 49.1 +84 19 44 0.040 1.006 108.7 69.1 11.6 44.27 355.3 188 +46 -50 0.04 111 -35 N/A N/A / Map / Offsets
2016 11 01 193000 05 21 30.4 +84 41 43 0.040 1.006 108.5 69.3 11.7 43.94 354.9 187 +47 -54 0.04 111 -40 N/A N/A / Map / Offsets
2016 11 01 200000 05 19 58.8 +85 03 30 0.040 1.006 108.3 69.5 11.7 43.59 354.4 186 +47 -57 0.04 110 -45 N/A N/A / Map / Offsets
2016 11 01 203000 05 18 11.7 +85 25 05 0.040 1.006 108.1 69.8 11.7 43.24 353.8 185 +48 -59 0.04 110 -50 N/A N/A / Map / Offsets
2016 11 01 210000 05 16 05.4 +85 46 29 0.040 1.005 107.8 70.0 11.7 42.87 353.2 184 +48 -60 0.04 110 -54 N/A N/A / Map / Offsets
2016 11 01 213000 05 13 35.2 +86 07 39 0.041 1.005 107.6 70.2 11.7 42.50 352.5 183 +48 -59 0.04 110 -57 N/A N/A / Map / Offsets
2016 11 01 220000 05 10 34.9 +86 28 37 0.041 1.005 107.4 70.4 11.7 42.12 351.7 182 +48 -58 0.04 109 -59 N/A N/A / Map / Offsets
2016 11 01 223000 05 06 55.3 +86 49 20 0.041 1.005 107.2 70.6 11.7 41.73 350.7 182 +48 -55 0.04 109 -61 N/A N/A / Map / Offsets
2016 11 01 230000 05 02 23.6 +87 09 47 0.041 1.005 106.9 70.8 11.8 41.34 349.5 181 +48 -52 0.04 109 -61 N/A N/A / Map / Offsets
2016 11 01 233000 04 56 40.1 +87 29 58 0.041 1.005 106.7 71.0 11.8 40.95 348.1 180 +47 -47 0.05 108 -60 N/A N/A / Map / Offsets
2016 11 02 000000 04 49 14.3 +87 49 50 0.041 1.005 106.5 71.2 11.8 40.55 346.2 180 +47 -43 0.05 108 -57 N/A N/A / Map / Offsets
2016 11 02 003000 04 39 15.2 +88 09 19 0.041 1.005 106.3 71.4 11.8 40.16 343.7 179 +47 -38 0.05 108 -54 N/A N/A / Map / Offsets
2016 11 02 010000 04 25 12.8 +88 28 20 0.042 1.005 106.1 71.6 11.8 39.77 340.2 179 +46 -33 0.05 108 -50 N/A N/A / Map / Offsets
2016 11 02 013000 04 04 14.7 +88 46 38 0.042 1.004 105.9 71.8 11.8 39.38 335.0 179 +46 -27 0.05 107 -46 N/A N/A / Map / Offsets
2016 11 02 020000 03 30 21.3 +89 03 47 0.042 1.004 105.7 72.0 11.8 39.00 326.5 179 +45 -22 0.05 107 -42 N/A N/A / Map / Offsets
2016 11 02 023000 02 30 32.4 +89 18 35 0.042 1.004 105.5 72.2 11.9 38.62 311.7 179 +45 -17 0.05 107 -37 N/A N/A / Map / Offsets
2016 11 02 030000 00 44 04.7 +89 27 58 0.042 1.004 105.3 72.4 11.9 38.25 285.1 179 +45 -12 0.05 107 -32 N/A N/A / Map / Offsets
2016 11 02 033000 22 27 21.6 +89 27 18 0.042 1.004 105.1 72.6 11.9 37.89 251.0 180 +44 -06 0.05 106 -27 N/A N/A / Map / Offsets
2016 11 02 040000 20 48 38.7 +89 17 16 0.043 1.004 104.9 72.8 11.9 37.55 226.4 180 +44 -01 0.05 106 -21 N/A N/A / Map / Offsets
2016 11 02 043000 19 53 49.9 +89 02 47 0.043 1.004 104.6 73.0 11.9 37.21 212.9 181 +44 +04 0.05 106 -16 N/A N/A / Map / Offsets
2016 11 02 050000 19 22 20.2 +88 46 32 0.043 1.004 104.4 73.2 11.9 36.88 205.1 181 +44 +08 0.05 106 -11 N/A N/A / Map / Offsets
2016 11 02 053000 19 02 31.6 +88 29 35 0.043 1.004 104.2 73.4 11.9 36.57 200.3 182 +44 +13 0.06 105 -06 N/A N/A / Map / Offsets
2016 11 02 060000 18 49 03.1 +88 12 19 0.043 1.004 104.0 73.6 12.0 36.26 197.0 182 +44 +17 0.06 105 -02 N/A N/A / Map / Offsets
2016 11 02 063000 18 39 19.1 +87 54 57 0.043 1.003 103.8 73.7 12.0 35.98 194.7 183 +44 +21 0.06 105 +03 N/A N/A / Map / Offsets
2016 11 02 070000 18 31 57.3 +87 37 33 0.044 1.003 103.6 73.9 12.0 35.70 193.0 183 +45 +24 0.06 105 +08 N/A N/A / Map / Offsets
2016 11 02 073000 18 26 10.9 +87 20 11 0.044 1.003 103.5 74.1 12.0 35.43 191.7 184 +45 +26 0.06 104 +12 N/A N/A / Map / Offsets
2016 11 02 080000 18 21 31.4 +87 02 52 0.044 1.003 103.3 74.3 12.0 35.18 190.7 184 +46 +28 0.06 104 +16 N/A N/A / Map / Offsets
2016 11 02 083000 18 17 40.7 +86 45 36 0.044 1.003 103.1 74.5 12.0 34.94 189.8 184 +46 +30 0.06 104 +19 N/A N/A / Map / Offsets
2016 11 02 090000 18 14 26.6 +86 28 26 0.044 1.003 102.9 74.7 12.0 34.71 189.1 184 +47 +30 0.06 104 +22 N/A N/A / Map / Offsets
2016 11 02 093000 18 11 41.0 +86 11 20 0.044 1.003 102.7 74.9 12.1 34.48 188.5 184 +47 +30 0.06 103 +24 N/A N/A / Map / Offsets
2016 11 02 100000 18 09 17.7 +85 54 20 0.045 1.003 102.5 75.0 12.1 34.27 188.0 184 +48 +29 0.06 103 +26 N/A N/A / Map / Offsets
2016 11 02 103000 18 07 12.6 +85 37 25 0.045 1.003 102.3 75.2 12.1 34.06 187.5 184 +48 +27 0.06 103 +28 N/A N/A / Map / Offsets
2016 11 02 110000 18 05 22.4 +85 20 34 0.045 1.003 102.1 75.4 12.1 33.85 187.1 183 +49 +25 0.07 103 +28 N/A N/A / Map / Offsets
2016 11 02 113000 18 03 44.6 +85 03 49 0.045 1.002 101.9 75.6 12.1 33.65 186.8 182 +50 +22 0.07 102 +28 N/A N/A / Map / Offsets
2016 11 02 120000 18 02 17.6 +84 47 09 0.045 1.002 101.7 75.8 12.1 33.46 186.4 181 +50 +18 0.07 102 +27 N/A N/A / Map / Offsets
2016 11 02 123000 18 00 59.6 +84 30 34 0.046 1.002 101.5 75.9 12.2 33.26 186.1 180 +50 +15 0.07 102 +26 N/A N/A / Map / Offsets
2016 11 02 130000 17 59 49.6 +84 14 05 0.046 1.002 101.3 76.1 12.2 33.07 185.8 179 +51 +10 0.07 102 +24 N/A N/A / Map / Offsets
2016 11 02 133000 17 58 46.7 +83 57 40 0.046 1.002 101.1 76.3 12.2 32.87 185.5 178 +51 +06 0.07 101 +21 N/A N/A / Map / Offsets
2016 11 02 140000 17 57 49.9 +83 41 22 0.046 1.002 100.9 76.5 12.2 32.67 185.2 176 +51 +01 0.07 101 +18 N/A N/A / Map / Offsets
2016 11 02 143000 17 56 58.8 +83 25 08 0.046 1.002 100.8 76.6 12.2 32.47 184.9 175 +50 -04 0.07 101 +14 N/A N/A / Map / Offsets
2016 11 02 150000 17 56 12.7 +83 09 01 0.047 1.002 100.6 76.8 12.2 32.26 184.6 174 +50 -09 0.07 101 +10 N/A N/A / Map / Offsets
2016 11 02 153000 17 55 31.1 +82 52 59 0.047 1.002 100.4 77.0 12.2 32.04 184.4 172 +50 -15 0.08 100 +06 N/A N/A / Map / Offsets
2016 11 02 160000 17 54 53.7 +82 37 04 0.047 1.001 100.2 77.1 12.3 31.83 184.1 171 +49 -20 0.08 100 +01 N/A N/A / Map / Offsets
2016 11 02 163000 17 54 20.1 +82 21 15 0.047 1.001 100.0 77.3 12.3 31.60 183.8 170 +48 -25 0.08 100 -04 N/A N/A / Map / Offsets
2016 11 02 170000 17 53 49.9 +82 05 32 0.047 1.001 99.8 77.5 12.3 31.37 183.6 169 +47 -31 0.08 100 -08 N/A N/A / Map / Offsets
2016 11 02 173000 17 53 22.9 +81 49 57 0.048 1.001 99.7 77.6 12.3 31.12 183.3 169 +46 -36 0.08 099 -13 N/A N/A / Map / Offsets
2016 11 02 180000 17 52 58.7 +81 34 28 0.048 1.001 99.5 77.8 12.3 30.88 183.1 168 +45 -41 0.08 099 -19 N/A N/A / Map / Offsets
2016 11 02 183000 17 52 37.1 +81 19 07 0.048 1.001 99.3 78.0 12.3 30.62 182.9 168 +44 -46 0.08 099 -24 N/A N/A / Map / Offsets
2016 11 02 190000 17 52 17.8 +81 03 53 0.048 1.001 99.1 78.1 12.3 30.36 182.7 168 +43 -50 0.08 099 -29 N/A N/A / Map / Offsets
2016 11 02 193000 17 52 00.7 +80 48 48 0.048 1.001 99.0 78.3 12.4 30.09 182.5 168 +42 -54 0.08 099 -34 N/A N/A / Map / Offsets
2016 11 02 200000 17 51 45.4 +80 33 50 0.049 1.001 98.8 78.4 12.4 29.81 182.3 169 +40 -57 0.08 098 -39 N/A N/A / Map / Offsets
2016 11 02 203000 17 51 31.9 +80 19 01 0.049 1.001 98.6 78.6 12.4 29.52 182.1 169 +39 -59 0.09 098 -44 N/A N/A / Map / Offsets
2016 11 02 210000 17 51 19.9 +80 04 20 0.049 1.000 98.5 78.8 12.4 29.24 181.9 170 +38 -60 0.09 098 -49 N/A N/A / Map / Offsets
2016 11 02 213000 17 51 09.2 +79 49 47 0.049 1.000 98.3 78.9 12.4 28.94 181.8 171 +37 -60 0.09 098 -53 N/A N/A / Map / Offsets
2016 11 02 220000 17 50 59.6 +79 35 24 0.049 1.000 98.1 79.1 12.4 28.65 181.6 172 +36 -58 0.09 097 -57 N/A N/A / Map / Offsets
2016 11 02 223000 17 50 51.0 +79 21 09 0.050 1.000 98.0 79.2 12.4 28.35 181.5 174 +35 -55 0.09 097 -60 N/A N/A / Map / Offsets
2016 11 02 230000 17 50 43.2 +79 07 04 0.050 1.000 97.8 79.3 12.5 28.05 181.4 175 +35 -52 0.09 097 -62 N/A N/A / Map / Offsets
2016 11 02 233000 17 50 36.0 +78 53 07 0.050 1.000 97.7 79.5 12.5 27.75 181.4 177 +34 -48 0.09 097 -63 N/A N/A / Map / Offsets
2016 11 03 000000 17 50 29.4 +78 39 19 0.050 1.000 97.5 79.6 12.5 27.45 181.3 179 +34 -43 0.09 097 -62 N/A N/A / Map / Offsets
2016 11 03 003000 17 50 23.2 +78 25 41 0.050 1.000 97.4 79.8 12.5 27.15 181.3 180 +33 -38 0.09 096 -60 N/A N/A / Map / Offsets
2016 11 03 010000 17 50 17.2 +78 12 11 0.051 1.000 97.2 79.9 12.5 26.86 181.3 182 +33 -33 0.10 096 -58 N/A N/A / Map / Offsets
2016 11 03 013000 17 50 11.4 +77 58 49 0.051 1.000 97.1 80.1 12.5 26.57 181.3 184 +33 -28 0.10 096 -54 N/A N/A / Map / Offsets
2016 11 03 020000 17 50 05.7 +77 45 37 0.051 0.999 96.9 80.2 12.5 26.29 181.3 186 +33 -22 0.10 096 -50 N/A N/A / Map / Offsets
2016 11 03 023000 17 49 59.9 +77 32 33 0.051 0.999 96.8 80.3 12.6 26.01 181.4 188 +34 -17 0.10 096 -45 N/A N/A / Map / Offsets
2016 11 03 030000 17 49 54.1 +77 19 37 0.051 0.999 96.6 80.5 12.6 25.74 181.4 190 +35 -12 0.10 095 -41 N/A N/A / Map / Offsets
2016 11 03 033000 17 49 48.1 +77 06 48 0.052 0.999 96.5 80.6 12.6 25.48 181.5 192 +35 -07 0.10 095 -36 N/A N/A / Map / Offsets
2016 11 03 040000 17 49 41.9 +76 54 08 0.052 0.999 96.3 80.7 12.6 25.23 181.6 193 +36 -01 0.10 095 -30 N/A N/A / Map / Offsets
2016 11 03 043000 17 49 35.5 +76 41 35 0.052 0.999 96.2 80.9 12.6 24.99 181.7 195 +38 +03 0.10 095 -25 N/A N/A / Map / Offsets
2016 11 03 050000 17 49 28.8 +76 29 09 0.052 0.999 96.0 81.0 12.6 24.76 181.8 196 +39 +08 0.11 095 -20 N/A N/A / Map / Offsets
2016 11 03 053000 17 49 21.8 +76 16 50 0.053 0.999 95.9 81.1 12.6 24.54 182.0 198 +40 +13 0.11 094 -15 N/A N/A / Map / Offsets
2016 11 03 060000 17 49 14.5 +76 04 38 0.053 0.999 95.7 81.2 12.6 24.33 182.1 199 +42 +17 0.11 094 -10 N/A N/A / Map / Offsets
2016 11 03 063000 17 49 07.0 +75 52 31 0.053 0.998 95.6 81.4 12.7 24.13 182.2 200 +44 +20 0.11 094 -05 N/A N/A / Map / Offsets
2016 11 03 070000 17 48 59.2 +75 40 31 0.053 0.998 95.5 81.5 12.7 23.94 182.4 200 +45 +23 0.11 094 -01 N/A N/A / Map / Offsets
2016 11 03 073000 17 48 51.1 +75 28 36 0.053 0.998 95.3 81.6 12.7 23.77 182.5 201 +47 +26 0.11 094 +04 N/A N/A / Map / Offsets
2016 11 03 080000 17 48 42.8 +75 16 46 0.054 0.998 95.2 81.7 12.7 23.60 182.6 201 +49 +28 0.11 094 +08 N/A N/A / Map / Offsets
2016 11 03 083000 17 48 34.3 +75 05 01 0.054 0.998 95.0 81.9 12.7 23.44 182.7 200 +51 +29 0.11 093 +12 N/A N/A / Map / Offsets
2016 11 03 090000 17 48 25.6 +74 53 21 0.054 0.998 94.9 82.0 12.7 23.29 182.8 199 +53 +30 0.12 093 +16 N/A N/A / Map / Offsets
2016 11 03 093000 17 48 16.9 +74 41 46 0.054 0.998 94.8 82.1 12.7 23.14 182.9 198 +55 +30 0.12 093 +19 N/A N/A / Map / Offsets
2016 11 03 100000 17 48 08.1 +74 30 14 0.054 0.998 94.6 82.2 12.8 23.01 182.9 196 +57 +29 0.12 093 +22 N/A N/A / Map / Offsets
2016 11 03 103000 17 47 59.3 +74 18 47 0.055 0.998 94.5 82.4 12.8 22.88 183.0 194 +58 +27 0.12 093 +24 N/A N/A / Map / Offsets
2016 11 03 110000 17 47 50.6 +74 07 23 0.055 0.998 94.4 82.5 12.8 22.75 183.0 190 +59 +25 0.12 092 +26 N/A N/A / Map / Offsets
2016 11 03 113000 17 47 42.0 +73 56 04 0.055 0.997 94.2 82.6 12.8 22.63 183.0 187 +60 +22 0.12 092 +27 N/A N/A / Map / Offsets
2016 11 03 120000 17 47 33.5 +73 44 48 0.055 0.997 94.1 82.7 12.8 22.50 183.0 183 +61 +18 0.12 092 +27 N/A N/A / Map / Offsets
